+ Reply to Thread
Page 1 of 2 1 2 LastLast
Results 1 to 25 of 34
Thread: ---Project BiXeon --- (SR-2 build)
    Xtreme Member arkadur's Avatar
    Dec 2008
    Jerusalem, Israel
    3
    Cool ---Project BiXeon --- (SR-2 build)
    Hi all,
    after my last project (Server of nod), with 3 WC loops
    this time i'm going on something bigger.
    my I7 950 \ GB UD3R is very nice - but i want (not sure about need) more!!!
    so, what we have?
    [ ] - not ordered yet
    [~] - on the way
    [V] - got it!
    [V] 2X Xeon 5620
    [~] EVGA SR-2 A1
    [V] 2X Corsair HX1000 PSU's (got 2 TX750, but i changed them)
    [ ] Corsair domminator 1600 6X2GB (i'm not think that GT's worth extra 100$)
    [V] Dell Perc5I raid controller 2Xsff4848
    [ ] 3X GTX 580 SLI
    [ ] MOUNTAIN MODS EXTENDED ASCENSION
    [V] 2X 74 GB raptors in raid 0
    [ ] 4X SSD's in raid 0 (Vertex 2 or C300 \ C400 )
    [ ] 8X 2TB HDD's for storage
    [ ] 2X ODD's
    water cooling list will be uploaded soon
    4KW!
    dual psu adpter
    TFC 360 that i already have...
    few pumps , but i'll use 355, and not the 655 or D5
    and, the anodized res, but i cant use them because of the are made from Alu, why... why the make them from Alu
    more updates - soon.
    thanks.
    EVGA SR-2 , 2X Intel Xeon 5620, 12X2GB Corsair Domminator 1600 MHZ CL7
    3X GTX580, Corsair AX1200, Lian Li PC-Z70
    3X Dell U2311H, Liliput 7" touchscreen monitor
    Mar 2010
    0
    Looking good
    Subscribed!!!
    Jun 2005
    Germany
    0
    Aquacomputer makes the reservoirs out alu, but there are some made of copper or delrin too.
    Xeon W3520 D0
    Gigabyte GA-EX58-UD5
    Powercolor HD 6950
    Areca 1680ix-16
    3x Vertex 60GB @ Raid 0
    5x 5900.12 1.5TB @ Raid 5
    X-Fi Xtreme Music
    Coolermaster UCP 700W
    EK Res 250 -> 2x DDC-1T w. XSPC Dual Top -> EK HD6970 -> EK Supreme HF Full Nickel -> MoRa3 (9x140)
    Xtreme Addict Vinas's Avatar
    Jan 2007
    Michigan
    38
    I predict that rig under heaviest load will pull about 900watt max... So, you're gonna need those 1000w working together to get some good efficiency.
    Core i7 860 / Apogee XT/960mm rads, 16GB G.Skill Ripjaw X, dual ATi 5870 EK fc [Cu] blocks & bk plates, Panworld PX-40 pump, PPC 1200w TurboCool, 2 INTEL x25m & 1 OCZ Agility III 240GB SSDs
    Intel 4.5GHz LinX Stable Club
    Dec 2008
    Jerusalem, Israel
    3
    hi all.
    i see that i cant edit my post to a poll.
    but - i want you to help me:
    which color theme will look better on this build?
    1. red \ black \ white and brass fitting?
    2. blue\ black \ white and brass fitting?
    3. blue \ orange or yellow \ brass fitting?
    any other combenation is welcome.
