How are you guys keeping your chilled setups at desired temperatures? Obviously some of you want the coldest temperature possible so you let the compressor run continuously.
Is there some sort of off the shelf way to control temperature? I believe my window A/C unit uses a basic resistance type thermometer. It's designed to only go to 60 deg F, so obviously it won't work for sub-zero temps. Besides trial and error super insulating the thermometer, how could I control the compressor for desired temps based off of the reservoir liquid temps?
