Page 1 of 6 1234 ... LastLast
Results 1 to 25 of 148
Thread: AMD Launches HD 6770 AND HD 6750 (Rename!!)
    Jun 2010
    today amd Launches HD 6770 AND HD 6750 but Unfortunately These cards Rename for old card (HD 5770/HD5750)
    hd 6770
    hd 5770
    hd 6750
    hd 5750
    hd 6770
    76.8 GB/s memory bandwidth (maximum)
    hd 5770
    hd 6750
    73.6 GB/s memory bandwidth
    hd 5750
    this is bad
    amd epic fail
    Wanna look under my kilt?
    Jun 2005
    Glasgow-ish U.K.
    Shame I was hoping the 67xx was gonna bring some small power increases and power consumption decreases
    you sigged that?
    why?
    ______
    Xtreme Enthusiast Kai Robinson's Avatar
    Oct 2007
    East Sussex
    Uhm - its probably not a direct rename - they added DX11 and OpenCL to these...and they need a product that sits below the 6850...and they need to phase out the 5xxx series.
    Main Rig
    Intel Core i7-2600K (SLB8W, E0 Stepping) @ 4.6Ghz (4.6x100), Corsair H80i AIO Cooler
    MSI Z77A GD-65 Gaming (MS-7551), v25 BIOS
    Kingston HyperX 16GB (2x8GB) PC3-19200 Kit (HX24C11BRK2/16-OC) @ 1.5v, 11-13-13-30 Timings (1:8 Ratio)
    8GB MSI Radeon R9 390X (1080 Mhz Core, 6000 Mhz Memory)
    NZXT H440 Case with NZXT Hue+ Installed
    24" Dell U2412HM (1920x1200, e-IPS panel)
    1 x 500GB Samsung 850 EVO (Boot & Install)
    1 x 2Tb Hitachi 7K2000 in External Enclosure (Scratch Disk)
    Entertainment Setup
    Samsung Series 6 37" 1080p TV
    Gigabyte GA-J1800N-D2H based media PC, Mini ITX Case, Blu-Ray Drive
    Netgear ReadyNAS104 w/4x2TB Toshiba DTACA200's for 5.8TB Volume size
    I refuse to participate in any debate with creationists because doing so would give them the "oxygen of respectability" that they want.
    Creationists don't mind being beaten in an argument. What matters to them is that I give them recognition by bothering to argue with them in public.
    Xtreme Cruncher
    Jun 2006
    Who cares? You wanted them to design a whole new chip in order to slide it under 6870/6850? That would be colossal waste of time and money.They already have the chip that fits perfectly in that performance segment,it's called Juniper... It has already proved itself on the market,why re-invent the wheel then? Makes zero sense ,no matter how you look at it.
    AMD will do whole line-up refresh on 28nm,then you will have "brand new" mid range card(that will probably spank 6870/5850 ).
    May 2006
    over the rainbow
    Quote Originally Posted by Kai Robinson View Post
    hd57xx ist already dx11 & opelcl. its just a simple rename. its the same chip.
    AMD Phenom II X6 1055T@3.5GHz@Scythe Mugen 2 <-> ASRock 970 Extreme4 <-> 8GB DDR3-1333 <-> Sapphire HD7870@1100/1300 <-> Samsung F3 <-> Win8.1 x64 <-> Acer Slim Line S243HL <-> BQT E9-CM 480W
    Apr 2010
    Quote Originally Posted by informal View Post
    Why change the Names ؟؟؟
    Feb 2006
    Vienna, Austria
    5xxx had a complete DX11 lineup
    UVD2.0 tells us that it's the same chip
    but i don't think that it's suprising; juniper is a very small chip and highly competitive against GTS 450 (it completely destroys all 450 editions at the same price point); even a new 550 won't be able to touch it
    Core i7 2600k|HD 6950|8GB RipJawsX|2x 128gb Samsung SSD 830 Raid0|Asus Sabertooth P67
    Seasonic X-560|Corsair 650D|2x WD Red 3TB Raid1|WD Green 3TB|Asus Xonar Essence STX
    Core i3 2100|HD 7770|8GB RipJawsX|128gb Samsung SSD 830|Asrock Z77 Pro4-M
    Bequiet! E9 400W|Fractal Design Arc Mini|3x Hitachi 7k1000.C|Asus Xonar DX
    Dell Latitude E6410|Core i7 620m|8gb DDR3|WXGA+ Screen|Nvidia Quadro NVS3100
    256gb Samsung PB22-J|Intel Wireless 6300|Sierra Aircard MC8781|WD Scorpio Blue 1TB
    Harman Kardon HK1200|Vienna Acoustics Brandnew|AKG K240 Monitor 600ohm|Sony CDP 228ESD
    Oct 2007
    Hong Kong
    Shame on AMD!!!
    Xtreme Cruncher
    Jun 2006
    Quote Originally Posted by cold2010 View Post
    Because it's called marketing. AMD's latest lineup is named 6xxx,they can't have products with different names.This way it's easy for potential buyer: 67xx<68xx<69xx<6990.Prices and names are in line with performance.
