+ Reply to Thread
Page 1 of 2 1 2 LastLast
Results 1 to 25 of 47
Thread: Silverstone TJ11
    May 2009
    0
    Silverstone TJ11
    All i can say is...wow!
    http://www.maximumpc.com/article/hom...t_case_goes_11
    thoughts?
    I am Xtreme lowfat's Avatar
    Oct 2005
    Grande Prairie, AB, CAN
    17
    Wow, it sure is ugly you must mean.
    No way would that thing be allowed in my house. It isn't even good enough for a closet.
    I am Xtreme zalbard's Avatar
    Dec 2008
    Germany
    41
    Huge, not very pretty and mad overpriced.
    http://www.xtremesystems.org/forums/...d.php?t=264274
    Donate to XS forums
    Xtreme Member KingOfsorroW's Avatar
    Jan 2009
    Huyamba
    0
    I like the case, but I don't like the price.
    I also don't see it being much (or any) better than the cm haf x, which is:
    1. available now
    2. 3x times cheaper than the silverstone
    3. has normal motherboard positioning
    i7 950@4.05Ghz HeatKiller 3.0
    EVGA E762 EK WB | 12Gb OCZ3X1600LV6GK
    Razer Tarantula |Razer Imperator | SB X-Fi PCIe
    480GTX Tri SLi EK WBs | HAF X | Corsair AX1200
    ____________________________________________
    Loop1: Double_MCP655(EK Dual Top) - MoRa3Pro_4x180 - HK3.0 - EKFB_E762
    Loop2: Koolance_MCP655(EK Top) - HWLabsSR1_360 - EK_FC480GTX(3x)
    Xtreme Enthusiast Sideroxylon's Avatar
    Jan 2007
    0
    I'll stick with my TJ07.
    Intel I7 920 D0 @ 4.2g------------EK Supreme HF
    EVGA X58 SLI LE------------------EK-FB EVGA X58 LE
    nVidia GTX 580----------------------EK-FC580 GTX
    6g Corsair DDR3----------------DDC 3.2 w/ Petra's top
    OCZ 120g Vertex SSD------------------PA120.4
    WD 150g Raptor
    WD 500g
    ASUS Xonar DS
    HX1000 psu
    Silverstone TJ07 case
    Registered User MasterYoda34's Avatar
    Dec 2008
    0
    Quote Originally Posted by Sideroxylon View Post
    this
    Xtreme Member eKirts's Avatar
    Sep 2008
    Guelph, Ontario
    0
    i agree... another step backwards from the TJ07
    .:Rig
    .:E8400
    .:Maximus Formula
    .:4 x Mushkin Ascent XP2-8500.2gb
    .:Radeon HD5870 1GB
    .:open case - plastic cutting board
    .:Upcoming
    .:i7 920
    .:Rampage III Extreme
    .:To be continued...
    Registered User Tigris STI's Avatar
    Nov 2008
    Sevastopol, Ukraine
    0
    Same here
    Jun 2009
    Toronto, Canada
    0
    I love it and i hate it.
    I love it because u can mod it but u need to spend a lot of $$$ to look nice.
    Banned
    Apr 2010
    0
    One word, fugly. For that price just buy a Mountain Mod case.
    Xtreme Enthusiast Lu(ky's Avatar
    Jun 2007
    Long Beach, CA
    2
    I agree the case just does not look right, price, but in the long run someone from here will think of some mad mods with it and it will be a real winner I bet..
    CPU: Intel Core i7-4770K
    MOBO: GIGABYTE GA-G1.Sniper M5 MATX 1150
    MEMORY: G.SKILL Trident X 8GB 2400MHz 9-11-11-31
    GPU: 2 x eVGA GTX 780 SC
    SOUND M-Audio BX8-D2 Monitors
    SSD: 4 x Samsung 128GB Pro's Raid 0
    PSU: SeaSonic Platinum 1000W
    COOLING: 2 x Alphacool NexXxoS UT60 Full Copper 420mm
    CASE: Lian Li PC-C32B TECH STATION MOD build log coming soon
    MONITOR: ASUS VG278HE Black 27" 149Hz
    O.S: Windows 7 Pro x64
    Oct 2010
    0
    +1
    Honestly, what were they thinking. For one thing, while those stupid holes on the side of the case may serve a purpose, they look like garbage.