    Xtreme Addict tool_462's Avatar
    Mar 2008
    Minnesota
    0
    Please, no more red & black builds!
    i5 2500K @ 4.9GHz+ 8GB G-Skill RipJaws DDR3-2000 @1600Mhz CAS 6 Asus P8P67 Pro CrossFire 6970's @ 950/1450
    Xeon X5677 @ 4.5Ghz 6GB G-Skill RipJaws DDR3-2000 @1600Mhz CAS 7 Gigabyte EX58-UD5 4870x2
    i7-880 @ 4.2Ghz+ (still playing) 4GB G-Skill RipJaws DDR3-2000 @2300Mhz CAS 9 Asus Maximus III Formula MSI Hawk 5770
    Dec 2008
    Jerusalem, Israel
    3
    hi all
    i didnt chose the color theme yet,
    but - i got a update
    my board is here!
    my board came without the ECP V3, but probebly i'll get it soon
    the Xeon CPU's didnt come with cooler, so i bought the ac freezer 13,
    one of them - with a broken fan
    the HD4850 is so tiny
    i've changed the backplates, very simple and easy with t20 torx key
    sorry about the pics frames , i've no time right now..
    more updates will come soon.
    enjoy
    Dec 2008
    Jerusalem, Israel
    3
    i've a little update,
    i'll order my case next week finally, so my desk will be clean for my other work.
    one of my HX1000 PSU, needed a RMA, so i even trdae it to AX1200, defently better for me.
    and, i got from Frozen my fullcover block for my MB (hot item - just a 106$!)
    here a few pics:
    enjoy!
    Arkadur
    Xtreme Member xxh1tm4nxx's Avatar
    Aug 2009
    Islamabad, Pakistan
    0
    nice...any updates on this?
    Xtreme Addict Alexandr0s's Avatar
    Nov 2009
    Netherlands
    53
    Wow, can't believe I missed this ! That's a lot of epic hardware :O!
    “Little expense had been spared to create the impression that no expense had been spared.” - Hitchhiker's Guide
    It's better to ask dumb questions now, than to look stupid later
    Mondays:
    Nanoseconds from Permaban [XC] Oj101's Avatar
    Jan 2006
    South Africa
    267
    Blue/black/white/brass
    Aren't you going to water cool the CPUs? I think you should to do the build justice
    Sub'd for being so incredibly over the top
    Xtreme SUPERCOMPUTER
    Nov 1 - Nov 8 Join Now!
    Quote Originally Posted by Jowy Atreides View Post
    Intel is about to get athlon'd
    Athlon64 3700+ KACAE 0605APAW @ 3455MHz 314x11 1.92v/Vapochill || Core 2 Duo E8500 Q807 @ 6060MHz 638x9.5 1.95v LN2 @ -120'c || Athlon64 FX-55 CABCE 0516WPMW @ 3916MHz 261x15 1.802v/LN2 @ -40c || DFI LP UT CFX3200-DR || DFI LP UT NF4 SLI-DR || DFI LP UT NF4 Ultra D || Sapphire X1950XT || 2x256MB Kingston HyperX BH-5 @ 290MHz 2-2-2-5 3.94v || 2x256MB G.Skill TCCD @ 350MHz 3-4-4-8 3.1v || 2x256MB Kingston HyperX BH-5 @ 294MHz 2-2-2-5 3.94v
    Dec 2008
    Jerusalem, Israel
    3
    hey all
    probebly i'll order the MM EX-ascension case today.
    i've order the MB TRAY only from them - but finally i dont have much time to build my own custom case.
    all parts will be water cooled.
    CPU - EK HF nickel / plexi top
    GPU - EK FC-580 nickel / plexi top
    i'll update you guys later.
    Xtreme Member fatherTime27's Avatar
    Jan 2010
    0
    I cannot put into words how jealous I am
    Internal Watercooling Antec 900 Build Log*
    WC loop: Black ice extreme 240 radiator, XSPC 120 radiator, HK 3.0, D5 pump with Bitspower top, DD fillport, Primochill tubing, distilled + ptnuke
    Pink Floyd is #1
    Xtreme Addict ScottALot's Avatar
    Feb 2010
    Wisconsin
    2
    Yaaay the EK SR-2 duck-looking waterblock!
    Signatures make my posts look huge... but I'm not humble enough to completely remove my signature, so I kept this note explaining it.
    Dec 2008
    Jerusalem, Israel
    3
    there is a little update. i know that log going slowly. but that better then nothing.
    i've ordered the HPTX tray from MM,
    for my custom case build.
    it seems that the production cost will be more then i thougt. (CNC & waterjet)
    so, i'll return to the MM EX-Ascention case. it's the best value for my money.
    first stage - get the case, and other hardwere. (GPUs, HDDs)
    second stage - get 3 Dell u2311 for the multi display.
    thired stage - WC it all
    this is the first GPU, more to come soon.
