I had ordered new tubes last week, I decided to drop the tygon and go Primochill tubes for a change, yet what I see on my loop is more corrosion than any thing else, which again is pushing me towards buying thermochill EC6.
intel Core i7 980x, ASUS Rampage III Extreme , Corsair Dominator GT DDR3 2000 CL9 3x4GB , nVidia GTX 680 FTW TriSLI , Auzentech X-Fi HomeTheater HD
Guys what's the best way to clean the Res. I tried to scratch it with some cotton but that did not work, the acrylic in my res. is also kind of fuggy
I never been able to clean a clouded reservoir. There was thread a while back about trying to clean a clouded GPU (Shazza I think). please post a picture of your cleaned CPU block.
one thread reported using rice & vinegar to clean out an infected acrylic reservoir but i have no personal experience with this
here is a thread on using silver as a biocide that i meant to leave with my earlier post:
http://www.xtremesystems.org/forums/...77&mode=linear
good luck
I cleaned my 4 year old EK res using Klasse All in One - its crystal clear again now.
Yeah I had some gunk like this in my block last time I checked as well, jug of distilled from the grocery + PT. Don't think I overdid the latter but possible.
Dark Star IV i5 3570K | Asrock Z77 Extreme4 | 8GB Samsung 30nm | GTX 670 FTW 4GB + XSPC Razer 680 | 128GB Samsung 830 Apogee HD White | 140MM UT60/120MM UT45/120MM ST30 | XSPC D5 V2
so is it the tubing or the water?
Horror... Horror has a face... and you must make a friend of horror. Horror and moral terror are your friends. If they are not, then they are enemies to be feared.
ROFL! any relation to mark?Horror... Horror has a face... and you must make a friend of horror. Horror and moral terror are your friends. If they are not, then they are enemies to be feared.
"Lurking" Since 1977
Jesus Saves, God Backs-Up *I come to the news section to ban people, not read complaints.*-[XC]GomelerDon't believe Squish, his hardware does control him!
My tygon tubes did the same thing. Weird part, is that the separate GPU loop did not turn as cloudy, using the same tubing. This leads me to believe something in our loops to be causing the problem. (you can see it in my avatar) Leaning towards too much PT Nuke, because I use that also but seem to remember putting much less in the GPU loop.
Current: AMD Threadripper 1950X @ 4.2GHz / EK Supremacy/ 360 EK Rad, EK-DBAY D5 PWM, 32GB G.Skill 3000MHz DDR4, AMD Vega 64 Wave, Samsung nVME SSDs
Prior Build: Core i7 7700K @ 4.9GHz / Apogee XT/120.2 Magicool rad, 16GB G.Skill 3000MHz DDR4, AMD Saphire rx580 8GB, Samsung 850 Pro SSD
Intel 4.5GHz LinX Stable Club
So I might move on to silver I'm thinking, at least when I get new block(s).
well now we know if we use too much pt nuke it clouds up your loop but how much does it affect your blocks.
kill coil looks like the easier way to go just dropping it into your res.
much learned
could we pick it up @ any jewelry store and how much do we need?
Will a small piece of 925 silver work?
i7 950@4.05Ghz HeatKiller 3.0
EVGA E762 EK WB | 12Gb OCZ3X1600LV6GK
Razer Tarantula |Razer Imperator | SB X-Fi PCIe
480GTX Tri SLi EK WBs | HAF X | Corsair AX1200
____________________________________________
Loop1: Double_MCP655(EK Dual Top) - MoRa3Pro_4x180 - HK3.0 - EKFB_E762
Loop2: Koolance_MCP655(EK Top) - HWLabsSR1_360 - EK_FC480GTX(3x)
Yes, but you need 99.9% or .999 silver for best results. Sterling is 92%. The silver coils are 1 to 2 grams but one person used a 10 gm ingot to avoid movement in the reservoir.
When I tear down again, I am going to try true silver fittings. Allegedly 2 to 4 will equal a coil from various threads.
General link on silver from this forum listed above
buy or make your own silver coils which I have done and they are easy to make.
Wow that is crazy. I have used nothing but pure distilled water for 7 years now and Ive never had any issues like this. :o
MB Reviewer for HWC
Team OCX Bench Team
Yeah unless we just got poorly filtered distilled (which I suppose is possible) then it's got be the PTN...
The major question really is what's causing the corrosion in the loop?
How could some one know that the dist. water they are using is of a good quality !!?!?
Well this has thoroughly scared the crap out of me. I went a little heavy with the PT nuke in my loop, since last time when I followed their instructions algae started to grow.
