    X
    Subscribe to New Ads!
    Receive weekly ads in your inbox!
Results 1 to 3 of 3
Thread: D5 and multi res, most effecient
    Aussie God
    Feb 2005
    Copenhagen, Denmark
    Guys...
    What would you suggest for best performance..
    I got a Laing D5 Vario, EK multi res, and EK D5 Top (1 hole, center, 2 on top)
    I was thinking of using the res like a fillport.. Would that yield the better performance?
    Competition ranking;
    2008; AOCM II, Minfeld/Germany #2 @ 01SE/AM3/8M (w. Oliver)
    2009; AMD-OC, Viborg/Denmark #2 @ max freq Gigabyte TweaKING, Paris/France #4 @ 32M/01SE (w. Vanovich)
    2010: Gigabyte P55, Hamburg/Germany #6 @ wprime 1024/SPI 1M (w. THC) AOCM III, Minfeld/Germany #6 @ 01SE/AM3/1M/8M (w. NeoForce)
    Spectating;
    2010; GOOC 2010 Many thanks to Gigabyte!
    Aug 2009
    HT: SJ,CA CT: BF,WI
    yes you can use one of them all a fill port and a drain its what the tops are for. umm i dont know much but either/or would yield better performance
    Aug 2004
    Minneapolis, MN
    Using the res as a fill port will make bleeding the loop take longer. Bleeding the loop with a cylinder res is a piece of cake. I don't really think you'll gain much performance by bypassing it, as it doesn't have much restriction.
