So I read how to do this and gave it a try with just a fan hooked up, no pump. I jumpered the ATX connector as stated, plugged a 4 pin modular molex into my PS with a fan attached and plugged in the power cord. However, the power only surges for a second and then stops. I need to turn the power supply off and on to keep the fan running. Is this what will need done to fill the loop with the pump or should it run constantly using the jumper?
Thanks,
John