    What *new" features would you get if AMD designed a new mid range DX11 800/720SP GPU with similar specs as Juniper? Answer :nothing. Then why do it in the first place? (rhetorical question)
    Xtreme Mentor
    Jun 2008
    France - Bx
    This HD6K series is a great deception ... HD5K was so good ...
    Jun 2010
    Please guys concentrate ! When Stream Processors come with the same Number (800) and When Texture Units come with the same Number (40) and When Z/Stencil ROP Units come with the same Number (64) and When memory bandwidth come with the same Number (76.8 GB/s for hd 6770/hd 5770 and 73.6 GB/s for hd 6750/hd 5750) and Both card use the same core clock and the same chip .... This is called rename!
    Feb 2008
    Denmark / Aarhus
    So it dont have hdmi 1.4? If it does then I dont care
    Desktop I5-3570k, 8GB Ram, GTX 560, Silverstone TJ08-E, Crucial M4 128GB, 750W Silver Power, ASUS P8Z77-M
    Laptop ThinkPad W520 2720QM /2 x 4 GB ram / Quadro 1000M / Crucial M4 128GB + 500Gb Hdd / FHD Screen / Intel WiFi Link 6300 AGN WLAN / 9 Cell Battery
    Laptop 2 New Macbook Pro Retina / i7 QuadCore / 650 GT / 16GB Ram / 512 GB SSD
    Server: Athlon II X4 640, ASROCK K10N78, 8GB Ram, LSI MegaRaid 8 port, 64GB Vertex 1, 5 x 1 TB WD Raid6, 3 x 3TB Seagate Raid5
    Aug 2008
    Waiting to see if it turn out to be accurate, but if it is, very disappointing in AMD.
    --Intel i5 3570k 4.4ghz (stock volts) - Corsair H100 - 6970 UL XFX 2GB - - Asrock Z77 Professional - 16GB Gskill 1866mhz - 2x90GB Agility 3 - WD640GB - 2xWD320GB - 2TB Samsung Spinpoint F4 - Audigy-- --NZXT Phantom - Samsung SATA DVD--(old systems Intel E8400 Wolfdale/Asus P45, AMD965BEC3 790X, Antec 180, Sapphire 4870 X2 (dead twice))
    Apr 2008
    Lansing, MI / London / Stinkaypore
    Quote Originally Posted by Mech0z View Post
    1.4a, while the 5700s were 1.3 (no bluray 3D). Bingo.
    Not that I agree with any of it though, I thought it would be 69->68->66...
    I have this nagging suspicion that the threadstarter is actually Chinese, but trying so hard to pretend to be westernized. ugh.
    Quote Originally Posted by radaja View Post
    so are they launching BD soon or a comic book?
    Jun 2007
    Thessaloniki, Greece
    Because it's called marketing. AMD's latest lineup is named 6xxx,they can't have products with different names.This way it's easy for potential sheep: 67xx<68xx<69xx<6990.Prices and names are in line with performance.
    fixed
    This worse than NVs rebrands as those at least had some minor changes for the most part
    Seems we made our greatest error when we named it at the start
    for though we called it "Human Nature" - it was cancer of the heart
    CPU: AMD X3 720BE@ 3,4Ghz
    Cooler: Xigmatek S1283(Terrible mounting system for AM2/3)
    Motherboard: Gigabyte 790FXT-UD5P(F4) RAM: 2x 2GB OCZ DDR3 1600Mhz Gold 8-8-8-24
    GPU:HD5850 1GB
    PSU: Seasonic M12D 750W Case: Coolermaster HAF932(aka Dusty )
    Jun 2008
    Hong Kong
    Maybe we just "Flash" the HD5770/HD5750 the VBIOS with HD6770/HD6750 , and get HDMI 1.4 native support wtih HD5k family ?
    Gaming Rig
    CPU : AMD FX-8300 (Vcore 1.275V )
    HSF : Thermalright AXP140 with GELID WING 14
    MB : ASUS M5A88-M
    RAM : Corsair Vengeance DDR3-1600 LP 4GB x4
    VGA : Galaxy GTX660 2GB GDDR5
    PSU : FSP Aurum 500W 80PLUS GOLD
    Case : Lian-Li PC-A04
    SSD : Plextor M5S 256GB
    Xtreme Cruncher
    Jun 2006
    Quote Originally Posted by BrowncoatGR View Post
    fixed
    I'll ask again : what *new" features would you get if AMD designed a new mid range DX11 800/720SP GPU @ 40nm with similar specs as Juniper?
  18. #18
    Xtreme X.I.P. Particle's Avatar
    Apr 2008
    Kansas
    I'd be upset if this were with a performance part instead of a gimpy mainstream one. The people effected by this aren't likely to complain--they just need simple to understand naming schemes. There are some exceptions (non-gamers on here for instance), but largely we're talking about the people who assume a 6000-series anything is going to be faster than any 5000-series card. You'd be surprised how often I get asked stuff such as: "Is a 5470 faster than a 4890?"
    Particle's First Rule of Online Technical Discussion:
    As a thread about any computer related subject has its length approach infinity, the likelihood and inevitability of a poorly constructed AMD vs. Intel fight also exponentially increases.
