Page 1 of 2 12 LastLast
Results 1 to 25 of 32
Thread: My 1100T has arrived
    Oct 2010
    Any speculations how it will clock on a CIV with 8 GB of me (2*4GB). It will be aircooled with a Thermalright Venomous X w/upgraded fan
    May 2004
    Quote Originally Posted by Dirk Diggler View Post
    Nope, because we don't know your ambients, what PSU you'll use, if you will put it in a well ventilated case and so on. And even then it wouldn't make any sense to speculate IMHO.
    Oct 2010
    Quote Originally Posted by LowRun View Post
    PSU - Corsair Ax-850
    Ambients ~21.6
    Case - Lian-Li PCA77F
    Guess I need to draft up a sig with all that information...
    I am Xtreme
    Dec 2008
    France
    Should be able to get past 4GHz easily, likely to get to 4.2, hard to predict anything ahead of that.
    Donate to XS forums
    Oct 2010
    Either I dont know what I am doing, I suck at buying chips or my board is holding me back LOL. Wont do 4.2 with any reasonable voltage. Right now I am trying to get it stable at 4125 after that I will see how well the NB/CPU does.
    Xtreme Mentor
    Feb 2009
    Bangkok,Thailand (DamHot)
    1100T Still not appear in Thailand
    Intel Core i5 6600K + ASRock Z170 OC Formula + Galax HOF 4000 (8GBx2) + Antec 1200W OC Version
    EK SupremeHF + BlackIce GTX360 + Swiftech 655 + XSPC ResTop
    Macbook Pro 15" Late 2011 (i7 2760QM + HD 6770M)
    Samsung Galaxy Note 10.1 (2014) , Huawei Nexus 6P
    [history system]80286 80386 80486 Cyrix K5 Pentium133 Pentium II Duron1G Athlon1G E2180 E3300 E5300 E7200 E8200 E8400 E8500 E8600 Q9550 QX6800 X3-720BE i7-920 i3-530 i5-750 Semp140@x2 955BE X4-B55 Q6600 i5-2500K i7-2600K X4-B60 X6-1055T FX-8120 i7-4790K
    Xtreme Cruncher
    Apr 2008
    Ohio
    I had mine on air and 4.1ghz was stable, but I don't think 4.2 would have been. I wasn't using any high end air though. I would call that a good OC if you can get all six cores stable with a decent voltage. Anything higher may be a stretch for 24/7 stable.
    ~1~
    AMD Ryzen 9 3900X
    GigaByte X570 AORUS LITE
    Trident-Z 3200 CL14 16GB
    AMD Radeon VII
    ~2~
    AMD Ryzen ThreadRipper 2950x
    Asus Prime X399-A
    GSkill Flare-X 3200mhz, CAS14, 64GB
    AMD RX 5700 XT
    I am Xtreme Ket's Avatar
    Apr 2004
    United Kingdom
    Theres quite a few places you can get the 1100T from in the UK, although I don't think £220~ is worth the extra 100MHz over the 1090T, which you can get for ~£170. Still though, be interesting to see what the 1100T can do. My bet is on its a super binned 1090T and won't clock that much better, if at all.
    "Prowler"
    X570 Tomahawk | R7 3700X | 2x16GB Klevv BoltX @ 3600MHz CL18 | Powercolor 6800XT Red Devil | Xonar DX 7.1 | 2TB Barracuda | 256GB & 512GB Asgard NVMe drives | 2x DVD & Blu-Ray opticals | EVGA Supernova 1000w G2
    Cooling:
    6x 140mm LED fans, 1x 200mm LED fan | Modified CoolerMaster Masterliquid 240
    Asrock Z77 thread! | Asrock Z77 Extreme6 Review | Asrock P67 Extreme4 Review | Asrock P67 Extreme4/6 Pro3 thread | Asrock Z68 Extreme4 thread | Asrock Z68 Extreme4 Review | Asrock Z68 Gen3 Thread | 8GB G-Skill review | TK 2.ZERO homepage | P5Q series mBIOS thread
    Modded X570 Aorus UEFIs
    Oct 2010
    So far it was worth ~100 MHZ@ around the same voltages of my 1090T. The deal breaker for me will be what the northbridge does so far i have it at 2500 chugging away at 1.23 volts for 3 hours.
