hi,
just woundreing which company makes higher default clocks of this card?
hi,
GIGABYTE's 460SO, core/mem clock are 815/4000.
if you wanna get higher clock, you could OC easily by your self, this 460SO's core clock can even be tweaked to 900 or may higher and higher.
how this leadtek 1gb gtx460 extreme.gpu/memery 800/4000mhz.any one using one of these??
Colorful iGame GTX 460
Turbo mode 900/1000
If you live each day as if it was your last, someday you'll most certainly be right.
evga FTW is 850/1700/1000
Sandy Bridge 2500k @ 4.5ghz 1.28v | MSI p67a-gd65 B3 Mobo | Samsung ddr3 8gb |
Swiftech apogee drive II | Coolgate 120| GTX660ti w/heat killer gpu x| Seasonic x650 PSU
QX9650 @ 4ghz | P5K-E/WIFI-AP Mobo | Hyperx ddr2 1066 4gb | EVGA GTX560ti 448 core FTW @ 900mhz | OCZ 700w Modular PSU |
DD MC-TDX CPU block | DD Maze5 GPU block | Black Ice Xtreme II 240 Rad | Laing D5 Pump
I'm buying an EVGA GTX 460 1GB SC EE, flashed to a FTW edition BIOS, that works effortlessly for $200 AUS. This is all I'm paying and it's gonna flaw the EVGA GTX 285 2GB FTW edition that I bought a year and bit a go when it first came out for $700.
some info from leadtek website
WinFast GTX 460 EXTREME
GPU NVIDIA GeForce GTX 460
Graphics Bus PCI Express 2.0
Memory size 1024MB GDDR5
GPU/Memory clock 800/2000MHz <------- default clocks?
Memory data rate 4000MHz <------- ?
Output Dual-Link DVI x 2+Mini HDMI
Memory Interface 256-bit
Data bandwidth( GB/sec.) 115.2
Fill Rate(billion texels/sec) 37.8
Stream process 336
RAMDACs (MHz) 400
Full Microsoft® DirectX®11 Shader Model5.0 Support
NVIDIA® 3D Vision™ Ready
DirectCompute Support
HDMI 1.3a Support
ok already on order this card
any one can explain to me GPU 800mhz,MEMERY 1000mhz, SHADER 1600mhz ? factory clocks.am i right?
Looks ok mate, that is a nice base overclock and would mean that the card is only about 10-15% behind an unreleased 560 would score.
Intel i5 2500k @ 4.2 Ghz
TRUE 120 Extreme @ Scythe S-FLEX 1600rpm
8GB (2x4GB) G.Skill RipjawsX PC12800 CL8 1.5V
AsRock Z68 Extreme4
2x 6950@70 2GB CrossfireX
Dell U2711
OCZ Vertex 2E 60GB SSD
Samsung F3 500gb HDD
Silverstone FT-02B-W
how u must determine shader clock because is nothing mention about shader?????
My gigabyte had 750 core clock
