http://slappablog.wordpress.com/2010...arks-3dmark06/
Opened up the window last night and let the winter air flow:
This is single card only. The 5870 was running at 900MHz/1300MHz.
ooo, nice score!
ROG Power PCs - Intel and AMD
You gotta love winter. If you can, try using Vista 32bit for 3d mark 06. CPU score will be lower but total score will be quite a bit better. My thuban runs 4.5GHz on all cores through 06 with a bit of cold air through the rad and it ain't one of the best. Keep pushing it.
Asus Crosshair V Formula-Z | FX 8350 | 2x4GB Trident-X 2600 C10 | 2x ATI HD5870 Crossfire | Enermax Revo 1050watt | OCZ Vertex 3 60GB | Samsung F1 1TB
Watercooling: XSPC Raystorm | EK 5870 Delrin fullcover | TFC X-changer 480 w/ 4x Gentle Typhoon | DDC2+ Delrin top | EK 200mm res | Primochill LRT 3/8 tubing
Case: Murdermodded TJ-07
sub 9 sec. SPi1M 940BE 955BE 965BE 1090T
You lucky Albertans, over in BC it's just wet and mild...
X6 1090T (1010MPMW) @ 4267MHz 1.44V NB@3229MHz 1.33V | Asus Crosshair IV Formula | 2x2GB Corsair Dominator GTX2 @ 1845MHz 6-6-5-17-22 1T | Asus HD4890 @ 1050/4800 | Corsair HX850W | HAF 932
EK Supreme HF | EK-FC4890LT | MCP655 + Koolance D5 Top | ThermoChill PA120.3 + 3x Enermax Magma | XSPC Bay res | Masterkleer 1/2" UV Red
Thanks!
Yeah I'm thinking of switching over to vista or win 7 for benchmarking. higher 3d and less stress loading OS. Then I can also do vantage
If i push the voltage I can get 4500MHz
muhahaha. We get some nice days to take advantage of the cold air for overclocking. Last year I was OCing on -27C ambients
I will push it again when I have time Wish I could tonight but I gotta get sleep for an exam tomorrow.
Ok, cause i'm the kind type of person, i'll give you something to shoot for:
Cheers
wow i want some 8C ambient!!!
Intel Core i5 6600K + ASRock Z170 OC Formula + Galax HOF 4000 (8GBx2) + Antec 1200W OC Version
EK SupremeHF + BlackIce GTX360 + Swiftech 655 + XSPC ResTop
Macbook Pro 15" Late 2011 (i7 2760QM + HD 6770M)
Samsung Galaxy Note 10.1 (2014) , Huawei Nexus 6P
[history system]80286 80386 80486 Cyrix K5 Pentium133 Pentium II Duron1G Athlon1G E2180 E3300 E5300 E7200 E8200 E8400 E8500 E8600 Q9550 QX6800 X3-720BE i7-920 i3-530 i5-750 Semp140@x2 955BE X4-B55 Q6600 i5-2500K i7-2600K X4-B60 X6-1055T FX-8120 i7-4790K
heatware chew*
I've got no strings to hold me down.
To make me fret, or make me frown.
I had strings but now I'm free.
There are no strings on me
anyone notice that the score chew just posted has 7790 cpu score,
while a near identical setup from slappa is getting 8219
whats the secret?
2500k @ 4900mhz - Asus Maxiums IV Gene Z - Swiftech Apogee LP
GTX 680 @ +170 (1267mhz) / +300 (3305mhz) - EK 680 FC EN/Acteal
Swiftech MCR320 Drive @ 1300rpms - 3x GT 1850s @ 1150rpms
XS Build Log for: My Latest Custom Case
probably vid drivers and CPU-NB
heatware chew*
heatware chew*
it seems to be time to show some x6 3dm06 runs?
here is my 5850 single card + x6 @ over 70*F ambient on win7 64bit.... 1more htt & win vista/7 you should be able to beat it slappa maybe not even any more cpu speed
LEO!!!! amd phenom II x6 1100T | gigabyte 990fxa-ud3 . . 2x2gb g.skill 2133c8 | 128gb g.skill falcon ssd sapphire ati 5850 | x-fi xtrememusic. . . samsung f4 2tb | samsung dvdrw . . corsair tx850w | windows 7 64-bit. ddc3.25 xspc restop | ek ltx | mc-tdx | BIP . . lycosa-g9-z2300 | 26" 1920x1200 lcd .
heatware chew*
heatware chew*
Hehe, appearently you didn't.
I wasn't actually chasing anything single card, it was just a try with just one card.
The real goal was 27K cause i saw theoldtimer and equinox do that.
As you can see, Canyon flight is the only test that gains massive from going X-fire. But i didn't need to tell you.
heatware chew*
Thanks for clarification. I'm not much into 3DMarks.
So, it seems that CPU test 2 score on second SS is normal, but the CPU Test 1 is bugged, it should be more like 100 points higher than the one on the first SS.
