For your case, I'd suggest the 2150's when they become available. I don't have access to actual flow numbers of a SH so I'll take what I do have available to me and that would be SM (Petra's SM's to be precise). A AP-15 is rated (as you have stated) @ 58CFM (that's open air), when it gets on a rad like the MCR, it drops to ~35/36CFM. The SM is open air rated @ 70.5CFM but when it's on the same MCR, it only pushes ~37CFM...now here's the real kicker, the GT is ~ 8dB lower. It's all about static pressure and the GT has far more than the Yates ever will and that is what's needed to push through stacked rads. The 2150 RPM GT's are rated for 69CFM (open air) so should work a bit better. If noise truly isn't a concern, the newer model GT's (3K, 4.2K and 5.4K) may be of interest to you.
Fan on rad numbers taken from this topic.
http://www.xtremesystems.org/forums/...d.php?t=261778
