Page 1 of 2 12 LastLast
Results 1 to 25 of 31
Thread: 4870x2 still decent? or very outdated?
    Mar 2010
    I got some extra 4870x2's laying around. How outdated are these? Can 2 outperform 1 gtx580? Hope so!
    Dec 2010
    Nor*cal
    Yes, though more recent catalyst drivers have been outright ignoring HD4800 cards, much less HD4800 quadfire setups!!
    Mar 2010
    can you recommend a good driver for these?
    Xtreme 3D Team
    Jan 2009
    Ohio
    Quote Originally Posted by Gamb311 View Post
    Hmm...a lot of the drivers were sticking the second core in 2D mode even during 3D resulting in performance only 20-30% better than a 4870.
    I think it's fixed in the recent drivers though.
    Smile
    Jun 2008
    Im in a similar situation with my 4870X2. I have no games that use DX11. So in order to see a real performance I would need to get at least a 5870 or better.
    It boils down to how much do you feel you need? Myself, the old X2 is still doing fine by me, even though the rest of my system is pretty much brand new in the last 6 months.
    Apr 2006
    Hong Kong
    Good drivers for 4870x2 are 10.8 before they started breaking the second core jumping to 3D.
    "Language cuts the grooves in which our thoughts must move" | Frank Herbert, The Santaroga Barrier
    2600K | GTX 580 SLI | Asus MIV Gene-Z | 16GB @ 1600 | Silverstone Strider 1200W Gold | Crucial C300 64 | Crucial M4 64 | Intel X25-M 160 G2 | OCZ Vertex 60 | Hitachi 2TB | WD 320
    Feb 2003
    Greece
    10.4 hotfix and 10.5 are the top drivers for 4870X2. If you want newer 10.12 is the 3rd best driver for me.
    i7 920 3922A436 W/C HEATKILLER | DFI LP UT X58-T3EH8 W/C Swiftech MCW30 | Corsair 6GB DDR3-1600 Ram Kit (3 x 2GB, PC2 12800, 7-7-7-20, TR3X6G1600C7) | Sapphire HD4870 X2 W/C (EK) | PC P&C 750 Quad Cf |1 x Intel Postville 80GB SSD | 2 x Raptor 36Gb Raid0 | 2 x Seagate 500Gb Raid0 | 2TB Western MYBOOK STUDIO EDITION II Raid0 | PHILIPS 42PFL8404H | WIN 7 Ultimate x64 | CoolerMaster CM Stacker | ThermoChill PA120.3, Swiftech MCP 355 with XSPC v3 top
    Xtreme Guru
    Aug 2003
    Athens, Greece
    4870X2 are pretty descent cards. Without descent support from AMD though...
    Project ZEUS II
    Asus Rampage II Extreme
    Intel I7 920 D0 3930A @ 4.50GHz (21 X 214mhz)
    3 x 2GB G.Skill Trident 1600 @ 1716MHz (6-8-6-20-1N)
    2 x Asus HD 6870 CrossFire @ 1000/1100MHz
    OCZ Vertex 2 60GB | Intel X25-M 120GB | WD Velociraptor 150GB | Seagate FreeAgent XTreme 1.5TB esata
    Asus Xonar DX | Logitech Z-5500 | LG W2600HP 26" S-IPS LCD
    Watercooling setup:
    1st loop -> Radiator: 2 x ThermoChill PA120.3 | Pump: Laing DDC-3.25 with Alphacool HF 38 top | CPU: Swiftech Apogee XT | Chipset: Swiftech MCW-NBMAX | Tubing: Masterkleer 1/2" UV
    2nd loop -> Radiator: ThermoChill PA120.3 | Pump: Laing DDC-3.2 with Alphacool HF 38 top | GPU: 2 x EK FC-6870 | Tubing: Masterkleer 1/2" UV
    Assembled in Mountain Mods Ascension Trinity
    Powered by Corsair Professional Series Gold AX1200
    Aug 2010
    Illinois
    They are still alright. I checked the HWbot... single 4870x2 vantage is on par with a single 5850 and '06 is 3k point ahead of a single 5850. Still a good performer, but not running with the big dogs like they used to. :/
    Xtreme 3D Team
    Jan 2009
    Ohio
    Quote Originally Posted by ChanceCoats123 View Post
    Two 800 SP GPU's in crossfire on a single board
    Expect 5850 performance, since scaling isn't as good as a true 1600 SP chip like the 5870.
