This 5770 is in my HTPC. So its a tight fit. From the center of the gpu I have about 3.25" to the top of the case. From the back of the card the gpu sits about 3.25" in. I have rougly about 1" of clearance from the top of the pcb of the card to the top of the case. Length to the front of the case is not really a factor as I have installed a 4870x2 in this case just to see if would fit.
The biggest issue Im finding with these coolers is they are too tall and finding good dimensions on these is a pita. Ive looked at the Scythe Setsugen 1 or 2, and the Musashi. Another option is a Zalman VF3000 or maybe a Thermalright T-Rad. I want to stay away from anything like the Arctic Cooling coolers as you pretty much only use the fans they come with, or you make modifications to make them fit.
I think the Setsugens are out because they both use 120mm fans which is going to make them too tall. The Musashi might work, but Im wondering about the length of the cooler from the center of the GPU to the back of the card and do I have enough room.
Im not looking to overclock. I just want to keep the GPU cool, and quiet. Nothing worse than a bunch of fans humming while Im watching a movie.
Anyone have a good source of dimensions for these coolers? Or any other suggestions?
q9550 @ 444 x 8.5 1.3v w Venomous X
Awesome cooler though, 4850 at 1.4v+, 800 core, furmark under 65c.
