Does anyone have a CAD of one of their pots they would share? I wanted to run a few simulations using COMSol and Solidworks to see a performance comparison to the one I have been mocking up.
PM me if you are willing to share,
Cory
Cory
What if the hokey pokey really is what it is all about?
I have a few mock ups of some well known designs from various builders. I'll try to dig up the files and send you a PM when i have them.
Gaming Setup
Intel X3440
Gigabyte H55n USB3
2x4gb Mushkin 996999
EVGA GTX 580
Silverstone Sugo SG-05
Corsair H60 w/ Push/Pull AP15s
Seasonic SS-560KM 560w
is it for cpu or gpu? i have designs for both cpu and gpu, but my gpu design is special and dont want to share it before i have manufactured it! PM me if you want the cpu design.
voklskier4452 i would like those designs too! if you find them please PM me. thanks
i7-980X @ 4GHz | GTX580 DirectCU II | X58A-OC | XMS3 1600MHz CL7 | HX1000W | Intel 510 120GB
Meeee tooooo!!!! please
well, heres a teser of my pots!
One of the better DI containers out there, REV2 Mousepot. Jason aka Mickey Mouse shared his design drawing a few years ago. To modernize it, you could make it a split material design (CU/ALU) that would save machining time and headaches, as well as material cost. Some people may not like a flat base, but for DI it's hard to beat. A drilled base will usually clog where this will not.
Sorry guys was unable to get to my files for a while as I had some rig troubles. Will upload my files when i get off work tonight.
Gaming Setup
Intel X3440
Gigabyte H55n USB3
EVGA GTX 580
GHZ how would the load holding be on that pot? not very much surface area for heat dissipation....
980X @ 5200 idles @ -68 or so, in Vantage CPU test you loose around 8° by the end of each test. You might do slightly better with a drilled base on a clean container, but as the session goes on you have to fight clogging which ultimately will make things worse.
Any more CAD designs ... please
I will make them locally not for sale ,for personal use.
voklskier4452 any news on the pot designs?
I just stumbled onto an old album on my photobucket. all my old cad designs are pictured there as well as some other stuff. Please keep in mind some of these designs were purely just me learning solidworks so they wont make any sense from a physics or machining standpoint.
The other thing is I did at one point try to recreate some more famous pot designs so if you see anything that looks like a blatant rip off, thats because it is.
http://s471.photobucket.com/albums/r...52/solidworks/
Gaming Setup
Intel X3440
Gigabyte H55n USB3
EVGA GTX 580
