Got my rig on WCG for you fellas again, mainly cause my room is cold . Also doing GPU F@H for XS as well.
Quick Q though, my client is sitting here at Scheduler request pending, requested by user. Is that something on my end, or no?
Nick
Nick
Core i3-550 Clarkdale @ 4.2GHz, 1.36v (Corsair A50 HS/F) LinX Stable
MSI H55-GD65 Motherboard
G.Skill 4GBRL DDR3-1600 @ 1755, CL9, 1.55v
Sapphire Radeon 5750 1GB
Samsung F4 320GB - WD Green 1TB
Xigmatek Utgard Case - Corsair VX550
Just wait for it to connect. Make sure you have your network settings right, ie if you use a proxy make sure that's in the client settings, if you use a firewall make sure boinc.exe (I'm assuming you're running Windows) has access.
[SIGPIC][/SIGPIC]
Welcome back, you are allowed to run as many heaters as you wish
My Biggest Fear Is When I die, My Wife Sells All My Stuff For What I Told Her I Paid For It.79 SB threads and 32 IB Threads across 4 rigs 111 threads Crunching!!
Got it. Under "activity" I had to set Run Always and Network Activity always available, whoops haha. Thanks.
back, good to see some guys return.
XSWCG Disclaimer:
We are not responsible for the large sums of money that you WILL want to spend to upgrade and add additional equipment. This is an addiction and the forum takes no responsibility morally or financially for the equipment and therapy cost. Thank you and have a great day.
Sigmund Freud said... "Failure to CRUNCH is a sign of Sexual Inadequacies".
Thanks fellas.
