http://valid.canardpc.com/show_oc.php?id=1599098
Memory is G.Skill PC4800 1GBLA (Samsung TCCD 437). It seems that I've just broken overall DDR1 frequency WR by mistake (seriously!)
Regards
Regards
Awesome, any Polish guys on XS that uses less then 5 year old hardware?
Both Ryvbanan and you are stuck with around launch of A64 hardware, hmmm...
Apart from that SellMa, I doubt that is close to highest DDR(1), considering that 320+ 2-2-2-5 has been done and alot were running TCCD at 360-380'ish.
Competition ranking;
2008; AOCM II, Minfeld/Germany #2 @ 01SE/AM3/8M (w. Oliver)
2009; AMD-OC, Viborg/Denmark #2 @ max freq Gigabyte TweaKING, Paris/France #4 @ 32M/01SE (w. Vanovich)
2010: Gigabyte P55, Hamburg/Germany #6 @ wprime 1024/SPI 1M (w. THC) AOCM III, Minfeld/Germany #6 @ 01SE/AM3/1M/8M (w. NeoForce)
Spectating;
2010; GOOC 2010 Many thanks to Gigabyte!
Very nice Frequency , you have maybe the WR
On 2005 , tanuki has a beautiful 410Mhz on DDR1, but the pic isn't available now (maybe tanuki did better).
Configuration :
Memory:A-DATA Vitesta DDR600 256MB(S/N:503XR)
DimmPosition:2
M/B: DFI LANPARTY UT nF4 Ultra-D(BIOS: Default)
CPU:Athlon64 3000+(BI)CBBHD 0448WPMW
CPU Cooler:PAL8150+Delta 8cm 1.35A
P/S:OCZ Power Stream 520W
VGA:ATI XPERT 98 PCI 8MB
HDD:Seagate Barracuda 7200.7 120MB(ST3120026A)
Vcore:1.4Vx123%(CPU-Z:1.664V)
Vio:3.35V Vddr:3.4V Vldt:1.5V Vchip:1.8V
R/T:19℃
OS:Windows2003Server
Can you use some tool to measure memory latency? I would be interested to compare it with today's values.
you wait until i tell Andre you broke his record, he is NOT going to be pleased!
I thaught LA was only in 256m flavors.
Very nice result .
What are your bench scores in aida for your mem?
I always wanted the 2x256m set of LA's, but by the time I wanted them, they were almost gone and very expensive.
I like my ch5 and some oem utt though.
Plus I got some decent oem sticks of samsung uccc 512m's.
The only good ddr1 board I got is the nf2.
And the one I have is 2nd hand, had to replace a bunch of caps and it don't clock quite the same like my 1st board did.
Some day I'll get back on it and mess with it, get it to 280 stable again.
Wanna see 280 stable with my ch5 and utt (768m, mixxed...), should be darn fast for that system.
That old nf2 is still faster at 240-250 with a single cpu at 2.4-2.5ghz then my dfi 790fx is with a single core at 3ghz :\.
Anyways, congrats on the result dude.
Do you know if anyone else has one any better with samsung ram?
Being that the 939 was the last ddr1 platform, that would be the only setup that could compete, dual chan wise.
Oh and to finilise your recored.
You should pi 32m it at the very least...
Old Scuul 4 live !!! really nice, wanted to do some oc on ddr2, which is oldscool too, but my Dominator 10000 stopped living, rma......
www.vitesse24.de
www.vitesse24.de
C2Q q6600 3.3GHZ @ 1,184V
4,5GHZ@ 1,52V ( 9* 500 )
Corsair Dominator 10000 2gb, 8888 2gb, 9136 1gb
Oh on that day i am novice overclocker
Intel Core i5 6600K + ASRock Z170 OC Formula + Galax HOF 4000 (8GBx2) + Antec 1200W OC Version
EK SupremeHF + BlackIce GTX360 + Swiftech 655 + XSPC ResTop
Macbook Pro 15" Late 2011 (i7 2760QM + HD 6770M)
Samsung Galaxy Note 10.1 (2014) , Huawei Nexus 6P
[history system]80286 80386 80486 Cyrix K5 Pentium133 Pentium II Duron1G Athlon1G E2180 E3300 E5300 E7200 E8200 E8400 E8500 E8600 Q9550 QX6800 X3-720BE i7-920 i3-530 i5-750 Semp140@x2 955BE X4-B55 Q6600 i5-2500K i7-2600K X4-B60 X6-1055T FX-8120 i7-4790K
