+ Reply to Thread
Results 1 to 12 of 12
Thread: Is USB 3.0 bootable?
    Xtreme Member cab's Avatar
    Jul 2010
    EU, USA
    0
    Is it possible to boot OS from a USB3 flash drive?
    Are there any USB3 card readers?
    I am Xtreme lowfat's Avatar
    Oct 2005
    Grande Prairie, AB, CAN
    17
    AFAIK the NES/Renesas controllers can not be booted from. Even if you plug a USB2.0 device in to a USB3.0 port it will not work.
    Xtreme Addict mattkosem's Avatar
    Jul 2008
    US
    3
    I've got an Adata usb3.0 drive. I can boot from it without issues on usb2.0 ports. None of the mobos I have will see it at boot time on their usb3.0 controllers though. I believe they're all NEC, so avoid those.
    --Matt
    My Rig :
    Core i5 3570k - MSI Z77MA-G45 - 8GB G.SKILL Flare DDR3-2000 - 4xC300 64GB R0
    Jul 2010
    EU, USA
    0
    There a some new mobos/chipsets both from Intel & AMD -- Are any of them capable of BIOS-booting USB3 flash drives ????
    If so, can we compile here a list of such mobos? Is the GIGABYTE GA-Z77X-UD3H one of them?
    Oct 2005
    17
    All P67 or newer board should be able to boot from USB3.0 from my experience. At least all of mine have been able.
    Xtreme Addict NEOAethyr's Avatar
    Sep 2010
    US, MI (Muskegon)
    16
    My chiv can boot and install from usb3 ports.
    If you install win7 with it, it does so in usb 2 mode.
    If you install win8 with it, I assume it does so in usb3 mode.
    It's not like a raid thing, where you can boot off from it, but windows flips out sorta thing.
    It'll boot, and install all the way through with no probs.
    CPU: AMD Phenom 1090T
    CPU Heatsink: NZXT Kraken X60
    Mobo: ASUS Crosshair IV Formula (2101 BIOS)
    MEM: 2x 4gig ADATA XPG Gaming Series v2.0 [AX3U2000GC4G9B-DG2] (Hynix H9C-BFR)
    PSU: Seasonic X-750
    VGA: nVidia Grid VGX K2 (Only got 1 out of the 2 gpu's at the moment)
    Monitor: ASUS VG278HE & 3DVision2 Kit
    Drives: 2x WD Green 1TB Modified Drives (RAID 0), Corsair Force Series 3 CSSD-F60GB3A-BK 60GB SATA3 SSD, Pioneer BDR-2208 Blue Ray Burner
    Case: Rosewill Blackhawk Ultra
    OS's: Windows 2003 Enterprise x86 SP2-R2 VLM, Windows 7 Standard Embedded x86 SP1 EVL (128GB Patched)
    Mouse: Razer Abyssus (I smashed this because of a usb comflict, still have the prob though afterwards ..., using generic mouse for now)
    777
    Just ordered an Samsung Galaxy S IV i9500 Octo-Core Quad Band 16gb Unlocked.
    Should be getting the screen protector anyday now.
    Also got 64gig micro sd card but it turned out it's a bad card, rma'ing.
    Oct 2005
    17
    Quote Originally Posted by NEOAethyr View Post
    Not nessessarily. I can not install Windows 7 via a USB3.0 port unless I slipstream USB3.0 drivers.
    Sep 2010
    US, MI (Muskegon)
    16
    I can..., done it a few times.
    But then again I am using a usb 2.0 stick in the usb 3.0 port...
    Another odd thing is you can use the usb3 port in win7 without installing drivers for it.
    It'll be in usb2.0 mode though.
    PSU: Seasonic X-750
    777
    Jul 2010
    EU, USA
    0
    Quote Originally Posted by lowfat View Post
    They can boot an OS from a USB3 flash drive at 300MB/sec?
    Xtremely Hot Sauce Bobsama's Avatar
    Sep 2007
    New York
    10
    Not always. My Asus Sabertooth X58's USB 3.0 ports were useless without drivers--no legacy mode available.
    My toys:
    Asus Sabertooth X58 | Core i7-950 (D0) | CM Hyper 212+ | G.Skill Sniper LV 12GB DDR3-1600 CL9 | GeForce GTX 670-2048MB | OCZ Agility 4 512GB, WD Raptor 150GB x 3 (RAID0), WD Black 1TB x 2 (RAID0) | XFX 650W CAH9 | Lian-Li PC-9F | Win 7 Pro x86-64
    Gigabyte EX58-UD3R | Core i7-920 (D0) | Stock HSF | G.Skill Sniper LV 4GB DDR3-1600 CL9 | Radeon HD 2600 Pro 512MB | WD Caviar 80GB IDE, 4TB x 2 (RAID5) | Corsair TX750 | XClio 188AF | Win 7 Pro x86-64
    Dell Dimension 8400 | Pentium 4 530 HT (E0) | Stock HSF | 1.5GB DDR2-400 CL3 | GeForce 8800 GT 256MB | WD Caviar 160GB SATA | Stock PSU | (Broken) Stock Case | Win Vista HP x86
    Little Dot DAC_I | Little Dot MK IV | Beyerdynamic DT-880 Premium (600 Ω) | TEAC AG-H300 MkIII | Polk Audio Monitor 5 Series 2's
    Oct 2005
    17
    Quote Originally Posted by cab View Post
    No idea. I was referring to installing Windows 7 from a USB3.0 flash drive.
    Jul 2010
    EU, USA
    0
    I can confirm Gigabyte Z77X-UD5H booted my USB2 flash drive from USB3 port. And I see that Panasonic has a new UHS-compliant USB 3.0 Reader, so now all we're missing are some screaming fast SD cards... yeah?
    Now I'm curious if any of the new mobos with AMD 990FX will boot form USB3.
+ Reply to Thread
