Page 2 of 3 FirstFirst 123 LastLast
Results 26 to 50 of 70
Thread: Cm-haf-xl
  1. #26
    Xtreme Guru
    Dec 2009
    Latvia, Riga
    There was another recent build here with nice idea that can be reused - to use similar plate for waterpaths to make tubing more neat. But otherwise i wouldn't go for such. Looks are superb & top notch, but there are lot of small electronic details on motherboard that might cool worse with all air-flow covered to them.
  2. #27
    Aug 2010
    netherlands
    Quote Originally Posted by matt220 View Post
    Simply awesome.
    Personally though, I think you should go with the black bitspower rotary fittings instead of the sliver, the mix just doesn't clash well in my eyes.
    Other than that bravo
    Thnx,
    The fittings gonna be exchange, the silver fittings are just to get everything in place
    Quote Originally Posted by churchy View Post
    Thnx,
    I'm gonna make something for the airflow, underneath the acryl
  3. #28
    Aug 2010
    netherlands
    Update: Midplate & Noise reduction
    Last days did some thinking about the hdd/ssd bays. used for this the original Haf bay, cut it in 2 pieces
    One for the ssd's and one for the hdd's
    Bay 1 for the ssd
    Bay 2 for the hdd
    Hmmm my new friend, Mr. Gorillatorch, helped me a lot lately with my build
    Again bay 2
    Gonna place them like this
    Bay 2 installed
    And bay 1 beneed the slimeline dvd drive.
    Have made a bay for the slimline dvd-rw
    fits perfectly
    just about this, need to do some little things to it, to make it look better, but for now.....
    Cut out a piece for the dvd
    Fits also
    The opening for the power cable to my gpu's
    For the noise reduction i used some isolation tape
    And grind a piece of my ceiling plate
    Vry nice piece i think
    This is all beeing covered with a midplate 5mm black acryl
    like this
    Replaced the original rivets for countersunk rivets.
    The original rivet
    countersunk rivets with tape for protection
    Whole back is finished for another idea
    For this update i wanna thank Mr. Sammie from cK-leds
    He has given my some very nice led strips
    Green silicone strips
    Green Smd strips
    Uv purple Smd strips
    And he's given my a nice suprice..... a nice RGB strip
    Not gonna use them in this mod, but maybe the next one to come
    also did some nice things with my pumps. Sawn 4 pieces of acryl.
    2 x uv green acryl 5mm
    And 2 x Black acryl 5mm
    Need to polish them
    Sawn the green acryl one more time with 4 feet instead of 2
    black acryl under the pump
    my 2 pumps ready to go
    Looks nice i think on my black midplate. and placed a single led in it
    Placed in the Haf with the led
    And some pics in the dark
    Thats it for today
    Grtzzz.
  4. #29
    Xtreme Guru
    Jun 2010
    In the Land down -under-
    some craftmen skills you have there! loving the dvdrom
    Another thing I find funny is AMD/Intel would snipe any of our Moms on a grocery run if it meant good quarterly results, and you are forever whining about what feser did?
  5. #30
    Aug 2010
    netherlands
    Update
    I've frosted the uotside from the acryl, and put some led strips around the motherboard
    Placed the cover, still need to get the strips right
    But it's a nice effect already
    Have some disappointment about the solid tubes
    "Old" Tube
    "new" Tube
    doesnt fit anymore in the Bitspower fittings, so need to change plans. So i put the new solid tube in the Tygon tube
    Have tested it first, and looked really nice
    So did some sawning and fitting, and here,s the result
    Everything almost straight
    Have to exchange some silver for black fittings
    Lights out please.......nice, but need to buy some extenders for a straight line
    But the most lines are straight
    Total shot
    Pump 1 plugged in, only pump 2 now
    Reservoirs also nice with the green light
    Next step, buying BP black fittings and the acid green fluid
    So did some shopping by Highflow.nl
    Black and silver again for a new idea
    And i bought 6 BP zilveren L-Rotery,s second hand for a really good price
    For the link between the cpu and the motherboard i used silver fittings andextenders, this looks really good woth the nickel blocks from the gpu
    still need to put a small link between the cpu and the NB
    Did some cable managment, looks messy, but first things first
    The inside is better looking
    Mdpc sleeving always nice
    And the cpu power, 4 x 4 blocks
    a good friend have helped me with my slotloader dvd-rw
    He was really fast with putting this together again......... respect
    2 wires soldered on it, and tested it
    looks really nice, i think
    My reset button is now the eject button for the slotloader on the aquaero
    Mr. wwwicked thanks a lot, i owe you one
    Some stuff from my favorite shop HighFlow Computer Cooling Shop - Uw shop voor PC waterkoeling, luchtkoeling, modding, behuizingen en gaming!
