Before I start, I want to give a big shout out to Timo Minx and Froudeg for supplying the block and Housing for this. Was a great gift and I haven't been able to set it up until now. A few years later, but I never let it go. Thanks guys
So this is custom made for load testing. They had some made up with power supplies and resistors, and their setup was pretty cool. Froudeg was some kinda genius with the electronics and while my setup won't be nearly as cool, I'm hoping to get it pretty accurate.
The load testing system I have now is ok, and pretty accurate, but it's bulky and ugly.
The 'station' is ok, with the Power Meter and variable voltage, it's always been the block design that i hated. Awkward and just didn't look professional.
So some pics of where I'm at.
The housing...
The block with locations for resistor/heating element...
the mounting plate...
The base of the block is 1.5" and the face is reduced to 1.3" with a location for the K probe, drilled right to the center of the mass.
The base has a location that will currently fit an 5/16" (8mm) bore, 1.5" (40mm) length load resistor or heating element (same difference)
That plate is an old backplate from a Kayl mount so thanks to you too Kayl! I didn't have to touch it, it's the ideal size square cutout for this setup.
I just had to measure and drill the holes to bolt the plate down, and I countersunk the holes so that the screws are just under flush.
Once I have a heater to stick in there, I'm good to go. I'll be using expanding foam for the fill behind, along with some fine tuning of the plate.
I need to grind just a tiny bit off the plate so that it has enough clearance for some foam tape to insulate from the heater block. that way it should give as true a reading on heatload as it can.
Before it was just the housing and block but now that I finally got around to making the plate work, I'm pretty stoked to give it a try.
Just need to make a couple calls tomorrow, I've been reading the catalogues for a few suppliers, but the variety is way too huge. Besides, ideally it'd be great to find a copper or brass style of element if I can. If I can match the size, or go to a very slight interference fit, I should be able to get the best heat transfer I can with minimal need for paste.
Otherwise I'll fit something in that's very close to size, and use a thermal epoxy. Not as good, but I'll do what I need.
As long as I can get it well insulated so the heat can only go to the evaporator it should get me the accuracy I'm hoping for.
I'll run a K probe on the face where it is, and I'm going to run 2 more, one on the resistor, and one on the rear of the block as well. Bit more infomation on heat and where it's going.
I'm going to see if I can find a decent control, or even just a heat sensor and relay to cut the tester off if it's over 70c or so. I think that should do, though I don't know what the plastic is so I may go slightly lower.
At least then it'll be safer against failure in cooling, or if it's left on after testing.
Just a few little things, and it'll be ready to roll. Just need to find something in a 200w or better rated, 20 to 25 ohm (or close) resistor of the right size.
Oh, that's the variable power and power meter station I made up, works pretty well, and goes up to around 400w at the moment. Hoping work it to 600w max when I'm done. We'll see what resistor I can find
So that's the project, hope I can find that last thing soon. The test block I have now works really well, but this should give me a bit more data when I'm testing, and let me do even more with respect to tuning, and assessing evap effectiveness.
Gray
