http://shop.hdnw.com/search.aspx?q=q6600
http://shop.hdnw.com/product.aspx?n=CP-INT924Q
Q6600 on clearance at a local computer store for 109$
if you keep getting server or 404 errors its because their website sucks
Intel C2Q Q9550 2.83ghz :: Intel DQ45CB :: 4 x 2gb OCZ DDR2 PC2-8500 Reaper HPC :: ASUS EAH5850 :: Thermaltake TR2 RX 750w :: Western Digital Caviar Black 4 x 750gb in RAID 10
Intel e3-1235 3.3ghz :: Intel s1200kp :: 4gb kingston hyperX 1600mhz :: WD 500gb Cavier Green
Intel i7-3770k 4.4ghz :: msi z77ma-g45 :: 8 gb patriot Signature 1600mhz :: 160gb WD Cavier :: 5830 + 5870 CF :: Antec Earthwatts 650w
"...all men die, and no brave man lets death frighten him from his desire..."
110$
and i went in to the store and they only had 1
which i bought >_> soo......
yea.....
can kill this thread i guess if you want
need to get a bigger heatsink for it.
just swapped out my cooler on the Q6600, put in a Zalman 9500A
went from ~85C on WCG load to 45C! >
Good work! Way to add cores!
Cruncher #1: EVGA Z68 FTW | i7-2600k @ 4.5 | 6GB Ram
Cruncher #2: Supermicro Dual-Socket | 2 x 6-core Opterons | 4GB Ram
Cruncher #3: 8-core Xserve 1,1
T400 for non-crunching
"But don't think you'll run me over - It's, ah, planting season here in Texas... and the farm is growing..." -Otis11 on crunching WCG
AMD also carries sub 100 X4 cpus, and for a bit more (actually 50%), EE X4 which is rated at 45w ( Athlon II X4 600E ). I am not sure whether that's TDP or ADP though.
But then for a bit more money on top of EE X4, you can get SB 2500s rated at 65w.
Main Rigs...
Silver : i7-2600k / Asus P8H67-I Deluxe / 8GB RAM / 460 GTX SSC+ / SSD + HDD / Lian Li PC-Q11s
WCG rig(s)... for team XS Full time
1. i7 860 (Pure Cruncher)
2. i7-870 (Acts as NAS with 5 HDDs)
3. 1065T (Inactive currently)
yea but i dont exactly have the money or real estate yet to keep buying more systems and setting them up
But does your Mobo allow OCing? Cuz that chip will do 3.6 without too much trouble iirc...
Got an Xtreme System? Bring it here! <----
ill try a little bit, but its not the most stable OS on it and i cant afford to upgrade it and pack the hdds away
Edit: dead in the water at 360x8. probably needs something more then 450w
Edit: Edit: Running 300 x 9 for the moment
An Antec what? If it is a "builders Series" I have a G0 Q66 @ 3.4 on air on that power supply with not issues 100% WCG and F@H on the vid card.
A Intel 975 board should be able to take it to 3.4 with out a problem at all. Maybe check for update info for the BIOS?
Antec Smart Power 450.
i have a Raidmax volcanoe 630w which i know is up for the challenge
http://valid.canardpc.com/show_oc.php?id=1617114
Humm. It sould be ok on either psu. Give it Hell either way. Good Luck Mr. G !
its running 300x9 and the temp has only increased like 2C to 56C 55C 49C 51C
You're going to have to bump up your Vcore, but if you put it at like 1.4 you should be able to boot at 375*9 without too much trouble... then see how high you can bump it?
Heck, the only Q6600 I ever OCed I put at 1.4v and started at 400*9. When that worked I just left it.
I think my Q6600 has made an impact on my stats...
...I think...
Nice jump! Now get that thing OCd!
its 9 x 300. pretty stable, quiet and warm.
my q9950 on the otherhand >_> is 2.83 and its hot as heck even with a Zalman 9700 on it
The XS WCG team needs your support.
A good project with good goals.
Come join us,get that warm fuzzy feeling that you've done something good for mankind.
i dont think ill be adding to much more in the way of systems til im stable out of college. its my last semester and bills will be piling up soon
Make sure that zalman is free of dust
it is, i just pulled it out of its packaging yesterday, though i dont know about that paste that came with it
my Q9550 hit 80C last night while i was sleeping with a 9700 zalman on it. not even overclocked, and the zalman was put on that same day. i have a 4850x2 with 2 VR900's on it, it used to run at 50C but now its hitting 80C again so i had to re-underclock it.
