Well it's sort of an Autocascade, and sort of not...
I have an AC window unit i got cheap and thought I'd play a bit.
Really the inspiration is Drewmeister more than anyone else. He's had a system for blending gasses that's given some amazing temps, and working in the science and medical cooling field of cooling, has the gasses and experience to make it happen.
There was a time that I wasn't a 'believer' but I realised that any limitations I placed on his work, I place on my own.
Took around 4 min to get the initial cooling working well, then a steady drop over the next 5-10 min to around -90c. Around 5 min after that, to -100c.
So this is a 1/2hp rotary, and the blend is 134a/290/1150. Enough of the lower pressure gasses to get started, and enough Ethylene to maintain the low temps.
Not pretty or even really well organised, just brazed in what was needed without a lot of fuss. Not going to be a finished unit how it is.
No load tests yet, but I'll clean up the evap and all that, get a bit better insulation, and go from there. I don't expect much, but if I can get even a 20% Ethylene 'cooling blend' to work, then that's enough to pull the temps down on load dramatically.
Currently around 1/3 of each gas, but I don't expect the Ethylene to remain at that level when it's entering the evap. Hard to explain exactly, but I am hoping that it can stay over 15% fully condensed Ethylene for actual evap cooling.
It's autocascading obviously, but not with phase separation as such. More of an enhanced blending system within the captube.
Wish I'd gotten pic of how it's been brazed, but the manifold in the pics is the start. The return gas uses it as the suction line heat exchanger, and then captube is a 2 part setup.
The Captube is coiled enough to slide into the SLHX, and 2 kinds.
First length is 1/8", around 7'. Then it's brazed into a 6" piece of 1/4" copper pipe. Then it carries on as .031" captube, around 3'.
The 1/8" and 1/4" are coiled and brazed into the SLHX and it's a fairly tight fit.
The 31 is just wrapped, and I'm thinking of brazing that to the pipe.
No flexline for this though. No intention of this being a 'unit' just some experimentation. The gas blend is pretty standard to be honest. Started with a 40psi charge of 290. Then up to 80psi with 134a. After that, around 150psi total static with the 1150.
I added another small amount of R290, but my static is still around 130psi with a cold suction line, more likely 150psi still with it warm.
But I found a good blend, and the 6" piece of pipe seems to be working the way I'd hoped, making a chamber for the liquid low pressure stuff to help the 1150 condense, and then travel into the 31.
But the numbers speak for themself so far.
I'll be playing a bit here and there with this, try to find a blend of gas and a captube setup that really makes the high pressure blending work for me.
Don't know if I'll be able to get the Ethylene to stay condensing well enough to be part of the gas that's actually cooling with higher load, but it's a fun experiment.
I enjoy the research a lot more than the 'real work'
Gray
