Several years ago, I remember seeing a while ago an in-line filter made by Pentek. It absolutely killed flow rates but it did was a filter is supposed to do. Anyone know where to pick one up?
idk but just was thinking if you had two tanks one on top of the other with the filter in between you wouldn't have to worry about flow would you. The return dumps into the top tank, the water would drop through the filter into the bottom tank. Obviously take a bit of space but could be done.
Lian Dream: i7 2600k @ 4.7Ghz, Asus Maximus IV Gene-z, MSI N680GTX Twin Frozr III, 8GB 2x4GB Mushkin Ridgeback, Crucial M4 128GB x2, Plextor PX-755SA, Seasonic 750 X, Lian-li
HTPC: E5300@3.8, Asus P5Q Pro Turbo, Gigabyte 5750 Silentcell, Mushkin 2GBx2, 2x 500gb Maxtor Raid 1, 300gb Seagate, 74gb Raptor, Seasonic G series 550 Gold, Silverstone LC16m
Laptop: XPS15z Crucial M4
Nikon D700 ~ Nikkor 17-35 F2.8 ~ Nikkor 50mm F1.8
Lian Dream Work Log
my smugmug
Heatware
The last place I saw these were Petra's, but that shop is gone. You might try http://www.mcmaster.com for it or something similar. It is very restrictive, I could never get mine to work with either a single MCP655 or MCP355.
CPUID http://valid.canardpc.com/show_oc.php?id=484051
http://valid.canardpc.com/show_oc.php?id=554982
New DO Stepping http://valid.canardpc.com/show_oc.php?id=555012
4.8Ghz - http://valid.canardpc.com/show_oc.php?id=794165
Desk Build
FX8120 @ 4.6Ghz 24/7 / Asus Crosshair V /HD7970/ 8Gb (4x2Gb) Gskill 2133Mhz / Intel 320 160Gb OS Drive, WD 256GB Game Storage
W/C System
(CPU) Swiftech HD (GPU) EK HD7970 with backplate (RAM) MIPS Ram block (Rad/Pump) 3 x Thermochill 120.3 triple rads and Dual MCP355's with Heatkiller dual top and Cyberdruid Prism res / B*P/Koolance Compression Fittings and Quick Disconnects.
Mcmaster
IIRC, http://www.mcmaster.com/#4448k26/=aes99u is the right one
I use mine to clean any crud that may be in the loop for a few days before final assembly then remove it.
I'm using 5 micron filters and my DDC's push through just fine.
Circles SucQ!
You can also get those things from a hardware store or a water treatment store. It's actually for a house water filter. I would just go to Home Depot, Lowes, Walmart, etc and you should be able to find it there.
Project Millertime: The Core I5 build
Crunching/folding box on air: AMD Athlon X2 7750 Black Edition; Sapphire Radeon HD 4830; Gigabyte MA78GM-US2H; Lian Li PC-V351; Windows 7 RC
house water filter, maybe, but such filters with G1/4 threads imho aren't that common in plumbing stores.
I believe that the Pentek does not have a G 1/4" fitting either and still needs a converter of some sort.
Desk Build
W/C System
Don't know how about Pentek, but this one has G1/4 ports.
Yep, you're correct. IIRC, I said "to hell with it" and jammed a pair of these in there because it was the cheapest way to go at the time. Has worked fine for about 4-5 years now without a leak. If I had to do it today, I would probably find some convoluted method, making sure to use the proper threads for each joint regardless of cost.
Circles SucQ!
Yea, you will need to convert it down, but there are PVC adapters out there that allow you to drop down the size. I'm not certain if they exist in G1/4, but you can get plastic barbs in most sizes.
Good enough. Thanks guys