    I,ve seen this fluid by the L3p desk, what looks really good
    Feser One Cooling Fluid - UV ACID GREEN
    Black extenders, have bought a lot of these
    Bitspower G1/4 Matt Black IG1/4 Extender BP-MBWTP-C40
    A rally nice rotery
    Bitspower G1/4 Matt Black Dual Rotary 90 Degree IG1/4 Adapter BP-MB90R2
    And more rotery's
    Bitspower Matt Black fittings
    And some shiny silverware
    Bitspower Silver Shiny Fittings
    I had to extend my Aquaero from the dispaly.
    Power on, and works fine
    And placed all the new fittings
    straight behind the powercables
    New black rotery's on the EK bridge
    And the pumps connected
    1 tube underneed the radiator bay
    The only thing now is to connect everything togheter and do some more wiring
    But have space enough for this.
    I hope to put the acid green fluid this weekend in, and show you some pics of this
    Grtzzz.
  6. #31
    Dec 2008
    Jerusalem, Israel
    i like the idea of green theme for the EVGA Classi board.
    but, i didnt make a choice myself about my sr-2 build.
    nice work with the tubing! keep it up!
    [SIGPIC][/SIGPIC]
    EVGA SR-2 , 2X Intel Xeon 5620, 12X2GB Corsair Domminator 1600 MHZ CL7
    3X GTX580, Corsair AX1200, Lian Li PC-Z70
    3X Dell U2311H, Liliput 7" touchscreen monitor
  7. #32
    Apr 2008
    Seattle
    My god man, i'm blown away by this work, looks amazing.
    Current Worklog: vDarkness Previous Projects: X360:V1 * X360:V2
  8. #33
    Xtreme Guru
    Jun 2010
    wow sex on water! Are you actually using those 6x bp rotarys??
  9. #34
    Aug 2010
    netherlands
    Update: filled it up and cables
    Did al the wirring voor the aquaero
    And some updates for the firmware and software for the aquaero
    The 140mm fan works fine.
    The other fans also
    filling loop 1. No problems
    Tubes on top
    straight to the pump
    The fan is really coming out nice with the uv light
    Because there is a solid tube inside the Tygon tube, there's a lot of air inside
    Uv strips are really nice , and a good effect
    Uv acryl is very nice also
    and filled loop 2
    Beautiful pomps i think
    Looks good with the green acryl under need the ppumps
    And a total shot
    Grtzzz.
  10. #35
    Jan 2008
    Athens -> Hellas
    Awesome...love the black sticker on the green plexi...lets only the right amount of UV-plexi to be seen...
  11. #36
    Jan 2008
    Bonnie Scotland / Sunny England
    Absolutely stunning! Taken my breath away!!!
    ~Bex
    PROJECT :: The Xtreme (WET) Dream!!!
    PERSONAL H2O BESTS :
    E8600 @ 4.8GHz
    E6750 @ 4GHz QX9650 @ 4.6GHz
    i7 920 @ 4.6GHz
    PERSONAL AIR BESTS :
    Sempron140 @ 4Ghz (Stock Cooler)
    i7 3960x @ 5.4ghz (Air Cooler)
    Bex : "Who said girls can't play PC games or overclock!? Do I look like your imagination!?"
    Aaron : "TBH, a girl doing all that is a pretty perfect girl!"
    Swift_Wraith : "could someone please check bex for a penis?"
  12. #37
    Xtreme Member Elusid's Avatar
    Sep 2007
    Colorado
    I love how you covered the mobo! It ties the whole case together and gives it a nice flow. I'm not to thrilled with the motherboard color in my build so I think I might use that same idea. Amazing build so far! Subbd*
    Current Build: Virtual Cosmos
    Cosmos II | Aquaero 6 XT | SuperNova 1000 T2 | EK-CoolStream SE 360, XE 240, CE 140, WE 180
  13. #38
    Apr 2007
    U of M
    Stunning build, Kier! One question for you though. Do you know where one could source the glowpads that you used in your build?
  14. #39
    barfastic
    Guest
    BRILLIANT job kier!
    VERY WELL DONE!
  15. #40
    Aug 2010
    netherlands
    Thnx y'all for the nice respons
    Quote Originally Posted by Sgrios View Post
    You can send an email to Recom.nl. the can help you with the glowpads.
