Results 1 to 8 of 8
Thread: Need help choosing lens.
    I am Xtreme
    Jul 2007
    The Sacred birth place of Watercooling
    So i want to learn to shoot music gigs.
    Firstly i would love to hear any tips for this type of photography
    and secondly i guess i will need the right tools to get the shots so...
    Im not sure which lens i will need for that. Atm i can only afford one Good quality Lens.
    Details:
    Camera D7000
    I will be getting a FLASH just not sure which one sb700 or sb900?
    Not 100% sure but from what I've been told
    Small stage/Venues
    Low light venues.
    I will have access to most if not all areas.
    Lenses i had in mind
    24-70 2.8 = 36-105
    24-120 f/4 VR = 36-180
    70-200 2.8 VR2 = 105-300
    Budget is $2000
    I was deciding between the 24-70 2.8 and the 24-120 f/4 VR
    As i thought i would need the range/zoom as i don't want to be in the face of the performers.
    I was leaning towards the 24-120 f/4 VR
    I'm assuming the venues will have low/bad quality light.
    So yeah there's my dilemma
    suggestions and help is appreciated
    cheers!
    Quote Originally Posted by skinnee View Post
    No, I think he had a date tonight...
    He and his EK Supreme are out for a night on the town!
    Dec 2007
    NYC
    For concerts, especially if you're not going to be near or on stage, you're best bet is the 70-200 F/2.8. It'll give you the most reach, which in turn gives you more flexibility in where to shoot from. Avoid the 24-120 F/4, as shooting concerts means often shooting in low and challenging light. VR can compensate for static subjects, but if you want sharp shots of the performers, you'll need the faster glass to get a fast enough shutter speed. VR can't freeze action like a fast shutter speed.
    Also keep in mind that rapidly changing stage lighting can add to the challenge of shooting concerts. Auto ISO will be you're friend, as will a wider aperture range (another reason to opt for 2.8 glass.) VR can be useful in some creative applications, say where you want some motion blur from the performers but not from the static objects on stage.
    Lastly, keep in mind that the lenses you've chosen are all full-frame / FX format. The 70-200 is a great bet for both formats, but the focal lengths of the standard zooms you've chosen (the 24-70 and 24-120) don't translate well to the DX format, as they loose much of their wide angle perspective. Do you have plans to upgrade to a full frame camera down the road? If not, consider the 17-55 2.8 DX instead of the 24-70 or 24-120 for a more useful standard zoom focal range.
    ** REBUILD IN PROGRESS / RIG SOON TO BE**
    i7 990x Gulftown cooled by a HeatKiller V3.0 / swiftech MCR-320 / Laing DDC-3.2
    ASUS Rampage III Black / 24GB (6 x 4 Gig) G.Skill Ripjaw 1600mhz CAS9 / 2x nVidia GTX-460s in SLI
    Corsair HX-1000 PSU / Corsair Obsidian 800D Case
    Crucial C300 256GB SSD / 2TB WD Caviar Black 64MB Cache SATA 6 Drive / 2x 1.5 TB Seagate 7200.11 drives in non-boot RAID 1 / LG BluRay/HD-DVD combo / LG BD-RE Drive
    Dell 2407 WS Monitor / Logitech Z-5500 5.1 THX Speakers / Windows 7 Ultimate x64
    Nov 2008
    Heart of Europe
    Focal range is up to you and up to how far you will be from stage. Some ppl are almost on it, so they shoot with wide-angles.
    Though, what you need is fast lens, so f2.8 and less is good (yes its possible to shoot even with fixed lens, not zoom, just need bit of space to move and practice). D7000 has very impressive high-iso, but I would still prefer fast lens.
    70-200 is considered as "must" for this kind of photos. Though, remember, it will be 105-300 in terms of FF field of view. But usually isnt problem to get bit far away from stage.
    i7 930 D0 - 4,2 GHz + Megashadow
    3x4GB Crucial 1600MHz CL8
    Foxconn Bloodrage rev. 1.1 - P09
    MSI HAWK N760
    Crucial M500 240GB SSD
    SeaGate ES.2 1TB + 1TB External SeaGate
    Corsair HX 850W (its GOLD man!)
    ASUS STX + Sennheiser HD 555 (tape mod)
    Old-new camera so some new pics will be there.. My Flickr My 500px.com My Tumblr
    Xtreme Guru
    Mar 2004
    steelcity.pa.usa
    Honestly I'd go with nikon 35mm 1.8 dx; nikon 50mm 1.8; rokinon 85mm 1.4; nikon 80-200mm 2.8
    That will bring you in well under $2000. If you're going to use a flash you'll want the 800 or 900. The 6/700 will be near useless in mid-large size venues.
    STARSCREAM
    3570k @ 4.6 GHz | Asus P8Z77-V LK | G.Skill F3-12800CL8D-8GBXM | ASUS GeForce GTX550 Ti
    Corsair Neutron GTX 240GB | Corsair Force GT 120GB | SK hynix 128GB | Samsung 830 64GB
    WD Black 640GB (3) | Seagate 7200rpm 1TB | Dell Perc H310 xflashed to LSI 9211-8i
    Corsair AX750 | CoolerMaster Hyper 212 | Antec P280 | Dell Ultrasharp U2410 | BenQ XL2420T
    ROCCAT Savu | Filco Majestouch-2 TKL w/Cherry MX Reds
    MEGATRON
    3770k @ 4.5GHz | Asus Sabertooth Z77 | G.Skill F3-12800CL8D-8GBXM
    SK hynix 128GB | Mushkin Enhanced Chronos 60GB | WD Red 3TB (4) | Seagate 7200rpm 3TB (2)
    WD Green 2TB (3) | Seagate 7200rpm 1TB | Dell Perc H310 xflashed to LSI 9211-8i (2)
    Corsair AX650 | Corsair H80i
    I am Xtreme
    Jul 2007
    Quote Originally Posted by theYipster View Post
    Thats the exact answer i needed as i was a lil confused with VR and Speed.
    Yeah i realized i choose the FF Lenses and the plan is to go FF in 2 years.
    I did have the 17-55 2.8 in mind but atm i can only afford 1 pro lens. If i had the $ i would go the 17-55 and the 70-200.
    Quote Originally Posted by Mescalamba View Post
    Yeap. so 70-200 should be in my bag.
    Quote Originally Posted by itznfb View Post
    I own the 35mm 1.8 but not the other primes/zoom. Could i get away with a 35mm 1.8 and 50mm 1.4 (borrowed) and a 70-200 2.8?
    As for flash i will get the sb900
    cheers
    Xtreme Guru
    Mar 2004
    steelcity.pa.usa
    Quote Originally Posted by disruptfam View Post
    cheers
    You could get away with just a 35 or 50mm. The longer the focal length the more light you need which is why I suggest the 85mm.
    If you already own the 35 then the 70-200 vr1 and rokinon 85 are still within your budget.
    Sent from my Samsung Galaxy S
    STARSCREAM
    MEGATRON
    I am Xtreme
    Jul 2007
    Cheers thanks for the tips ^
    I cant get rokinon locally though
    Xtreme Guru
    Mar 2004
    steelcity.pa.usa
    Rokinon is also manufactured under other names like Opteka. These lenses aren't as good as the nikon/canon version but in a concert setup with lots of dark strangly lit shots you won't really need the higher IQ of the name brand lenses. The rokinon is the only (non nikon) 85mm I've had experience with and its actually quite good.
    STARSCREAM
    MEGATRON
