http://cgi.ebay.co.uk/Danfoss-Elimat...item2eb2ebbcca
It's a for 16/18cc 1HP 12,000 BTU rotary comp simple single stage.
I presume it's an okay one to use?
Is there a set size we should use or type?
No problem with different types of gases
Thats Bidirectional so used for heat pumps,also know as reverse cycle. below are all the specs. But ok to use,depending on what type of oil you use. The HC refrigerant shouldn't hurt it. R290 & mineral oil .
Optimized for CFC and HCFC refrigerants and mineral or alkyl benzene oils. 80% 3Å Molecular Sieve with 20% activated alumina. Temperature range: -40°C - +70°C. Max. working pressure: 42 bar
Value
Type DCB 304
Weight 1.556 Kg
Acid capacity [g] 3,16 g
Acid capacity [oz] 0,112 oz
Approval UL
Connection material STEEL
Core size 30 cu.in.
EAN number 5702428158527
Felt mat/hole design 0
Inlet 1 connection size [in] 1/2 IN
Inlet connection size [in] 1/2 IN
Inlet connection size [mm] 12 MM
Inlet connection type Flare
Max. Working Pressure ef 46,0 bar
Max. Working Pressure 667 psig
Net volume [fluid oz] 10,89 foz US
Net volume [l] 0,322 l
Outlet 1 connection size [in] 1/2 IN
Outlet connection size [in] 1/2 IN
Outlet connection size [mm] 12,0 mm
Outlet connection type Flare
Pack format Multi pack
Product description Biflow filter drier
Refrigerant(s) HCFC
Refrigerant(s) HFC
Shell volume [foz US] 16,57 foz US
Shell volume [l] 0,49 l
Solid core surface [cm2] 250 cm2
Solid core volume [cm3] 365 cm3
Solid core surface [in2] 38,75 in2
Solid core volume [in3] 22,27 in3
Temperature range [°C] -40 - 70 °C
Temperature range [°F] -40 - 160 °F
Type designation DCB 304
The Laws of Thermodynamics say:
Zeroth Law: "You must play the game."
First Law: "You can't win."
Second Law: "You can't break even."
Third Law: "You can't quit the game."
Do you wanna Play Thermodynamics ????????I forgot "you must"