    Smile
    Jul 2007
    Alberta, Canada
    My experience with my old 4870x2 makes the gtx 480 look good. Be sure you have a very stable high quality psu, a well ventilated enclosure and a high tolerance for noise as those things suck power like its going out of style and they want you to hear about.
    When I rmad mine I replaced it with a 5870 and was much more impressed. All the performance of the x2 with half the power draw and a fraction of the noise output.
    All this said performance wise they are still half decent cards, they are just inefficient.
    As far as quad fire scaling on the hd4k series ( hell most series ) its quite poor and buggy.
    Feedanator 7.0
    CASE:R5|PSU:850G2|CPU:i7 6850K|MB:x99 Ultra|RAM:8x4 2666|GPU:980TI|SSD:BPX256/Evo500|SOUND:2i4/HS8
    LCD:XB271HU|OS:Win10|INPUT:G900/K70 |HS/F:H115i
    Jun 2007
    Bay Area
    performance still rocks. but other features make newer cards more appealing (heat/power/noise)
    1. INTEL E5200 M0 (200x12.5 @1.175), Abit IP-35Pro, 2x2GB DDR2-1000, GT240
    2. INTEL i7-920 C0 (200x19 @1.275), Gigabyte EX58-UD4P, 4x4GB DDR3-1333, GTX680 FTW+ 4GB
    heat
    Feb 2008
    Bulgaria
    Okay, this seems to be the appropriate thread for me.
    Before switching to DX11 (when there's something to switch to, of course) i'm trying to get the maximum out of my 4870x2.
    So, after playing around with the stock Sapphire BIOS i found out that 790/915 (which happens to be ASUS TOP stock values as well) is my wall. The logical step was ASUS TOP BIOS with 1.25v vcore. I did some testing and found out that 790/915 (no matter what vcore) is the maximum. Which is kinda disappointing. What is strange, actually, that past this values, the screen starts to freeze. No artifacts, blinking pixels, stretching polys, flickering or any kinda of visual problems. The screen just freeze and after that the PC lock-up and need hard restart. The most interesting part is that i can play some games without any problem (Like Trackmania Nations), other freeze without any noticeable regularity like BC2 - i can play for hours without a problem, next time i freeze after 5 minutes. The most strangest of all is Crysis 2 - freeze right after the level starts. No matter what.
    In order to figure out what's the problem, my first thought was that something is overheating. Okay, but GPU-Z wasn't showing anything wrong - all measured temperatures are just in order. Anyway, i tried with 200mm fan blowing directly into the card - still can't get past 790 core AND (separately) 915 mem. Because of this i'm starting to think, that the problem is rather software. I'm using 10.4a, which seems to be the most stable driver for me. Tried with and without catalyst - nothing.
    So, after the above said, i think i have some kinda of software problem, as i said. Anyone possibly have an idea or suggestion?
    Thanks in advance and sorry for the long post :R
    ASUS P5E Deluxe X48 | C2Q Q9550@testing[Fuzion v2+MCR320+MCP655] | G.Skill 4x2GB F2-8800CL5D-4GBPQ@testing | Sapphire 4870X2@ testing | 150GB WD VelociRaptor + 2xWD6400AAKS | Chieftec CFT-850-14C | Iiyama E2403WS | Razer DeathAdder | CM CosmosS Black
    c[_]
    Nov 2002
    Alberta, Canada
    my advice is lose the overclock on the card
    Heatware || 01.01.08; AND 111.2%
    Dead Z7S-WS? Click!. || XS Z7S-WS Thread || Current Dead Asus Z7S-WS count: 26+ ($15,000 in dead motherboards).
    All along the watchtower the watchmen watch the eternal return.
    Want to use my Anti-asus logo? Go ahead, but use this link please!: http://i853.photobucket.com/albums/a...sus/noasus.gif
    Bring back the game. http://reclaimyourgame.com/. EA are mean.
