Ln2 requires a dewar. Typically, dewars the most expensive part ranging from $150 to $500.
I would definitely run DIce first. I just glanced through this thread but to sum things up on my end:
1. One only person is necessary. It would help to have another, but is not required.
2. I've seen a lot of talk of this; acetone does
not evaporate at -70*C so fumes are only there are room temp.
3. I've seen talk elsewhere that the F1EE isn't a good DIce pot. That's totally false. I ran it today for the first time an i7 920 (a very high leakage one) and temps were great.
4. I've only ever seen the older silicon and Evga 1366 boards CB on DIce. Phenom II's, C2D and C2Q, 1366, 1156 are all perfectly fine to run on Dice, with the correct board.
Best of luck. Once you get this frosty afterwards, you will be hooked.
