    X
    Subscribe to New Ads!
    Receive weekly ads in your inbox!
Results 1 to 19 of 19
Thread: Asus P8P67 Pro + 2500K + CrossFire 6970's = no way to reset BIOS...
    Mar 2008
    Minnesota
    So I figured the lack of a rear panel clear CMOS button meant maybe Asux had better "failed overclock recovery" than previous generations, the lack of a clear CMOS button on the board further enforced that hope.
    Turns out you can't have a card in the second PCI-e slot and be allowed to reset the BIOS period. Card blocks both the jumper and the battery.
    Having all sorts of fun learning to OC a new platform with a BIOS that can't be reset
    There is virtually no recovery with this setup if you choose a setting the board doesn't like, maybe a new BIOS will address it, but probably not based on my previous experiences with Asus BIOS support
    Just figured I'd post a heads up should anyone choose to venture into SNB with this board, plan on having to route a lame CMOS clearing jumper wire outside of your case.
    i5 2500K @ 4.9GHz+ 8GB G-Skill RipJaws DDR3-2000 @1600Mhz CAS 6 Asus P8P67 Pro CrossFire 6970's @ 950/1450
    Xeon X5677 @ 4.5Ghz 6GB G-Skill RipJaws DDR3-2000 @1600Mhz CAS 7 Gigabyte EX58-UD5 4870x2
    i7-880 @ 4.2Ghz+ (still playing) 4GB G-Skill RipJaws DDR3-2000 @2300Mhz CAS 9 Asus Maximus III Formula MSI Hawk 5770
    Jan 2005
    Oddly, with the 1053 bios mine just resets itself fine if I fail an overclock attempt... starts for a second, then restarts itself with a prompt to press F1 for settings, "overclocking failed". I'm on a 2600K with the P8P67 Pro. I have had no issue at all with needing to reset the CMOS with my oc'ing attempts.
    Mar 2008
    Minnesota
    Quote Originally Posted by GoldenTiger View Post
    Interesting. I've tried the BIOS mine shipped with (forget number, not available on the site) and now I'm on 1053 and it fails hard every time. Boot loop forever and won't boot even if I turn off the PSU and let it sit for 10+ minutes.
    What is your setup exactly?
    Xtreme Mentor dengyong's Avatar
    Nov 2006
    A great place again
    Quote Originally Posted by tool_462 View Post
    Can overclock recovery be turned on/off in bios ?
    Oct 2010
    my pro will recover itself, but it takes about 1.5 minutes to boot when booting cold. and on a reboot, it takes about 20seconds to get to the screen prompt. seems they are going to wrong way on boot times.
    Nov 2006
    A great place again
    Quote Originally Posted by dejo View Post
    I'll have one of these tomorrow. I thought they're suppose to boot faster than the old bios ?
    Nov 2009
    I am not sure if this will work on these boards, but I had a DFI X38 that would reset the CMOS if you held the reset + power button down for 6-7 seconds. It was not documented anywhere I could find but it worked every time.
    May 2007
    Calgary, Alberta. Canada
    I have the P8P67 Deluxe version and it loops like yours but when it does that I hold the off button till it turns off and let it sit for a few seconds. Then push the on button and it boots to overclocking failed please hit F1 to enter bios.(Bios version 1053)
    Different board and mine doesn't like to save settings either!!
    Rig 1
    CPU: i7-990X. CASE: Antec Nine Hundred II. CPU Cooling: TR Venomous X RT. MOBO: ASUS Rampage III Formula. RAM: 12GB Mushkin DDR3 1600 CL7. GFX: EVGA GTX 580's x 2. SLI. HDD's: 1.5 TB Seagate, 1TB WD Sata III. Monitor: Samsung 25". PSU: Corsair AX 1200W. Win 7 64 Bit
    Rig 2.
    CPU: i7-2600K. CASE: Antec Nine Hundred II. CPU Cooling: TR Venomous X RT. MOBO: ASUS P8P67 Deluxe. RAM: 4 GB GSkill Ripjaws X DDR3 1600 CL6. GFX: EVGA GTX 580. HDD: 1TB WD Sata III. Monitor: Samsung 23". PSU: Corsair AX 1200W. Win 7 64 Bit.
