Results 1 to 10 of 10
Thread: Stuck at stable overclock on i7 920.
    Jan 2007
    Fredericksburg, VA - Podunk
    Well I am at my wits end folks. Try as I might, I am unable for the life of me able to get a stable overclock. I guess it's the cursed touch.
    Anyway, I have the following setup:
    Intel Core i7 920 D0
    ThermalRight Ultra 120 Extreme
    2x Gentle Typhoon 1150 RPM link
    Gigabyte GA-EX58-UD4P w/BIOS F13
    12GB OCZ DDR3-1600 7-7-7-24 link
    XFX HD5870 XXX
    4x Samsung PM800 128GB SSDs
    Seasonic X-650W PSU
    Windows 7 x64
    I tried to follow this guide from Gigabyte and it seems to work... sort of.
    It boots to Windows just fine but the machine fails after one pass of LinX. Temps get to 90C and stay there, which is a bit hot I do admit but no hard locks.
    My settings in the BIOS are as followed:
    MB Intelligent Tweaker (M.I.T):
    CPU Clock Ratio [20x]
    CPU Frequency [4.0GHz] [200x20]
    QPI Link Speed [x36] [7.2GHz]
    Base Clock Control [Enabled]
    BCLK Frequency (Mhz) [200]
    Performance Enhance [Standard]
    System Memory Multiplier (SPD) [6.0]
    Advanced Clock Control:
    Base Clock (BCLK) Control [Enabled]
    PCI Express Frequency (Mhz) [Auto]
    Uncore & QPI Features:
    QPI Link Speed [7.2GHz]
    Uncore Frequency [x13] [4000MHz]
    Advanced CPU Features:
    Intel Turbo Boost Tech. [Enabled]
    CPU Cores Enabled [All]
    CPU Multi Threading [Enabled]
    CPU Enhanced Halt (C1E) [Disabled]
    C3/C6/C7 State Support [Disabled]
    CPU Thermal Monitor [Enabled]
    CPU Eist Function [Disabled]
    Virtualization Technology [Enabled]
    Bi-directional PROCHOT [Enabled]
    >>>Advanced DRAM Features
    DRAM Timing Selectable (SPD) [Expert]
    Channel Interleaving 6 [Auto]
    Rank Interleaving 4 [Auto]
    >>>>>Channel A/B/C
    >>>>>Channel A/B/C Standard Timing Control
    CAS Latency Time 7 [8]
    tRCD 7 [8]
    tRP 7 [8]
    tRAS 16 [24]
    >>>>> Channel A/B/C Advanced Timing Control
    tRC 27 [Auto]
    tRRD 4 [Auto]
    tWTR 4 [Auto]
    tWR 8 [Auto]
    tWTP 19 [Auto]
    tWL 7 [Auto]
    tRFC 60 [88]
    tRTP 4 [Auto]
    tFAW 16 [Auto]
    Command Rate(CMD) 2 [Auto]
    >>>>> Channel A/B/C Misc Timing Control
    B2B CAS Delay - [Auto]
    Round Trip Latency 57 [Auto]
    CPU Vcore 1.31250V
    QPI/Vtt 1.515V
    IOH Core 1.12V
    DRAM Voltage 1.66V
    Advanced Voltage Control:
    Load-Line Calibration [Disabled]
    CPU Vcore 1.40000V
    CPU PLL 1.840V
    >>>MCH/ICH
    PCIE [1.500V]
    QPI PLL [1.140V]
    IOH Core 1.120V
    ICH I/O [1.580V]
    ICH Core 1.140V
    >>>DRAM
    DRAM Voltage 1.660V
    My only concern is that I need VT support for VMWare. HT would be very nice to have but not necessary a concern if disabling it gets me a stable OC.
    If anyone has any ideas, please feel free to toss them.
    Jan 2007
    After slaving a bit more, it seems to like 3.8GHz. Dropped the CPU clock ratio from 20x to 19x. It's on pass 4 now and seems to be holding steady.
    That being said, does anyone think enabling turbo will cause it to crash?
    Aug 2007
    England, UK
    90 degrees is too high IMO. If that was me I would run the ran in the 1600-1866Mhz range and drop that QPI/VTT voltage, its making your temps skyrocket.
    1.31250V VCore with LLC disabled is probably drooping to beloe 1.3v....I would enable LLC.
    IOH Core (you've listed it twice, im looking at the one below vtt) looks low, try 1.375v
    EDIT I would disable turbo mode for now...if you've got it set for 200x20 with turbo mode enabled, you're hitting 4.2. Try for 4ghz first
    Xtreme Guru
    Jun 2010
    In the Land down -under-
    For starts your VTT is way to high, drop it down to 1.35, QPI Link speed leave it on AUTO.. Cpu vcore 1.35 / QPI Pll 1.3 .. First of all though try getting temps down, Which cooler you using?
    Another thing I find funny is AMD/Intel would snipe any of our Moms on a grocery run if it meant good quarterly results, and you are forever whining about what feser did?
    Jan 2007
    Quote Originally Posted by Johnny87au View Post
    I'm using a standard TRUE 120 Black.
    Changed the voltages as followed:
    Load-Line Calibration [Enabled]
    CPU Vcore [1.35000V]
    QPI/Vtt Voltage [1.355V]
    Turbo Mode [Disabled]
    Am I forgetting something else?
    Xtreme Guru
    Jun 2010
    Quote Originally Posted by Kurumi View Post
    Qpi Pll - 1.3 .. Are you getting stable with those settings? Please post temps also.. Temps really seem awful..
    Jan 2007
    Well after some more testing this is what I have so far.
    QPI PLL is at 1.3V
    Temps get to 85C with case open, 89C with it closed.
    Can only get 19x204MHz so far. Won't hit 211MHz yet, but I think with more tinkering, it can.... maybe.
    Also using Core Temp 0.99.8 to monitor temps.
    Xtreme Guru
    Jun 2010
    Whats your ambient temps?? You could always try reseating the IHS and using aftermarket TIM..
    Jan 2007
    Ambient temps in the room are around 70 - 75F. I recently reapplied the heat sink and used the ThermalRight silver paste that I had from another build about three weeks ago. Before that I used AS5 and the temps were the same. The TRUE hasn't been lapped either.
    Mar 2003
    Holland,MI-USA
    change your Uncore Frequency to run at 3200 qpi 7200 ram 1600 see the pattern keep them in sink
    Cooler Master 110 case w/window and cold cathode/Sony E540
    I7 920@4.4Ghz 210x21 Megahalems
    Gygabyte GA-X58A-UD3R
    OCZ 6Gb DDR3 1600
    XFX ATI 5770 960/1400
    Seagate Barracuda 1.5tb
    Lite-On DVD RW iHAS220-08/Sony Optiarc AD-7190S
    PC Power & Cooling Silencer 750
    That's my 2008 Street Glide.
