Hey peeps,
I wanted to know how my cpu copes with the newer models. As it's a cpu of the previous generation I wanted to know what the Core i7 equivalent would be when compared to my chip running at 4.1ghz with dd3 memories.
Any clue?
Hey peeps,
Any clue?
GIGABYTE Z97X Gaming 3
Intel i7-4790K Devil's Canyon @ 4.5ghz
NXZT 340S
Corsair H110i & Corsair Link
2x8GB Corsair Dominator Platinum DDR3-2133
ASUS Strix GTX1080Ti OC
Storage:
Corsair AX1200i PSU
- 2xSamsung 850 Pro 250GB SSD
- Samsung 860 Pro 250GB SSD
- Samsung 970 Evo M.2 250GB SSD
- WD Caviar SATAII 1TB 32 mb cache
- Seagate SATAII 320GB 16mb cache
- Samsung 2.5" SATAII 320GB 8mb cache
- HGST(PS4) 2.5" SATAII 500GB 8mb cache
- Maxtor SATAI 120GB 8mb cache
Windows 10 Pro 64bit
ASUS ROG Swift PG279Q
Core i7's with HT are directly comparable with HT turned off too. Gulfies aren't.
In many situations your chip will be essentially the same as an i7 with 4c/4t, but the core i7 architecture has better performance in certain operations. DDR3 adds bandwidth and a bit of oomph compared to DDR2, but a well setup DDR2/S775 Quad system will still be plenty powerful for most things. If you don't need to upgrade don't waste the cash. If you like upgrading, go for it
Ci7 990X::Rampage III Extreme::12GB Corsair Dominator 1866C7GT::2 x EVGA SC Titans in SLI::Corsair AX1200::TJ07::Watercooled
Ci7 920 3849B018::Rampage II Extreme::6GB GSKILL Trident 2000C9 BBSE::EVGA GTX580::Antec Signature SG850::TJ09::Aircooled w/TRUE 120X
Thanks guys, so it would be comparable to a what speed i7 4c/4t?
NXZT 340S
Storage:
Corsair AX1200i PSU
See how long it takes your chip to do a 1 or 32M pi run, then take a look on HWBot and browse the i7 920 rankings for the same PI runs, looking for the same time, and see what MHz they were running. It's not going to be an accurate representation of the MHz for MHz comparison, but good enough IMO
Gigabyte EX58A-UD3R F6 : i7 920 D0 4.4GHz 1.4v : 4Gb G.Skill ECO 6-8-6-24 1.54v
Apogee XT & MCW30 : XSPC Dual 750 w/DDC+18W : RX120 & RX240 : Tygon tubing : Corsair HX 850
2x750Gb 7200.12 RAID0 : 2x500Gb 7200.12 RAID1 : Samsung DVD-RW : LG BD-R
Antec P182 with 5 x Noctua NF-P12 & 1 x Akasa Apache
M-Audio Delta 1010 (Rack) : Behringer Truth B2031A
XFX 5770 + 8600GTS (physx) : 2x Samsung Syncmaster 710n
Lappy: Asus C90s & E7500 @3.17GHz w/ 4Gb RAM & top scoring 8600m GT DDR2
NXZT 340S
Storage:
Corsair AX1200i PSU
Ok well here is some help.
As far as single core power:
My QX9650 at 4 ghz did a 1M super pi run at about 11.7 seconds. And that's a bit on the high side since I was using low FSB (about 364). Most people, from what i recall, were able to break 10 second barrier somewhere over 4.5 ghz (maybe it took 4.7 ghz?) on Q9650's or E8400's.
For comparison, my 2600k @ 4 ghz does 1M in about 9.4 seconds, which may be about equal to a core 2 around 4.7 ghz. You can look for some core i7 4 ghz 1M scores for more reference.
Hope that helps some.
solely depend on application used.. If you encode x264 e.g. clock2clock the i7 (not SB..) has a ~40% advantage(likely due to HT), in cpu test vantage an i5-750, has ~10% advantage c2c, in many games, (like F1 2010, or COD Black Ops) you will see a nice boost.. in your minimum/average fps. comparing to an i5 750 would be like ~3600mhz i guess
What you are looking at is a CPU thats right below a QX9770 in clockspeed but also a 1333 Mhz FSB instead of the 1600 on the QX9770.
It's like comparing an overclocked Q9650 to an i7 920...
Just compare it to any 45nm Core 2 based quad at 4.1 Ghz and you will get a more accurate comparison than what others have suggested here.
Comparing different architectures with SuperPi doesnt work very well.
Smile
In terms of cpu power alone, 4.1Ghz is somewhere close to a 3.2-3.3 i7 Nehalem. But in terms of memory bandwith and memory latency there is no way lga775 can ever catch up with nehalem and imc.
--lapped Q9650 #L828A446 @ 4.608, 1.45V bios, 1.425V load.
-- NH-D14 2x Delta AFB1212SHE push/pull and 110 cfm fan -- Coollaboratory Liquid PRO
-- Gigabyte EP45-UD3P ( F10 ) - G.Skill 4x2Gb 9600 PI @ 1221 5-5-5-15, PL8, 2.1V
- GTX 480 ( 875/1750/928)
- HAF 932 - Antec TPQ 1200 -- Crucial C300 128Gb boot --
Primary Monitor - Samsung T260
