Both of those ram kits are rated CAS 9 at DDR3 DDR1600 and you say +1600 so I doubt looking at either of the kits you mention for tight timings unless CAS 9 is thought of as tight with DDR3 ram. Others may have tested and see if differently.
Back and forth from board to board it seems.
AMD likes tight timings so go something like ripjaws or gskill PI's ..
Another thing I find funny is AMD/Intel would snipe any of our Moms on a grocery run if it meant good quarterly results, and you are forever whining about what feser did?
I got the 4Gb x 2 G.skill flare and so far they run @ 200MHz without a hitch.
Cooler Master HAF932
1200w PC Power & Cooling
AMD Phenom II X6 1090T Black Edition
ASUS Crosshair IV Extreme
8Gb G.SKILL Flare (4Gbx2) @ 2GHz
2 ATI Radeon HD 4870X2's w/ AC Accelero XTREME Cooler
128GB Crucial RealSSD C300
2Gb Hitachi Deskstar(storage)
2 ASUS DVD/RW
Logitec G15 Gamer (old style)
Logitec G9
Motherboard: MAXIMUS IV EXTREME rev. B3
CPU: INTEL i7-2700k @ 5400Mhz
Watercooling: Swiftech H20-320 push-pull 6x120 mm
Memory: G.Skill F3-17000CL9D-8GBXLD 2133MHz 9 11 9 28 2N
Graphic Card: Crossfire ASUS HD 7970 3Go @ 1200/1800 / VTX 7950 3Go @ ont sais pas
Sound card: Sound Blaster X-Fi Titanium Fatal1ty Champion Series
Power supply: Corsair AX-850
SSD: OCZ Vertex 3 120Go (o.s)
HDD: WD 600Go Velociraptor (games)
HDD: WD 500Go caviar black (stock)
HDD: WD 200Go caviar black (save)
Case: ATC'S 840 porte pléxi
Rhéobus : Lamptron FC5
Cooling : 1x230mm 1x140mm 3x120mm
Keyboard: Logitech G510
Mouse: Saitek Cyborg R.A.T. 9
Screen: HANNS-G 28" x 3 eyefinity
Headset: TTeSports SHOCK ONE 5.1 Gaming, Plantronics Gamecom 777
O.S: Windows Se7en 64 Bit
