The problem is, hot water
I just put together WC system. below 24h old. Everything works but, somehow water inside loop is not cooling enough. Room temp is around 24'c and water temp is 42'c if the temp sensor inside aqua xt pump is accurate. This is when i fold with both GTX 480 @ stock clocks.
Another problem is cpu that heats up in linx test. Hitting around 78'c, idle around 50'c and below.
Loop order, pump(Aquastream XT- Ultra Version) -> gpu blocks in paraller(ek) -> cpu block(Swiftech Apogee XT Extreme) -> rad(Phobya G-Changer 420) -> res
I have 3 noctua 14cm fans pulling air trough rad.
What is next step to solve this problem, buy another rad? reseat cpu block?
Goal here is silent system and any tips is
pic of the system and specs
core i7 920@4GHz HT on 1.376V
sli gtx 480@stocks
coming soon
MB blocks and memory block
