+ Reply to Thread
Results 1 to 2 of 2
Thread: question about spanned volumes.
    Jan 2009
    Belgium
    0
    Hello.
    I have a quick question to bounce of you guy's.
    i have build a storage server for use at home to backup all the pc's in the house.
    I build so i could add disk's as my needs grow mainly when i upgrade the storage volume on my main rig from 1Tb disk's >2Tb > 3Tb or 4Tb disks
    The old ones go to the server..
    Raid card in the server is a arc-1680-24
    But i want all those different size disk to be one gaint volume for the os.
    I tried to combine two raid and/or volume sets in the raid controller setup but that doesn't work.
    So i could alway's create the volumes on the controller and then use the os to span both of them so you get on gaint volume.
    But does this distribute data equally over all the disk or just fills up one volume and then moves over to the other volume?
    I want to do this to keep performance reasonable and not let it drop off at the end of the array's.
    The server is also used to transcode and stream video and audio files to the various dnla devices arround the house
    i currently use win server 2008r2 on the server but that was more of a test case so i am open to other OS choices
    Thx
    Intel i7 920 DO 12GB
    EVGA x58 SLI Classified radeon 4870x2
    Creative audigy 2zs
    3WD velocirpators 300Gb in raid 0 for os short stroked to 160Gb
    Areca 1222 with 8 samsung F4E4G 2Tb in raid 6
    Everything watercooled but the areca but that's planned
    I am Xtreme zanzabar's Avatar
    Jul 2007
    SF bay area, CA
    20
    u can do it in windows but u cannot do it with the boot volume. u dont want to put the os partition on spanned disks. and since it looks like u want to back up to it its a really bad idea to use old drives to do it
    3770k, M5E, kingston 2x4GB cfr
    samsung 2TB F4EG, samsung 840 250GB , CM690II, corsair 750tx
+ Reply to Thread