    Jan 2009
    Italia
    sell it and get a gtx 560/hd6950
    Mar 2005
    I bought the 4870x2 right after they came out. I don't have any use for multiple monitors I use one monitor at 1920x1200 and that is just fine for me. I am usually the first guy to upgrade anything, but I have been at a loss to do so since my 4870x2 plays everything smoothly on high settings. As for the noise comments, I took off the fan assembly and cleaned everything then re-assembled using AS5. My comment would be what noise? This thing idols in the 60c range and never goes above 90c with the fan set to 35%. I can barely hear it. The design does cause the front heat sink to clog with dirt which will make the fan spin up. I just clean it when that happens. Until there is a DX11 game I can't live without I am a happy camper with my 4870x2.
    AsRockP55, I7 860, Thermaltake 850 PS, Watercooled CPU, Windows7 SP1
    Aug 2006
    San Nicolas, Buenos Aires, Argentina.
    I have a 4870x2. Noise is unbearable, even after cleaning the 5H1T out of it, and replacing the TIM.
    What i did to get rid of the noise was loose the fan casing, and add a 120mm right on top of the card.
    I just got a U2711 and the card is struggling with newer games, so im thinking about getting a second one. Strong PSU is recommended tho.
    Gigabyte EX58-UD5 // Intel Core i7 920
    SuperTalent PC3-12800 3x2gb
    ATI 4870X2 2gb
    Samsung 1TBx6
    Coolermaster Silent Pro Gold 1000w
    Coolermaster Cosmos
    Dell u3014
  18. #18
    Mar 2005
    Quote Originally Posted by VIctorj View Post
    I too have experienced noise with this card but in a smaller case where things were crowded. I got into larger cases and found the 4870x2 fan was much less active with good airflow. I also had occasion to change motherboards and found that the layout can impact the airflow. All of which is to say that good airflow in the case keeps the fan from spinning up to overcome heat. Mine is a reference design so nothing special there.
  19. #19
    Mar 2008
    San Diego
    I have my 4870X2 with a 4870 in trifire.
    It runs a U3011 Dell in BFBC2 and works fine.
    I can't use any driver past 10.5 or I get CTD.
    I'm waiting till BF3 is about to come out before
    I get new cards. I have mine all watercooled so
    no issues at all with noise or temps.
    i7 970 4.0 Ghz 1.325v // Asus P6X58D Premium // Windows 7 Ultimate 64bit // 12gb Corsair Dominators // 2- GTX 580 Hydrocoppers in SLI// 2-OCZ Vertex 2 Raid//128Gb Corsair SSD (Temp Storage) // Custom Wall Mount Case // Corsair 1000W // SyncMaster 2433BW // Dual loops 2-laing 355's each with XSPC dual top // (UN) 3G Brackets & X-Brackets // Swiftech Apogee XT // 2 x 120.3 & 2 x 120.2 Swiftech Rads//
    Wall Mount Build Log: http://www.xtremesystems.org/forums/...d.php?t=242186
    MM Extended Ascension Build Log:http://www.xtremesystems.org/forums/...d.php?t=212236[/SIZE][/SIZE][/SIZE]
  20. #20
    Feb 2009
    Montreal
    Quote Originally Posted by armeniandave View Post
    I used to have that setup and swapped to a 5970 (everything watercooled too). I got fed up with buggy drivers but recently 11.2-11.3 seem to be getting better. Have you tried those?
  21. #21
    Apr 2005
    The 4870x2 will still play anything out there today with good framerates but damn its a HOT card! A 6950 or 6970 will be faster, draw less power, run cooler and won't rely on crossfire profiles. That being said, the 4870x2 is still an awesome card, way ahead of its time when it was released, most cards don't have that kind of relevant speed years after release.
  22. #22
    Jan 2009
    UK
    I moved from an ASUS 6950 with unlocked shaders to a PowerColor 4870x2 and damn.... The x2 is kicking out higher frames in pretty much every game!
    As for drivers the 11.2's are by far the best.
  23. #23
    Apr 2006
    Hong Kong
    Quote Originally Posted by almighty15 View Post
    Interesting.
    I loved my x2 but started getting bored so moved to 2 295's for some quad GPU action. Then decided I didn't like multi and went GTX 580.
  24. #24
    Jan 2009
    UK
    Quote Originally Posted by CedricFP View Post
    Interesting.
    It's a personal thing but I love my x2
  25. #25
    Apr 2006
    Hong Kong
    So did I. Was a great card for it's time and had a shelf life far longer than many other high end cards before it, though that will be by virtue of being dual-GPU with ever improving SLI/CF scaling.