    MM tray & bundle
    bench table for a while. i need the other case parts.
    vantage - all stock.
    and, after some twikes, 4GHZ on air. cant wait for the LC.
    Nov 2009
    Netherlands
    53
    Nice job, looks great . Can't wait to see you liquid cool this baby !
    Mondays:
    I am Xtreme theseeker's Avatar
    Mar 2007
    Sugar Land, TX
    5
    Looking forward to your comments regarding the MB. I really want one but I have not had much positive feedback.
  18. #18
    Xtreme Mentor =[PULSAR]='s Avatar
    Apr 2004
    CT, USA!!!
    2
    Can't wait to see the finished product My SR-2 is finally going in a case the MM Pinnacle 24 and Pedestal arrived this evening, WC power with 2x Thermochill 120.4's
  19. #19
    Dec 2008
    Jerusalem, Israel
    3
    thanks for the comments !
    the pinnacle is nice - but is too small .
    i'm going on 2X RX360 for the CPUs.
    2X TFC360 for the GPUs
    1X RX360 for the raid controller + MB + RAM
    i need the space for the HDD farm.
  20. #20
    Registered User acutech's Avatar
    Mar 2011
    Mirabel, Quebec, Canada
    0
    Amazing build arkadur, can't wait to see more!
  21. #21
    Dec 2008
    Jerusalem, Israel
    3
    Hello my friends !
    after long time without updated, the project continuous,
    the big issue was the case for this build, i really wanted a MM cube, but that was too expensive, i tried some pre owned cases, but the final price was not cheap too.
    now. i've see this baby on Frozen :
    the new Lian Li PC-Z70
    http://www.lian-li.com/v2/en/product..._index=138&g=f
    now, i'm going on dual PSU inside, and, i'll build external box or stand for the rads.
    what do you think?
  22. #22
    Oct 2007
    New Zealand
    1
    i think its doable, the loop going to be in single though
    dual 360 rads on lianli A05NB worklog : http://www.xtremesystems.org/forums/...d.php?t=259066
  23. #23
    Registered User Havokator's Avatar
    Sep 2002
    0
    def a tight fit
    Corsair Obsidian 650D
    Intel i5 2500K - 4.5 GHz
    Asus P8P67 Pro B3
    G.Skill Ripjaws 2x4GB 1600Mhz 9-9-9-24
    Asus GTX460 768mb
    Prolimatech Megahalems Rev.B
    Crucial C300 64GB SATAIII
    Samsung Spinpoint F4 2TB x 2 RAID-1
    Cooler Master Silent Pro Gold 800W
    Samsung SyncMaster 24'' LCD 2494LW
  24. #24
    Dec 2008
    Jerusalem, Israel
    3
    hello,
    after a long time with no update, this project came from the death.
    until now, i've worked with my lian li PC-Z70, that done great work on air.
    then, with a small update, i replaced the DELL PERC5I raid controller with other GTX580 (Zotac), both now reference design.
    in the past time, i got some extra HDD's, extra DOMM's, new monitors, new house and new wife
    workstation
    befor:
    after:
    in connection with the case issue.
    i've tried to get used MM case, but got nothing.
    a new one - is too expensive right now,
    so, i got simple sketch - let me know what do you think:
    1. you can see the lian li PSU brackets
    2. i know that the GPU's are 560 (cant find any 580)
    3. this is not finished yet. still need to make a choice of the rad positions (2XTFC360+1XTFC240+2XMCR240+1XBLACE ICE 360+ HWLABS X FLOW 240)
    4. cube size is 50WX50DX70H CM, maybe turned to 60CM D.
    5. i already got the MM HPTX MB Tray.
    arkadur.
  25. #25
    Dec 2008
    Jerusalem, Israel
    3
    OK, i was sleeping for a while with this project,
    but now, the dream come true,
    more to come - soon
+ Reply to Thread
