And here is a quick informal bench noise test of the 452 series. I controlled voltage on the PMP-450S to match that of the PMP-450 and simulate dual PMP-450 pumps. Very short video, showing one pump vs two pumps vs GT15 fan vs combined.
http://www.youtube.com/watch?v=rI1Eh3LTszU
Approximate results chart:
Very minor differences at this ambient noise level and hard to perceive. The video does a pretty good job of giving you the sound quality differences though. Overall, the GT15 fan was a bit more noticeable than one or two pumps. With all together it was really hard to tell the difference between one or two pumps running. I would recommend the RP-452x2 with PMP-450 pumps for those very sensitive to noise, as it provides you easy flexibility in obtaining lower noise levels if desired. You could also run both pumps in series at half the speed. Lots of options here..
I think that pretty well completes the performance to do list for now, let me know if you want to see something else performance wise. I'll work on getting some taken apart type pictures and doing some other pump tests..
Cheers!
Martin
