Results 1 to 7 of 7
Thread: My personal record
    Mar 2010
    My personal record
    Hehe, may be lame compared to others but this is my first time ever breaking 2k on ram Clearly I'm new to memory OC
    I'm wondering if you guys could give me some help on my timings.. I can run SP 32m @ 2134 8-10-8 but I get the following error when I go down to 7-10-8
    Also, at what point should I be worried about VTT voltages harming my Bloomfield? What about DIMM voltage? What is DIMM DQ VREF?
    Quote Originally Posted by Sister
    Do you really go on your computer...to look at computers?
    Jul 2009
    Germany _ Frankfurt
    well, using a classified and beginning now with RAM oc is a bit contraire, but however, the Problem is, that your RAM is limiting you. The RAm is Speced to 1600, and now it runs with nearly 2200 on your Board, so thats quite impressing as well
    www.vitesse24.de
    www.vitesse24.de
    C2Q q6600 3.3GHZ @ 1,184V
    4,5GHZ@ 1,52V ( 9* 500 )
    Corsair Dominator 10000 2gb, 8888 2gb, 9136 1gb
    Xtreme Mentor
    Feb 2009
    Bangkok,Thailand (DamHot)
    some Dimm VOltage may help
    i think test with Hyper Pi 32Mx8threads is more stress for RAM
    Intel Core i5 6600K + ASRock Z170 OC Formula + Galax HOF 4000 (8GBx2) + Antec 1200W OC Version
    EK SupremeHF + BlackIce GTX360 + Swiftech 655 + XSPC ResTop
    Macbook Pro 15" Late 2011 (i7 2760QM + HD 6770M)
    Samsung Galaxy Note 10.1 (2014) , Huawei Nexus 6P
    [history system]80286 80386 80486 Cyrix K5 Pentium133 Pentium II Duron1G Athlon1G E2180 E3300 E5300 E7200 E8200 E8400 E8500 E8600 Q9550 QX6800 X3-720BE i7-920 i3-530 i5-750 Semp140@x2 955BE X4-B55 Q6600 i5-2500K i7-2600K X4-B60 X6-1055T FX-8120 i7-4790K
    Mar 2010
    Quote Originally Posted by aslanwas View Post
    This may be true, but I don't have a complete lack of understanding...I have a vague idea of the concept behind ram OC just not what each abbreviation stands for and slacking which / tightening some helps with stability.
    Yes I was quite happy when I heard the POST beep for 2134 booting
    Quote Originally Posted by PatRaceTin View Post
    I've got 1.7v set in BIOS, HW monitor is reporting 1.75v, I need to go get my MM to make sure what it's at. I don't need to blow up this set right now
    I see, I'll try with 4 threads..will this lower my score too? Did you guys notice this is only a 2x2 kit on x58? Does that make a difference?
    I am Xtreme
    Aug 2008
    whats your current vtt?
    8-10-8 should be fine...
    triple channel helps a little in some applications..but if you're into benching and competiting..tripple channel helps
    Mar 2010
    Right now I have +150mV, which hw monitor reports as somewhere near 1.45..but I'm going to check with my multi meter in a minute.
    Yeah I ran 32m @ 8-10-8
    Right now I'm doing it for benching fun/learning. If I get anything worthy, I want to submit it to the ddr3 high clock challenge. So far the 8-10-8 got me 8m11s I think.
    I'm going to disable HT and maybe drop 2 cores and see what I can do..but now I'm not posting at 2134 with same settings as last night. Maybe I degraded already
    edit: actual VTT is 1.33v ish via my MM, and DIMM is 1.7v
    Mar 2010
    Worked my way down to 2134 7-10-7 and I've bested an 8m 6s 32m
    What timings are better left higher and what is better left lower? I've got tREFI as high as it can go, 1023, and for everything else I'm just going to slowly try tightening it and see results.
    I've got tRAS down to 24 (testing now) and tRFC to 82..gonna keep trying to lower tRFC.
    Also, for 32m, what can I do in the OS to help speed this up? Run win XP x64? I hear people say they do "mods"? Run as minimal background process as possible?
