Hey guys,
When overclocking memory I used to use memtest86 and memtest86+.
But out of convenience I started using Win7 memory diagnostic tool.
Is this a sufficient tool for testing stability of memory?
Thanks,
Drizzt
Hey guys,
Thanks,
Drizzt
CPU:Q6600 G0 @ 3.825
Motherboard:Asus P5E X38
Memory:2x2GB OCZ Reapers DDR2 1066
Graphics Card:Asus 4850
Hard Drive:2xSegate 500gb 32MB Cache raid0
Power Supply:Xion 800W
Case:3DAurora
CPU cooling: D-tek Fuzion V2 (Quad insert removed)
GPU cooling: mcw60
Monitor:24" LG
I'd stick with memtest, even Linx/IBT stresses memory quite well..
Another thing I find funny is AMD/Intel would snipe any of our Moms on a grocery run if it meant good quarterly results, and you are forever whining about what feser did?
Case:3DAurora
GPU cooling: mcw60
Monitor:24" LG
+1 memtest86+
I never tried the windows 7 memtest tool I've always used memtest86+, I have for years, I trust it well, and it's very well know & used by most.
Sandy Bridge 2500k @ 4.5ghz 1.28v | MSI p67a-gd65 B3 Mobo | Samsung ddr3 8gb |
Swiftech apogee drive II | Coolgate 120| GTX660ti w/heat killer gpu x| Seasonic x650 PSU
QX9650 @ 4ghz | P5K-E/WIFI-AP Mobo | Hyperx ddr2 1066 4gb | EVGA GTX560ti 448 core FTW @ 900mhz | OCZ 700w Modular PSU |
DD MC-TDX CPU block | DD Maze5 GPU block | Black Ice Xtreme II 240 Rad | Laing D5 Pump
Case:3DAurora
GPU cooling: mcw60
Monitor:24" LG
Try run command rate 1, if not its ok.. I havent overclocked a 775 since my old Q9650, use to love overclocking back then was alot more trickier compared to now... Anyways leave timings loose find your Highest overclock and tighten timings once your happy with your overclock..
Stacker830 Watercooled
windows7 ultimate 64 bit!!!
heatkiller(rev3) on 2500k@ 4.5ghz 1.35v,8 gigs 2133 ripjaws 1.5v
Swiftech Mcp-655,1/2in tygon,13x120 sunnons on junk ps,
(2)triple 120mm rads,Biostar TP67XE(rev 5.2)
150 gig velicraptor (stable drive) ssds r still buggy!!
xfi-xtrememusic,klipsch ultras, sen hd-595s
Evga Hydro gtX 590,co0lermaster-1250 watt,
24" Sony fw-900 black ops at @ 2304x1440 85hz/85fps SOLID
G@m3r 4 L1Fe!!
http://s76.photobucket.com/albums/j1...0VIEW%20ALL--/
3dmark 11 http://3dmark.com/3dm11/1102387
Case:3DAurora
GPU cooling: mcw60
Monitor:24" LG
HCI memtest (its a windows GUI) WAY better than memtest86/+
"Prowler"
X570 Tomahawk | R7 3700X | 2x16GB Klevv BoltX @ 3600MHz CL18 | Powercolor 6800XT Red Devil | Xonar DX 7.1 | 2TB Barracuda | 256GB & 512GB Asgard NVMe drives | 2x DVD & Blu-Ray opticals | EVGA Supernova 1000w G2
Cooling:
6x 140mm LED fans, 1x 200mm LED fan | Modified CoolerMaster Masterliquid 240
Asrock Z77 thread! | Asrock Z77 Extreme6 Review | Asrock P67 Extreme4 Review | Asrock P67 Extreme4/6 Pro3 thread | Asrock Z68 Extreme4 thread | Asrock Z68 Extreme4 Review | Asrock Z68 Gen3 Thread | 8GB G-Skill review | TK 2.ZERO homepage | P5Q series mBIOS thread
Modded X570 Aorus UEFIs
Yeah, number of instances equals number of cores. Just make sure to assign (total memory - size allocated by Windows)/number of cores to avoid testing your pagefile instead of memory. Failing to do so will lead to Memtest writing to the pagefile more than actually stressing the memory.
..:Core i7 870///eVGA P55 Classified///VTX3D Radeon 6970///Asus Xonar D2X///16GB F3-12800CL9D-8GBXL///WD 6400AAKS 640Gb///Samsung F2 EcoGreen 1.5TB///Samsung F4 EcoGreen 2TB///Pioneer DVR 216///Seasonic X-series 850///Corsair Obsidian 800D///Logitech G15 rev.1///Logitech G400@Zowie G-TF Spawn///Philips 240SW:..
..:EK Supreme Acetal///Bitspower Black Freezer EIP55NSC///Magicool Pro III///S-Flex E@7v///Laing DDC-1T w/ EK Plexi top///EK Multioption 150:..
Any memory test that run under gui or windoze will never beat memtest86+ in term of range and flexibility.
Just a simple example, how the heck that program able to test the ram occupied by windows os kernel or other bloated os code that is not swappable ? Guess you will never understand this either, don't you ?
Is HCI Memtest an in-OS memory tester? I'd love one of those so I can do quick tweaks.
Signatures make my posts look huge... but I'm not humble enough to completely remove my signature, so I kept this note explaining it.
Yeah, your screwed if the memory error just happens to be used up by the OS.
This is why it is much better to use a program that uses as small of a footprint as possible, so you can test ALL your RAM, not just X - OS - all the other drivers/resident programs that got loaded.
I always start testing with a blend test using Prime95 and a mem test using Burn In. After finding stable options, I verify using memtest. It is just my process, but it seems to treat me well.
