    X
    Subscribe to New Ads!
    Receive weekly ads in your inbox!
Page 3 of 5 FirstFirst 12345 LastLast
Results 51 to 75 of 104
Thread: Chiller's Hybrid SR-2 (56k death)
  1. #51
    Jan 2008
    Athens -> Hellas
    Amazing Work!!!
  2. #52
    Nov 2009
    Netherlands
    Nice job on the custom heatsinks, they really fit the dominators well .
    “Little expense had been spared to create the impression that no expense had been spared.” - Hitchhiker's Guide
    It's better to ask dumb questions now, than to look stupid later
    Mondays:
  3. #53
    Aug 2008
    today had some fun to make some more Dominator GT flames for my memory :
    3dmark Vantage : +47K (NO PhysX)
    3dmark11 : +14K
    3dmark06 : +41K
    3dmark05 : +50K
    3dmark03 : +187K
    3dmark01 : +126K
    Wprime32m : 3.233sec
    Wprime1024 : 1m30sec320
  4. #54
    Feb 2010
    UW - Madison
    If those dissipate heat well enough, Corsair might have some interest in them... they look sick!
    Signatures make my posts look huge... but I'm not humble enough to completely remove my signature, so I kept this note explaining it.
  5. #55
    Aug 2008
    they are made from pure alu, so yes i think they will transfer the heat good enough.
    3dmark11 : +14K
    3dmark06 : +41K
    3dmark05 : +50K
    3dmark03 : +187K
    3dmark01 : +126K
  6. #56
    Dec 2006
    @ Chillerzero - those are some awesome looking flamed heatsinks.
    /_/_/_ | Intel Core i7 920 @ 4.2GHz | Swiftech Apogee GTZ | Gigabyte EX58-UD5 | CORSAIR DOMINATOR 6GB DDR3 1600 | 2 x ATI 4850 Crossfire Enabled | WD Velociraptor 300GB | Creative Sound Blaster X-Fi Titanium Fatal1ty Pro | Corsair HX1000W | Antec P182 | _\_\_\
  7. #57
    Aug 2008
    update :
    3dmark11 : +14K
    3dmark06 : +41K
    3dmark05 : +50K
    3dmark03 : +187K
    3dmark01 : +126K
  8. #58
    Dec 2006
    Looks good!
  9. #59
    Aug 2008
    thanks
    3dmark11 : +14K
    3dmark06 : +41K
    3dmark05 : +50K
    3dmark03 : +187K
    3dmark01 : +126K
  10. #60
    Extreme BodyBuilder SnW's Avatar
    Aug 2008
    Holland,NH
    Mate i am seriously in love with you're rig as you know from OC3D
  11. #61
    Oct 2007
    denmark
    keep up the good job, keep it comming man, thats crazy! love it!!
    GIGABYTE G1.Sniper M5 / intel i7 4770K @ ????Mhz / EVGA GTX 780Ti SC ACX / HyperX Beast DDR3-2400 DC 16GB / Seasonic Platinum-860w / Corsair 350D / AOC G2460P.
    Cooled By H2o.
  12. #62
    Aug 2008
    waiting on my snake connectors that i ordered, so i can hook up the 3th pump and fill the loop
    3dmark11 : +14K
    3dmark06 : +41K
    3dmark05 : +50K
    3dmark03 : +187K
    3dmark01 : +126K
  13. #63
    Aug 2008
    small update, got at last the snake connector in, so the 3th pump can be fitted and the loop closed,
    ready to fill it up.
    left of the pump you see all kind of cables , that's for the Koolanc TMS-200 controller, all kinds of temp sensors all around the mobo and cpu's.
