Results 1 to 3 of 3
Thread: F3-12800cl9d-8gbrl + Asus P8P67 PRO
    Feb 2007
    Germany
    Hi,
    I have the F3-12800CL9D-8GBRL, Intel i5 2500k, Asus P8P67 PRO, Crucial c300 64gb x2 in raid 0, Samsung F3 1tb x2 in raid 1, windows 7 pro.
    I'm planning on putting it together when I wake up, I read on the Asus forums that people had problems booting while running the ram at 1600 and had to enable the xmp profile in bios, will this ram run at 1.5v when I oc the cpu?
    Should I send back this kit and order the F3-12800CL9D-8GBXL, does the F3-12800CL9D-8GBXL need an xmp profile to run at 1600 and will this ram run at 1.5v when I oc the cpu?
    I know the F3-12800CL9D-8GBRL kit is on the Asus QVL list but the F3-12800CL9D-8GBXL is not, but obv the x series is designed for sandybridge.
    I just want the best compatibility with the mb to acheiv the most stable oc result and this was the only thing that was bothering me
    That kit will be no problem, just like any DDR3 motherboard, it will only default (AUTO) up to DDR3-1333. So anything above that needs to be manually set. Since you have a perfect combo, you can enable XMP in BIOS/UEFI and the memory will be automatically set. Once that is complete, the system should be nice and smooth.
    Thank you
    GSKILL TECH
    Feel free to contact ustech@gskillusa.com or use our G.Skill Q&A Sub-Forum, if having any questions about G.Skill products
    Check out our items on NewEgg
    Feb 2007
    Germany
    Cheers that's helped allay my concerns
