+ Reply to Thread
Results 1 to 4 of 4
Thread: E6500 2.93GHz only runin at 1.6GHz
    Dec 2010
    0
    Hey all i have a problem and any advice would be very appreciated.
    first im going to start off with the problem then list my hardware specs.
    i have a program easytuner (provided by gigabyte) a program that lets you
    overclock in windows. im not really going to use it to overclock but i opened
    it and saw that my cpu is a 2.93 GHz and is only runin at 1.6 or 1.7GHz.
    can anyone tell me why this is??
    Ive opened my bios and checked and my cpu frequency is correct at 2.93GHz
    System specs:
    Intel Pentium(R) Dual-Core E6500 @ 2.93GHz
    Gigabyte GA-EP45t-USB3P
    2GB DDR3 PC3-1066 1333MHz (Patriot)
    ATI Radeon HD 5770 (XFX)
    Xtreme Enthusiast donmarkoni's Avatar
    Nov 2008
    5
    Hi!
    Check if it goes up when you stress test it. You can download LinX from here.
    If it does, then it's cause of EIST and/or CxE enabled in BIOS
    Personally, I like power saving features and don't mind having them active even while overclocking.
    Maximus 5 Gene | i7-3770K @ 5GHz | ADATA 2x2GB @ 2.6GHz 9-12-10-28-1T | HD7970 @ 1200/6400
    Rampage 4 Extreme | i7-3930K @ 5GHz ||| X58-A OC Orange | i7-980X @ 4.6GHz
    Xtreme Member OCBalmang's Avatar
    Sep 2010
    New brunswick, Canada
    0
    it sounds like your board could be under volting your cpu if you have everything on auto, you shouldn't ever let your board control your hardware voltages without your consent on the voltages chosen.
    Qx9650 4052.9MHZ 1.32Vcore ON AIR
    1600 6-6-6-18 super talent(speed series) MGH-E hypers!
    WOOT!
    I am Xtreme Leeghoofd's Avatar
    Sep 2006
    19
    6 x 266 : 1.6Ghz, it's definetaly EIST, CEIST or whatever they want to call it... seems a sortlike question returns every few months :p
    Question : Why do some overclockers switch into d*ckmode when money is involved
    Remark : They call me Pro Asus Saaya yupp, I agree
+ Reply to Thread
Tags for this Thread