    3dmark11 : +14K
    3dmark06 : +41K
    3dmark05 : +50K
    3dmark03 : +187K
    3dmark01 : +126K
  14. #64
    Aug 2008
    i'm going to fill up the loop now the 3th pump is installed, own mixture : 25% Ethylene Glycol and 75% PURE water, no demi.
    what you see in the measure cup is the Glycol no color pure 100% glycol :
    here my koolanc poor in cup on the ZERN res with a snake connector to make it a little bit eassier to fill :
    on the drain valve i putted also a tube in a bus filled with my mixture, where the pump can draw it's liquid from when i put the valve open, to make it a little bit eassier to lol :
    and here comes the first liquid lol, pumps are now running to get the last micro bubbles out the loop, for now, no leaks found :
    3dmark11 : +14K
    3dmark06 : +41K
    3dmark05 : +50K
    3dmark03 : +187K
    3dmark01 : +126K
  15. #65
    Aug 2008
    3dmark11 : +14K
    3dmark06 : +41K
    3dmark05 : +50K
    3dmark03 : +187K
    3dmark01 : +126K
  16. #66
    Aug 2008
    It's a miracle !!!!
    i get it closed hahahahaha, +200m cable in limited room of 3,5cm lol :
    here you see that the plate is a little round, but i put the cable fast fast in to look if i get it closed,
    later on the cable will be nice routed and strapped so that the plate doesn't look round :
    3dmark11 : +14K
    3dmark06 : +41K
    3dmark05 : +50K
    3dmark03 : +187K
    3dmark01 : +126K
  17. #67
    Aug 2008
    last minute adjustment for the vga's :
    3dmark11 : +14K
    3dmark06 : +41K
    3dmark05 : +50K
    3dmark03 : +187K
    3dmark01 : +126K
  18. #68
    Aug 2010
    Nice build man, looking forward to seeing the finished thing. Nice SIG too ahaha. I was the guy who painted the EVGA wallpaper of the "joker/scientist" with his LN2. Its nice to see people using it.
  19. #69
    Aug 2008
    little update :
    3dmark11 : +14K
    3dmark06 : +41K
    3dmark05 : +50K
    3dmark03 : +187K
    3dmark01 : +126K
  20. #70
    Aug 2008
    http://valid.canardpc.com/show_oc.php?id=1717611
    Mobo and cpu's cooled by the two coolers in screenshot software:
    3dmark11 : +14K
    3dmark06 : +41K
    3dmark05 : +50K
    3dmark03 : +187K
    3dmark01 : +126K
  21. #71
    Jan 2010
    nice stuff
    Internal Watercooling Antec 900 Build Log*
    WC loop: Black ice extreme 240 radiator, XSPC 120 radiator, HK 3.0, D5 pump with Bitspower top, DD fillport, Primochill tubing, distilled + ptnuke
    Pink Floyd is #1
  22. #72
    Aug 2008
    thanks
    3dmark11 : +14K
    3dmark06 : +41K
    3dmark05 : +50K
    3dmark03 : +187K
    3dmark01 : +126K
  23. #73
    Aug 2008
    here are the load temps, cpu temp in Coolit software is not correct, cpu isn't supported by the coolit software.
    As you see idle the coolers run lower power, when stressed the coolers will raise there cooling power, and keep the liquid temp low, under Ambient,
    cpu temp raises a 5 a 6°C from idle to load thanks to temp controlled coolers.
    Temp of liquid is set @ 22°C max, min power of coolers @ 60%, max power @ 100%, real nice settings on these coolers,
    and the coolers don't even run at 100% to keep the temp, for me that's good for lower noise level :
    3dmark11 : +14K
    3dmark06 : +41K
    3dmark05 : +50K
    3dmark03 : +187K
    3dmark01 : +126K
  24. #74
    May 2006
    Colorado Springs
    There are no words for what you have man
    1
  25. #75
    Aug 2008
    little sneakpeak what i'm doing now :
    Most of the time, people put there powercable for vga like the RED arrows.
    I whant it as clean as possible in this case, en i will do my powercables like the GREEN arrow, straight horizontal with the vga's.
    Vga's seems like they are floating in the air lol, strange sight.
    On later time i can mod also the plastic cap on the vga, make it wider, little bit bigger, so the powercables are IN the plastic cap of the vga cooler, totally NOT visible.
    And this is the beginning of this little vga mod :
    3dmark11 : +14K
    3dmark06 : +41K
    3dmark05 : +50K
    3dmark03 : +187K
    3dmark01 : +126K