    Xtreme Guru Johnny87au's Avatar
    Jun 2010
    In the Land down -under-
    0
    overpriced and not even as good as its brother the TJ07..
    Another thing I find funny is AMD/Intel would snipe any of our Moms on a grocery run if it meant good quarterly results, and you are forever whining about what feser did?
    Xtreme Member prznar1's Avatar
    Jul 2009
    Poland
    0
    the looks is just a matter of taste, but they are mad to put such a high price...
    Quote Originally Posted by AuToFiRE View Post
    *quarter million dollar frisbee*
    Feb 2008
    0
    Can anyone tell me for sure if an XSPC RX480 and XSPC RX360 radiator will fit in the bottom, with a standard ATX power supply?
    Jun 2007
    Long Beach, CA
    2
    Quote Originally Posted by nirvana_1911 View Post
    They say a 560 rad 4x140mm fans below will fit so I am sure it will. But I doubt a 480 rad along with a 360 rad will not because the 360 would hit the PSU.
    Jun 2010
    0
    Quote Originally Posted by Lu(ky View Post
    Mind linking me where it says that? That's news to me
  18. #18
    Xtreme Enthusiast SpuTnicK's Avatar
    Jun 2008
    1
    a bit of math won't hurt
    if it fits 560 rad then the bottom compartment is at least 605 mm wide
    now, on average, a 360 rad is about 410-415mm long. So you will have about 185-190mm room for a PSU.
    Is that not enough for you? (note that specified depth for this rad is 657mm!)
    An unfortunate person is one tries to fart but sh1ts instead...
    My Water Cooling Case Build (closed)
  19. #19
    I am Xtreme theseeker's Avatar
    Mar 2007
    Sugar Land, TX
    5
    Too bad they screwed it up. I was hoping for a replacement for my TJ07 but this case has too many issues.
  20. #20
    Xtreme Guru Church's Avatar
    Dec 2009
    Latvia, Riga
    5
    SpuTnicK: in few cases in addition to PSU length one has to add few cm-s for wires as well.
  21. #21
    Jun 2008
    1
    Quote Originally Posted by churchy View Post
    I did added that the overall length of the case is almost 5 cm bigger that 560gtx rad size!
  22. #22
    Xtreme X.I.P. Martinm210's Avatar
    Jun 2007
    Klamath Falls, Oregon
    30
    400 Euro is about $550USD
    Not that I wouldn't mind having one, but that's some serious change..
  23. #23
    Dec 2009
    Latvia, Riga
    5
    Martinm210: yup, imho it's price is main drawback of this case. At such price level one expects to have nearly no flaws in anything, yet that's not the case with TJ11. Heck, all we wanted was bigger TJ07, yet got one much more expensive, uglier and with motherboard layout not to liking of many. IF TJ11 would be priced lower, one could close eyes on drawbacks, but at it's price?
  24. #24
    Feb 2008
    0
    Silverstone specifies the overall length of the TJ11 as 657mm, a Corsair AX1200 is 200mm and an XSPC RX360 is 400mm.
    So that'd leave 57mm, minus the thickness of the front and back of the case itself and clearance for modular connectors and cable from the PSU.
    If worst comes to worst, instead of an RX480 and RX360, it'd have to be RX480 and RX240.
    What do you guys think?
  25. #25
    Crunching for the points! NKrader's Avatar
    Dec 2009
    Portlandia
    74
    i like it alot. other than the cheapo plastic hotswap bays where id put my radiator...
+ Reply to Thread
