+ Reply to Thread
Results 1 to 2 of 2
Thread: I45 + q9550
    Jun 2006
    0
    I45 + q9550
    Hey everyone
    I have a slight problem iv got my system stable at 4ghz on my i45 mobo
    but i noticed the temps of 2 cores was diffrent and it turns out that 2 of the core are running at 2.83ghz, has anyone had this problem before?
    i first seen this on Tmonitor and then tryed HWinfo32 and that showed the same, could this be a bios problem?
    specs..
    biostar I45
    Q9550
    2x 2gb corsair 8500
    8.5x multi
    471fsb
    1.4vcore
    NO CE1 or TM1 enabled i checked this meny times
    PS is there a program i can test each core for the proformance? to see if 2 cores are running at 2.83ghz?
    thanks
    Jun 2006
    0
    Anyone have any thoughts what it might be?
    it seems that the 2 cores that are at 2.83 ghz are stuck on 6 multi :S
    EDIT: i have just tryed sum older bios's, it seem any bios newer then 2008 keeps the multi on 6 for 2 of the cores, is there anyone willing to maybe edit the lastest bios to enable the multi change of the 2 other cores?
+ Reply to Thread