    Apr 2004
    United Kingdom
    IMO unless you can get the NB to 2800~ you won't see much of a advantage, if any. There will be too much bottlenecking and bus saturation going on.
    "Prowler"
    Cooling:
    Oct 2010
    Quote Originally Posted by Ket View Post
    Yeah i am hoping for 3000 I am still stability testing 4.1* and 2500 it just passed 3 hours so I am gonna take it up a little more to 2750 and test again.`
    Apr 2004
    United Kingdom
    Fingers crossed for 2750+ She will start to fly if you can make it past that.
    "Prowler"
    Cooling:
    Oct 2010
    Quote Originally Posted by charged3800z24 View Post
    The thing that pisses me off the most is that all the chips I buy seem to be voltage hungry compared to similar setups. I checked the 1100T thread and seen you was able to do 4.17 @1.47. If I lowered it to this voltage prime95 will run for 6 minutes before blue screening and rebooting
    Apr 2004
    United Kingdom
    You sure cooling isn't a issue? My Deluxe3 needed huge amounts of chipset voltage until I ripped the cooling off, lapped it, reapplied some TIM and remounted everything with screws and nuts. In your case, the FETs may just be getting pretty hot, thus needing more voltage to stay stable because of exess heat.
    "Prowler"
    Cooling:
    I am Xtreme FlanK3r's Avatar
    May 2008
    Czech republic
    show for us some benhcmakrs etc . I will began 27th with my tetsing
    ROG Power PCs - Intel and AMD
    Oct 2010
    Nothing impressive thus far. The Cinebench 4.2 runs with my 1090T were unstable just stable enough to complete a bench
    Oct 2010
    CPU/NB@3000
  18. #18
    Oct 2007
    Singapore
    Quote Originally Posted by PatRaceTin View Post
    you always can cross the border and get it in Malaysia...
  19. #19
    Oct 2010
    Tomorrow I will take the day off to pull the heatpipes and give them a little TLC. It took 1.30 to get the NP/CPU stable. 2750 ran all day at 1.24
  20. #20
    Oct 2010
    Got the NB stable @ 3.0 ghz temps dont exceed 55* C and the mem is running at 1666 up from 1333. Tonight I will remove the heatsinks on the board and reapply some TIM
  21. #21
    Apr 2007
    Thermalright Venomous X nevermind missed it. How do you like this cooler? How high can the stock cooler take X6's?
    i3 2100, MSI H61M-E33. 8GB G.Skill Ripjaws.
    MSI GTX 460 Twin Frozr II. 1TB Caviar Blue.
    Corsair HX 620, CM 690, Win 7 Ultimate 64bit.
  22. #22
    Jul 2009
    have you ever tried just OC'ing by changing the multipliers instead of HT? could possibly lead to lower voltage requirements as perhaps you run into a wall.
  23. #23
    Oct 2010
    Quote Originally Posted by Glow9 View Post
    You could prolly get to about 3.6-3.7 on the stock cooler as that is where turbo will take you but anything beyond tht will genereate to much heat. Yes I like the cooler I did upgrade the fan to a Scythe F series fan for better cooling and it seems to be doing well
    Quote Originally Posted by Shadowized View Post
    When I has the HT@200 I was running into the same problems
  24. #24
    Oct 2010
    Few benches on some stable settings at 4.172 NB@3034 mem @ 1680@9-9-9-24-27-110ns
  25. #25
    Xtreme 3D Team
    Jan 2009
    Ohio
    I really want to know where this 2750 number came from. rule of thumb is that you want a 1.5:1 to 2:1+ nb/ram ratio for optimal efficiency.
    Nothing special happens as soon as you hit 2750...or 2800. Some real bandwidth pops up at 3000+.
    Smile