    May 2003
    Athens-Greece
    I tried to SLI ... and it was a nightmare everytime i had to reset !!!
    Problems with Asus P67 series ? ... no way
    Have you tried the Asus CrashAlways BIOS 3 utility ?
    Asus Rampage IV Extreme ==> i7 4930k @4.9Ghz water-cooled (3325A911) IMC 3400+
    Asus Maximus V Gene ==> i7 3770k @4.8Ghz air-cooled (L224B652) IMC 3100+
    VTX3D 7870 Black Edition
    Avexir 2666 CL-11
    Enermax Revolution 85+
    Mar 2008
    Minnesota
    Quote Originally Posted by NewPants View Post
    Worth a shot, thanks for the idea.
    Quote Originally Posted by crossg View Post
    I've tried button hold, reset, etc and it just keeps with the boot loop.
    After further testing it does seem to happen primarily when changing EIST/Speedstep/C1/C3/C6 state type settings. If there is just insufficient vcore or too tight of RAM timings it will boot successfully after a hard shutdown (PSU) and a minute or so.
    Quote Originally Posted by TASOS View Post
    Hoping it will be addressed with a BIOS update, but like I said I'm not holding my breath. Funny that they couldn't toss a reset button on the board, the traces and surface mount pads are there for one
    Jan 2005
    That is what mine does and how I handle it. Saves settings fine though...
    Nov 2008
    Nottingham, UK
    you tried holding the insert key on boot up?
    Don't worry guys, i'm s**t at games but I have 500fps!
    Intel 4670K @ testing
    Corsair H100i
    MSI Z87-G43
    8GB Corsair 1866 CL9
    XFX 7950
    Samsung 830 256GB SSD
    Corsair Vengeance C70 Case
    Tagan 480w PSU
    Mar 2008
    Minnesota
    Quote Originally Posted by SBB View Post
    I haven't, I will though.
    I'm learning what settings not to change to avoid the boot loop, but it's still frustrating.
    I also can't cold boot after a few hours with the PC off, even at 100% stable settings Thinking my board might be a half borked edition.
    I am Xtreme
    Sep 2006
    Till now MemOk button saved my b u t t a few times...
    Question : Why do some overclockers switch into d*ckmode when money is involved
    Remark : They call me Pro Asus Saaya yupp, I agree
    Oct 2007
    I had same problem the way I cured it was setting power lead out resetting bios and then entering 1.6V as dram Max. It hasn't caused a problem since. I have Corsair GT's 2000 Btw. It seemed before like the settings were not saving and evrry time I cold booted failed to overclock failed.
    @tool 462 try setting mem to 1.6V
    System:
    Asus P8P67 Deluxe 2600K 4.8Ghz 5970 4GB Corsiar GT 2000 Areca 1880i & Corsair F40 and 2 Intel 80 Watercooled DDC 120.3
    Mar 2006
    Denmark
    P8P67 Pro recovers fine here.
    Froze during windows load screen, board reset by itself (well I did push the reset/power on very shortly, but dont think it affected recover).
    Froze and bsod'ed in Windows, after memdump was done the board reset (didnt touch a thing).
    Bios 1053.
    Intel i5 2500K | Asus P8P67 Pro | EVGA 570 SC | ST75ZF 750W
    Mar 2006
    Denmark
    Bios 1053.
  18. #18
    Jan 2005
    Hey guys, have a question... I'm trying to OC my RAM on the P8P67 Pro (1053 bios), but the DRAM Voltage setting seems to have no effect... it reads 1.51v or so on the voltage to the left, even if I set it to 1.60-1.65v in BIOS. Any way to change/fix this?
  19. #19
    Xtreme Cruncher
    Dec 2005
    somewhere over the rainbow
    I've ran into this probblem on many boards in the past.
    A quick fix is to mount a switch somewhere in the case that can switch between cmos pins and reset the bios and then install the video card.. Its a bit of work but saves from alot of hassle.
    Brandon
    Heatware | Ebay:Crazymullen | If you are unsure what Fhqwhgads means You are REQUIRED to go HERE| Powered by Centon Ram
    IMHO Waste is a computer going to a landfill having done actual computations less than 90% of it's life. 90% of the computers powered on right now are idle or powered off; what a waste! [/B]
    Is it a coincidence that your wifes pc is called Uranus?
