+ Reply to Thread
Results 1 to 3 of 3
Thread: GTX 460 768 vs GTX 280
    Sep 2008
    0
    Exclamation GTX 460 768 vs GTX 280
    Couldn't find a straight answer so far
    The reason i ask is because i had an evga gtx 280 but since it died they gave me a sparkle gtx 460 (the 768 one) as a replacement at the store i bought the 280.
    CPU:core 2 quad Q9550 - RAM: 4x2gb Kingston KHX8500D2/2G DDR2 1066 - Mobo:MSI P7N DIAMOND - Sound:Creative X-Fi Xtreme Audio PCI-E - VGA:MSI HD6950 flashed @6970 shaders - HDD:Western Digital WD2002FAEX 2TB - PSU:Corsair TX850W 850 watt - case:Chieftec BA-01B-B-B - coolers:CPU:zalman 9500 LED case:2x Noiseblocker blacksilent pro PLPX - mouse:Logitech MX518 - keyboard:Logitech G11 - OS:Windows 7 ultimate x64 - Monitor: Dell U2311H
    Registered User Nowyn's Avatar
    Aug 2009
    0
    While at stock it might loose in some games and win in others overall it should be somewhat comparable, plus 460 would overclock much higher than any 280/285, so it should give it an edge in the end.
    Intel Xeon W3520 @ 4.2 GHz | HT Off @ 1.248v
    Prolimatech Megahalems /w 38mm Scythe Ultra Kaze @ 2000RPM
    Gigabyte GA-X58A-UD5 @ F6 BIOS
    EVGA GeForce GTX 285 @ 712/1620/2808
    Corsair XMS3 1600 7-8-7-20-1T 3x2 GB @ Stock
    2x1TB WD Caviar Black RAID0 + 2TB WD Caviar Green
    Logitech MX-518
    Logitech G15 v2
    Chieftech 850W
    Samsung 22" T220
    Thermaltake Kandalf
    Mar 2010
    Skopje, Macedonia
    0
    Depending on the use their performance is about on the same level. I agree that when 460 is overclocked, it will surpass the 280 OC in most scenarios. It runs a lot cooler and it is more future-proof. I believe you got a good deal, although if I were you I would bargain for some other brand (different than Sparkle) and if possible with 1GB frame-buffer instead of 768. But in any case even Sparkle 460 768 is a good match for the 280.
    Phenom II 720 X4
    Biostar 790GXB A2+
    Corsair XMS2 8500 C5C 4GB
    ASUS ENGTX 460 DirectCu
    Cooler Master N520 & HAF 932
    ASUS Xonar D1 & Sennheiser HD485
+ Reply to Thread
