gpu cooling: zalman heatpipe with 120mm fan
highest gpu oc so far: 280
memory cooling: default
temp of water/gas: only air atm
highest memory oc so far (w/wo artifacts): 255/240
vgpu: default
vddr: default
vref: default
mods: zalman heatpipe mounted on the gpu, was quite some work as the holes seem to be placed a little diferent than on other cards so its not seated correctly, but it works.
without the zalman gheatpipe i could only get the gpu to 230-240.
highest score(madmark link):
highest score(futuremark link):
cpu: 1700+ 0308
cpu oc: 2000mhz atm
cpu cooling: coolermaster silent cooler (looks like the amd boxed cooler)
vcore: 1.60
mainboard: a7n8x deluxe rev2.0
fsb oc: 200 atm
chipset timings: cpu interface=optimal
nb cooling: default heatsink
sb cooling: default
mosfet cooling: default
chipset voltage: 1.7v
memory: khx 3500/twinmos3700
memory oc: 200
memory timings: 2-2-3-11
memory voltage: ~2.9v
psu: fortron fsp 350W
12v: 14.1
5v: 5.74
3.3v: 3.82
operating system: winxp pro
sp: default
driver: 3.53 (latest driver for compability with games)
ocing utility: sis utility
roomtemp: ~18°C
casetemp: ~21°C
cpu temp: 34°C idle 38°C load