    Rule 1A:
    Likewise, the frequency of a car pseudoanalogy to explain a technical concept increases with thread length. This will make many people chuckle, as computer people are rarely knowledgeable about vehicular mechanics.
    Rule 2:
    When confronted with a post that is contrary to what a poster likes, believes, or most often wants to be correct, the poster will pick out only minor details that are largely irrelevant in an attempt to shut out the conflicting idea. The core of the post will be left alone since it isn't easy to contradict what the person is actually saying.
    Rule 2A:
    When a poster cannot properly refute a post they do not like (as described above), the poster will most likely invent fictitious counter-points and/or begin to attack the other's credibility in feeble ways that are dramatic but irrelevant. Do not underestimate this tactic, as in the online world this will sway many observers. Do not forget: Correctness is decided only by what is said last, the most loudly, or with greatest repetition.
    Rule 3:
    When it comes to computer news, 70% of Internet rumors are outright fabricated, 20% are inaccurate enough to simply be discarded, and about 10% are based in reality. Grains of salt--become familiar with them.
    Remember: When debating online, everyone else is ALWAYS wrong if they do not agree with you!
    Random Tip o' the Whatever
    You just can't win. If your product offers feature A instead of B, people will moan how A is stupid and it didn't offer B. If your product offers B instead of A, they'll likewise complain and rant about how anyone's retarded cousin could figure out A is what the market wants.
  19. #19
    Apr 2007
    canada
    fixed
    how can nvidia's rebrands be more ok ... LOLL
    WILL CUDDLE FOR FOOD
    Quote Originally Posted by JF-AMD View Post
    Dual proc client systems are like sex in high school. Everyone talks about it but nobody is really doing it.
  20. #20
    Jul 2005
    Quote Originally Posted by Sn0wm@n View Post
    Because the nvidia rebrands were on high end cards that were sold for top dollar. Oh wait that kinda make it worse. Never mind.
    Also, this type of rebranding should never be done by any company. Marketing isn't an excuse for misleading model numbers.
  21. #21
    May 2007
    Europe/Slovenia/Ljubljana
    What a ty rebranding. Unless they plan to seriously knock off prices it's really bad as it's a direct transfer. Usually if they do rename, they move "last year" top models into "this year" mid end models. Not from mid end to supposedly another mid end...
    Intel Core i7 920 4 GHz | 18 GB DDR3 1600 MHz | ASUS Rampage II Gene | GIGABYTE HD7950 3GB WindForce 3X | WD Caviar Black 2TB | Creative Sound Blaster Z | Altec Lansing MX5021 | Corsair HX750 | Lian Li PC-V354
    Super silent cooling powered by (((Noiseblocker)))
  22. #22
    Xtreme Mentor
    Feb 2009
    Bangkok,Thailand (DamHot)
    rename marketing !!!!
    Intel Core i5 6600K + ASRock Z170 OC Formula + Galax HOF 4000 (8GBx2) + Antec 1200W OC Version
    EK SupremeHF + BlackIce GTX360 + Swiftech 655 + XSPC ResTop
    Macbook Pro 15" Late 2011 (i7 2760QM + HD 6770M)
    Samsung Galaxy Note 10.1 (2014) , Huawei Nexus 6P
    [history system]80286 80386 80486 Cyrix K5 Pentium133 Pentium II Duron1G Athlon1G E2180 E3300 E5300 E7200 E8200 E8400 E8500 E8600 Q9550 QX6800 X3-720BE i7-920 i3-530 i5-750 Semp140@x2 955BE X4-B55 Q6600 i5-2500K i7-2600K X4-B60 X6-1055T FX-8120 i7-4790K
  23. #23
    Xtremely High Voltage Sparky's Avatar
    Mar 2006
    Ohio, USA
    Meh... Thanks AMD for nothing.
    The Cardboard Master
    Intel Core i7 2600k @ 4.5GHz, 16GB DDR3-1600, Radeon 7950 @ 1000/1250, Win 10 Pro x64
  24. #24
    Apr 2007
    canada
    Quote Originally Posted by MrMojoZ View Post
    exactly .. amd's rebrand isnt ok .... but its in no way worse then nvidia's rebrands ...
  25. #25
    Xtreme Mentor
    Feb 2008
    Cool, new midrange cards from AMD.
    Anyone want to upgrade their 5770s to the new 6770s? I would have done if I had waited longer for the awesome new 6770 cards before getting 460s.
    Intel I7 980 + Phanteks PH-TC14PE Red, Asus Rampage III Extreme, 12 GB Geil Ultra Series
    SLI MSI GTX 680 power edition, Creative X-Fi Titanium HD, 2x4 Tb Seagate HDD, 128 Gb Crucial M4, 512 Gb Crucial M4
    Gigabyte M8000X, Microsoft Sidewinder X4, Antec P182, Acer G24, Windows 7 Professional, XFX Proseries 850w XXX
    Keeping my mobo + CPU till they are obsolete
    Copper loop X48 build Blue X58 Build Red X58 build
