So really, any of the older units could be redone with this mod and have it work for high load.
This one specifically is a 'vapo' build, though there's not a lot left of the original parts.
The compressor's now a NL9 instead of the original NL5.5 and the temps are better because of that, but the theory applies universally to any retail or custom cooler that's specced out for a 200w load.
So, for the mod, you'll need....
A vapo, mach2, or any cooler (of course)
2' of 3/8" copper tube
2' of 3/8" id tube insulation (13mm wall recommended, 10mm wall ok 6.5mm wall a bit thin, but still works better than not having insulation)
7' of .031" captube (unless the unit uses that or larger size already)
1 additional condensor, similar to the original one in the system.
Examples. Both around 120mm for ease of install.
1 additional fan, if you don't have a rear fan in the cooler (vapo's do)
1 new access valve (required)
1 additional new access valve (recommended)
Swagers or copper joiners in 1/4 and 3/8
or
3-4" of 1/2" tube (optional)
Some Rivets to refit the top of the case chassis (if applicable)
1 new filter dryer (highly recommended)
So the cooler's original configuration has a bit of space wasted, and there is no room for wasted space, so you will likely have to cut the parts on the original build. Recover the gas, and chop it up with long pipe 'tails' to make it easier to rebraze.
Lay the parts out so that you have a clear idea of the length of the new build, and that it will fit the case if you're doing a Vapo/Mach2 mod. Some custom cases have more length, and open builds won't matter, but it's a tight fit in a case, so it's better to know the length and size for sure.
When you know you're good for that, recut your pipe for the new brazing, and either use a swager to rework your pipe, use joiners for it, or (in this example) you can just cut very short sections of 3/8" pipe to join the 1/4".
For the 3/8" line (or 5/16 in some coolers) you will need the same gear, or you can chop short pieces of 1/2" tube to make joiners. Up to you.
So set up the lines and if you're doing this out of the case, use something to set the condensors to the approximate height you'll want them. Saves bending the pipe later, though 1/4" bends pretty easy. The condensor tubes are a lot thinner though, so it's better to just have it close to where it needs to be and not have to bend it much on the final install.
If you have it in the case, and the condensors are premounted then it's easy to braze in place. Just depends if you have the case apart.
So when you're brazed on the condensors (purge while brazing) you should have the compressor to one of the condensor's top inlets, then the bottom of that condensor into the inlet of the next, then to the filter dryer.
It's not critical which condensor you go to first. That is more about how your install is, where the best cool air will come from, how your fans run etc.
I strongly recommend that the air comes in both ends, so you should switch the rear fan to 'in' instead of 'out'. That way they both get cool air, so you'll get the best capacity out of them.
Vapo Cases have side venting so you don't need to cut blowholes. You can, if the air seems restricted (you'll get a lot of wind rush noise if it is) but it should be adequate.
For cases with no holes, you'll have to do something about it. On this one I just cut 2 80mm holes, and rivetted on some fancy 80mm fan guards. Open holes and good airflow, so I didn't add fans there. You can if you like, but more so if you can find room
So that's the condensor portion of the mod.
The suction line is a bit short, and the accumulator on Vapo/Mach is a bit small, so adding some volume there is recommended or you can get floodback at very low load.
So, you'll need to see where and how you have room for that.
Bend the 3/8" tubing into line that will replace the original suction basically adding as much length to the build that will still fit the case. I added around 18" of pipe to this one.
As long as it fits, and doesn't jam up into anything, it's fine. So you'll need to chop the suction, and 'plumb in' this new piece. Insulate before or after, depending on your skill at not burning the insulation
The captube mod can be anything that works out to 300+ watts, but in this case I use .031". It's common and easy to get. Any size is ok really, but .028" and smaller sizes end up pretty short. Vapo and mach original captube is usually .028 as far as I know.
So either you live with that, or replace the captube.
If you're going to just work with the original stuff, the results are a bit annoying, longer cooldown and such. And the slhx mods become a requirement at that point, the cap just needs the help.
For the replacement of the captube you can just 'tag' in the new stuff.
Measure your captube to around 7' of .031" if that's what you're using.
Cut the captube 4-6" away from the evaporator.
Fit the new captube to it, and cut a short piece of 1/4" pipe.
Crimp it around the 2 captubes, careful not to shut them, and slide them against each other, then pull 1mm apart so you're not blocking any flow, then keep pinching the flat of the 1/4" 'tag' until it's sealed pretty well.
Braze, but purge as you go, so that the flow isn't blocked when you braze, and of course, no crud in the tubes.
After you're done, you'll have a short piece of smaller tube, but it's not a huge concern. You can go shorter on the piece from the evap, but that little extra length gives you a second chance if you plug the captube. You can come down to 6.5' of new captube if you're going longer on the original stuff.
You can use any length you like, but this mod used this length and I know it works well for 375w.
Run your captube down the line as normal, wrap on the flex, then however you want/need on the solid line.
Braze into your filter dryer as normal. You may want to do that captube mod while you have the line chopped out. Easier to insulate if you want to use non split insulation. You can split it and either use tape to refit, or rubber cement works well to join the split insulation too.
