That's something I was wondering.
Wat block(s) are you using now?
If you're using restrictive blocks you're going to see a pretty steep rise in tube pressure with a powerful pump.
That Iwaki could blow a line if the blocks won't let it flow, or even if it doesn't, the pressue being high can wear the pump out too.
If your blocks are going to be an issue, getting something that's a free flow system may be better.
You don't need 'great' blocks with a chiller like that, but if you need high flow, using a type of block that works best with high flow may be something to consider.
Like the old 'maze' blocks of the past.
Gray