    I have searched the net for the glowpads, but couldnt find them anywhere
    so i,ve had send recom an email, and there respons was to order them straight by Recom
    good luck
  16. #41
    Aug 2010
    netherlands
    Update:
    Hi there, like promised pics by daylight
    Was a lot of pushing and pulling
    For the airflow behind the acryl and the motherboard i have placed some nice small fans
    witch blow air up
    They blow air against a small metal stripe, and bend the flow down, behind the acryl
    Works perfectly
    And i have placed some green strips for the frontbay
    everything placed in order
    Have sawn small pieces of green 3mm acryl
    think it looks nice with the black top
    But need to frost it some more
    Cover the behind also
    Gonna think it over some more
    And last but not least, the side panel
    Sawning time
    Used a 5mm green acryl again
    Need to be shappen some more
    And placed it back
    Looks fine with uv led strips
    But needs to be placed it in the right direction
    After this i did some thinking, and think it's a shame that the gpu's are not fully in sight
    So did some sawning again.
    Better like this, i think. The idea is to use the green acryl piece i've made, to place it in the other side panel
    so, to be continued
    Greetings
  17. #42
    Sep 2007
    Colorado
    Looking awesome! I think it was a wise choice to nix the green piece over the GPUs. Looks much cleaner without it there.
  18. #43
    Xtreme Guru
    Jun 2010
    looks insanely nice!!
  19. #44
    Jun 2009
    Toronto, Canada
    This build is SICK!!! Good job man i relay love your work.
  20. #45
    Aug 2010
    netherlands
    Update
    Hello everybody,
    the other side of the case,(other sidepanel) did some sawning and grinding
    It took some time, but almost finished
    Have used the green acryl from the other side, never throw something away
    Recycling again
    Need to shappen the slots some more
    And did some more small things. Maked the cover for the display again, but now with aluminium
    Better then the 3mm black acryl
    some more grinding and sawning
    put the grey display in
    only paint the cover again and it's finished
    Have used the same black aluminium for the sli cover
    Mdpc bolts in it
    nothing more for this cover, think it's finished like this
    Also did the final placing for the led strips
    Placed with the uv strips a green stripe, just to remove the purple color
    Looks nice on the mesh panel
    Lines on the motherboard cover are very good visible now
    Need to shappen the cables some more, but almost there
    Thats it folks, see you next time
    grtzz.
  21. #46
    Feb 2010
    UW - Madison
    What if you painted the Dominator fins in alternating between no paint and neon green?
    Signatures make my posts look huge... but I'm not humble enough to completely remove my signature, so I kept this note explaining it.
  22. #47
    Xtreme Guru
    Jun 2010
    1 word, godly!
  23. #48
    Jan 2009
    Huyamba
    i7 950@4.05Ghz HeatKiller 3.0
    EVGA E762 EK WB | 12Gb OCZ3X1600LV6GK
    Razer Tarantula |Razer Imperator | SB X-Fi PCIe
    480GTX Tri SLi EK WBs | HAF X | Corsair AX1200
    ____________________________________________
    Loop1: Double_MCP655(EK Dual Top) - MoRa3Pro_4x180 - HK3.0 - EKFB_E762
    Loop2: Koolance_MCP655(EK Top) - HWLabsSR1_360 - EK_FC480GTX(3x)
  24. #49
    Aug 2010
    netherlands
    Update: Up and running!!!
    Before i will show you the final pics, some more modding
    To turn the lights on and off i'am gonna use a multiswitch
    Made a cover for this
    Multiswitch Behind
    And the location where it's gonna be
    CM-HAF-XL is now up and running. So here some final pics for you guys
    Only need to put a piece acryl in the side panel, but it's delayed, and not really important for the pics
    Pics by night coming up, dont want to bore you with to much pics
    Grtzzz.
  25. #50
    May 2007
    New York City
    LOVE your clean straight tubing!
    amazing log!
    "The ultimate measure of a man is not where he stands in moments of comfort and convenience, but where he stands in times challenge and controversy."
    Dr. Martin Luther King Jr.
    DIY: Self Clinching Nuts
    Canon EOS 7D | Tokina 12-24mm f/4 | Canon EF 24-105 f/4 L | Canon EF 70-200 f/2.8 L IS Mk II | Canon EF 35mm f/1.4 L | Canon EF 400mm f/5.6 L | Canon EF 100-400mm f/4-5.6 L