If you're using the .028" captube, you'll have to come down to 5.5' at least to hold high load. 5' is really the limit of how short any captube should be, and any shorter can give serious grief. I haven't tested 5' of 28 and don't recommend it much, but if it's what you have, you can try it, and see how much capacity you can get out of it. you should really uncoil the captube, measure as close as you can, and chop it down. If it just won't give a good result you can always replace the captube with another size, as stated.
If you're modding a Mach2 with it's original head, I don't know it's capable of working with high load. I've never tested it and it's pretty awful really so I do recommend a new evaporator. If you're replacing the evap, then just running a new length of captube is easy.
On existing evaps of good quality and original Vapo evaps (that are actually quite good and should work to 300w), tagging in the new captube is a much easier option than drilling and replacing. there's just too much risk of copper shavings in the evap, and cutting open the evap and reworking it is really more hassle than it worth. 4" of 28 is similar enough to 6" of 31 (give or take) so you'll end up with around 7.5' of total .031 captube when you're done, and that's working for me as a 350w (give or take) capacity mod.
So you're going to look something like this when it's done.
Once you're assembled and brazed, you could consider some slhx options.
There's usually no room to put a real suction line heat exchanger in a case, but you can enhance the heat transfer of the captube with some soft solder, or in many cases, just tape and thermal paste.
I've set up accumulators like this.
Or you could look at this variation of captube on the solid suction return pipe.
Or if you aren't a good plumber, or don't have soft solder and don't want to braze the captube to the return pipe, taping with paste is also an option, if you have a nice big tube of cheap paste. Brazing or soldering gives much better heat transfer though.
So that's the brazing done, the slhx mod in there, the new condensor added.
Or this, with an insulated slhx in a small package.
Vac and charge.
I recommend a load tester to confirm, but if it's very close to what I've done with this one, it should end up over 300w.
On charging at no load and ambient of 22c, I charged it with a static pressure of around 40psi.
Then running with the fans and insulation cut back to monitor, I ran it unloaded, slowly charging until I was frosting to, but not into, the compressor return.
This is pushing just a bit, prefer if it's not frosting the compressor unloaded, but gives an idea. This one wasn't flooding back though, thanks to the accumulator/hx mod enhancing the heat exchange and making sure it's just vapor coming back. Frost doesn't mean liquid, just means cold. But it's more ideal if the frost is just at the compressor instead of freezing it just a bit.
That gives you a 'ghetto' method of charging to your max capacity that won't flood back.
If you are flooding back you'll hear the 'popping and clicking' noise that goes with it so it's pretty easy to tell.
I did that on this one, and I got a little over 375w of capacity, which should be adequate for 6 core full load benching. Small changes to the numbers I've listed should give a very similar capacity, but size differences in the compressor, or changes to the length of suction return from what I've stated with increase/decrease your capacity. I prefer a system that won't flood back even with no load, but some think that's ok if it's just a 'benching system' and will always have load when it's running.
I'll leave that up to you, and will only recommend that if you don't quite have the capacity you need with a maximum charge that does not flood back, you may have to add more suction volume (longer pipe, larger or additional accumulator) or further enhance suction line heat exchange.
That's the works. Takes a lot longer to explain than to do the mod, and even if you don't have a load tester, you can do the final charge to max, and get a good result.
You'll know for sure if you have enough capacity to run your 6 core cpu when it's attached, and if you're looking for the 'best' result you can tune it right on the cpu. Just be careful if you're slowly adding/removing gas so you don't spike the temperature on load and kill the cpu.
No 'guarantee' that this mod works, but it works for me, every time, to get 300 to 375w of total capacity using the captube and condensor mod, with the higher capacity range more likely doing the captube heat exchange mod along with it.
Hope it helps whether pro builder or amateur, the mod is ideal and the vapo/mach2 coolers can still perform as fairly quiet 24/7 units.
I've added some pics with compressor temps at time of load tests, to give an idea of compressor temp and strain.
Started by running 3 hours at 375w, then changed every half hour down to the next lower wattage to ensure full temps on running tests.
Temp results for the 1/4hp unit were -20 evap 350w -40 0w
Temp results for the 1/3hp unit were -25 evap 375w -45 0w
Both tested with R290. Ymmv using other gasses. 290 works well since the condensors are smaller and 290 is light so head pressures and condensor heat is lower. Better condensors would make colder gasses easier to work with.
This mod with the condensor I used gave about 3-4 degrees over ambient on the filter (won't bother with subcooling figures, for those that don't understand them) and the closer to ambient condensing temp, the better your system will work with higher capacity and colder evap temps. So a colder gas may look better, but in actual use it may perform poorly. This is how this one works with this gas.
Gray
Edit, a few more pics added, will try to finish up asap, and keep replacing with better pics as I go.
If anyone has some good pics of their version of this kind of thing, feel free to post No threadjacking here, anyone willing to share their tricks (or secrets, if you think about it that way) is more than welcome to throw in.
