Will the copper fins attached to the Aluminum cause corrosion.
No. Aluminum tubes with a copper block will.
All stock for now, no need for more, but it's gonna be soon methinks.
Giga Xtreme 58 mobo i7 965 ES D0 step Corsair 1600 6 gig
SLI GTX470 EVGA
EK HF nickle blue top CPU block (free from Eddie)
Koolance 470 waterblocks
One big loop, two 120x3 rads. Pa 120.3 and XSPC RX 120x3. Swiftech 35x pump with V2 restop. GT AP15 fans.
Banchetto Tech Station
120 GB SSD, and a few other drives.
1000W UltraX3 PSU, 900 watt (1500VA UPS
23.999" Acer GD235hz and 24" Acer H243H
I've seen many a copper rad with aluminum fins, but never an aluminum rad with copper fins. What brand is it?
At Xtremesystems.org we don't help you save money on your cooling gear, instead we try to make you feel better about the insane ammount you've spent.
Stay away from it, find something that high quality copper/brass
I wouldnt recommend it, stay away from Aluminium...
Another thing I find funny is AMD/Intel would snipe any of our Moms on a grocery run if it meant good quarterly results, and you are forever whining about what feser did?
Corrosion is an issue when you put metals like copper and aluminum in a loop together that are physically touching the water. If you buy any of the made-for-PC rads these days, you will find that the tubes and end tanks in the rads do not have aluminum, but are made of copper/brass. It doesn't matter what material the fins are as far as corrosion is concerned since the fins do not come in contact with the water.
Latest Project Log: Project Quintessence
1935 Zenith Radio Scratch Build
