hello,
i'm from belgium and 31years old.
here i whant to post my buildlog of my computer, hope you like the pics.
I also like to overclock some.
i do already pc work for 13years and it's a real passion of me.
Like to make parts that nobody has of have, or you don't can buy in a shop, to be exclusive.
so i hope some like what i will post here hahahaha
present my buildlog of my setup i'm buildling right now (already 6months working on it)
i found my case a little boring, so dicided to make it a little more nicer
i working now for some time already on my case mod,
[img width=800 height=500]http://i45.tinypic.com/wbqdmo.jpg[/img]
This build is made possible by and thanks to
Evga Taiwan
Thermaltake Taiwan
Angelbird Austria
Aquatuning Germany
Xtreme Case Mods Australia
Cooler Master Benelux
Zetix Belgium
what i make from this :
i made this :
and now i'm building the cooling in it, it looks like this how it is now :
I was in hospital for 1 month, and long time sick home, but now i am busy again on the mod :
Boreas chiller :
Video
http://www.youtube.com/watch?v=tg4mQPt8K-E
[ram]http://www.youtube.com/watch?v=W472AlaLsbA[/ram]
today only change the power for the led's in the Corsair HX1000 psu what i made see tru,
and put the first led's in the 5mm fan shroud for the boreas chiller :
PSU
De Boreas Chiller :
the boreas chiller is finished, no to the Freezone Elite and Freezone V1. :
new TEC plates in tha house, so now i can finish the Freezone V1 cooler :
the psu painting in black , de thermaltake for the TEC's :
the Coolit Boreas is finished, now the dual bay psu and the rest of coolers :
De thermaltake dual bay psu is also finished, pianted outside black, and inside silver for putting the light nice out,
only the psu front i need to put back :
painted because it looked like this in gold :
video
http://www.youtube.com/watch?v=VThbPrN9UPI
Koolance TMS-200 with expansion board modding :
I got some connector to short, need to order more
i customized the 3D fangrill so it fits on my Coolit Boreas Chiller :
This was how it looks standard :
And after the adjustment, who see the difference ???? lol :tong:
And this is how it going to fit in black and red on the Chiller :
Mounting for the Boreas Chiller made, was first the HDD trays.
Now made mat black acryl with behind the mounting plates for the boreas chiller.
And still need to finish it nice off and put holes for the cables of the boreas :
this is the difference of size between my old skulltrail (intel skulltrail D5400XS) and my current new one SR-2 5520 :
Now i made new holes for the motherboard spacers, and put tread in it for the spacers :
All nessesairy screws of the motherboard just fit nicely on the tray :
now only need the dangerden 10 PciE slot IO-shield :
And changing the backplates to for the Koolanc 360 blocks on cpu's :
Here's the 3d fan grill in primer with the adjustments for a little more airflow, ready to sand again :
the mounting for the Boreas chiller is ready exept for the holes to put the wires and tubing tru :
fan grill got it first paint job , is get dry now :
and the front plate for the drive bays has a primer :
and first paint job in mat black (just fresh, needs to dry) :
Little update,
Coolit Freezone Elite is ready to and cpu's are on the mobo ,
And here are some pics of the total view :
Two Koolance 360 rev1.1 , and Koolance SR-2 Classified full cover block are arrived :
after received it, let's open up the full cover block SR-2 and change it a little bit :
a lot of sanding it to get the nickel of it, and then the first layer of primer :
first layer mat black is on, tomorrow sanding it and paint it the last time for finishing touch,
after when it's dry mount the block again and put it on the motherboard :
SR-2 full cover block is ready and mounted :
from this :
i made these, and a little bit more, only waiting for a new shipment of red connectors :
The other cpu his power cable is also done, and the PciE cable also :
Total overview of the powercables on the motherboard, the green circle is where the cables leave the case to the other side for connection to the powersupply :
i used these ones :
And cut them smaller :
And use heatshrink to make the Black line on it :
new parts in :
Evga SR-2 1200w (peakload 1700w) psu
Due to U.S. regulation, power draw over a typical household 110-volt AC line limits the PSU-1300ATX-12N to 1300W. However, the unit is fully capable of a continuous 1700 watts when powered from a 220V AC circuit. Users are responsible for supplying adequate AC power for the PSU-1300ATX-12N.
PciE connector for GPU's with a 2200UF (MicroFarad) condensator and ferrit-cores :
Cpu ATX power connectors, also with 2200UF (microFarad) Condensator and ferrit-cores :
and te best part of the power supply is on the back of it lol :
Also LGA1156 socket isolation and new inox Backplates for my SR-2 :
also i got two red displays in for on my controller.
To swat the green light lcd out for a red symbol / black background display :
take a HB624 controller with ALMEGA88V chip :
put some cables and a pot meter on it :
with the pot meter 10K i can adkust the screen light :
To see real time the 12v rail of the SR-2 powersupply, and monitore the power drawn of the three coolit coolers :
cpu disable jumpers soldered for make the connector for it in front of the case :
need to cut new Socket isolation because SR-2 has no big condensators next to the sockets, so i can use some more isolation : :
putted also three temp sensors under the full cover blok, to measure the CPU PWM 1 en 2 and the NB temp
with a Koolanc TMS-200 controller :
total overview of the mobo in current state:
little testing en measurement, the boreas chiller and the freezone will be hanged on the power use controller.
but a lot of cables here that needs to be in the case fitted.
Alu plaat of 1.5mm is in, tomorrow making the adjustment of the mobo cover :
Today being busy with making place for all the usb cables, power led, hdd led etc to go away from mobo as fast as possible, not to show to much cables in case.
Also adjusting some things to get the mobo cover enlargement fitted on case,
used a lot of dremel cutting disks :
And because the Evga SR-2 mobo doesn't have condensators like a normal LGA1366 mobo around the socket, i needed to make some new socket isolation kits for around cpu with more amramflex, pictures will say enough :
And here you see the normal cut-out of a lga1366 socket kit and that for a Evga SR-2 mobo :
