Page 1 of 2 12 LastLast
Results 1 to 25 of 36
Thread: What to do with RAM chips on Tek-9 Fat
    Jun 2009
    Philly
    What should I do here? I don't want to leave them exposed, as that may be asking for trouble. I'll be putting a nice gasket around the GPU, but I still feel cold will migrate to the ram chips causing major condensation.
    And how about the vregs in back. Just put a fan on them?
    Mobo: eVGA x58 Classified (759)
    CPU: i7-990x
    GPU: 2xGTX 580
    Cooling: F1 Gemini/Tek-9 Fat LN2 | 12k BTU Chiller HK 3.0/DD Water Block
    RAM: 3 x 2gb DDR3 Crucial Ballistix Tracers
    HD: OCZ LE SSD 100GB | OCZ Vertex 2 SSD 60GB
    PSU: PC Power & Cooling 1200W
    OS: Win7 64-Bit | XP Pro
    Monitor: Dell 2707 LCD
    I am Xtreme
    Aug 2008
    it looks sealed to me...
    Xtreme Legend
    Mar 2005
    Australia
    memory will get cold transfer dont worry about it but VREG man make sure you have a heatsink on them and a good contact with a fan blasting at it as well
    Team.AU
    Got tube?
    GIGABYTE Australia
    Jun 2009
    Philly
    Thanks, so just leave the memory as it is....don't cover it up?
    Looks like I'll be making a run to Radio shack for heatsinks
    CPU: i7-990x
    GPU: 2xGTX 580
    PI in the face
    Nov 2008
    vregs are okay with just high power fan dont worry about sinks
    Quote Originally Posted by L0ud View Post
    So many opinions and so few screenshots
    Xtreme Legend
    Mar 2005
    Australia
    get the sinks we fried a couple of cards > VRM on fire on fire (i actually thought it was some new LED light i havent seen when i noticed one of the cards on fire LOL and then it hit me >> James turn it of turn it off lol)
    costs you nothing just 10 minutes of messing around to stick them on someway heh
    Team.AU
    Got tube?
    GIGABYTE Australia
    PI in the face
    Nov 2008
    lol wtf were you doing to them haha
    Xtreme Legend
    Mar 2005
    Australia
    we used an infrared thermometer to check the temps and the TMM gets fooled by the cold air coming out of the pot but you can if you are persistent enough catch a glimpse of the real temps and when i saw 96C (cold air was mainly fooling it to report about 35C or something stupid) i thought OK time to shut it down.
    Team.AU
    Got tube?
    GIGABYTE Australia
    I am Xtreme
    Aug 2008
    the vregs stayd 30-50c...with vcore adjusted to 1.35-1.4v.
    increasing vcore did increase heat...
    dinos
    maybe 1.55v+ for 90c+ ?
    Xtreme Legend
    Mar 2005
    Australia
    no mate it was similar to your volts
    how did you measure the temps?
    Team.AU
    Got tube?
    GIGABYTE Australia
    I am Xtreme
    Aug 2008
    infrared gun...
    Xtreme Legend
    Mar 2005
    Australia
    sounds like you were doing what we were doing also >> temps are actually much higher
    Team.AU
    Got tube?
    GIGABYTE Australia
    PI in the face
    Nov 2008
    we need a real man to finger test, dinos you still have finger prints after all these years of overclocking?
    Xtreme Legend
    Mar 2005
    Australia
    ahhh the finger test
    Team.AU
    Got tube?
    GIGABYTE Australia
    PI in the face
    Nov 2008
    q56 here is mine after 1hr30min full pot session with just fan (I am in 45F garage though so maybe sinks would be better for you) Card is robust though, no need for stupid hairdryer atleast
    Attached Images Attached Images
    I am Xtreme
    Aug 2008
    psu show off lol
    PI in the face
    Nov 2008
    ^rofl zapped
  18. #18
    Jun 2009
    Philly
    Thanks for the feedback guys Cool pic Splave!
    So this is how I'm going to run. Shoot holes in it please....
    The GF110 is so much bigger than the surface contact on the Tek-9.
    I'm not brave enough yet to do any voltage hardmods, lol!
    One of Kingpin's methods: He's right the grey tape comes right off, so I can probably reuse this backing over and over.
    I've got to figure out way to attach these. Hopefully ceramique will hold them on sufficiently. I don't have a heatsink for the top vreg, hopefully fan will be ok. What do you guys think?
    CPU: i7-990x
    GPU: 2xGTX 580
  19. #19
    PI in the face
    Nov 2008
    looks great man if anything to error on the side of too much insulation is better than not enough.
  20. #20
    ODOC
    Aug 2006
    Copenhagen - Denmark
    Try to find some rubber bands / elastics durable enough to withstand the eventually deep frezze or use multiple (redudancy)
  21. #21
    Looks ready to rock to me
  22. #22
    Jun 2009
    Philly
    Thanks guys for checking her out. Boots up good, so all ready to go..... Except no LN2 til Monday. Dang airgas couldn't fill today
    CPU: i7-990x
    GPU: 2xGTX 580
  23. #23
    Xtreme Legend
    Mar 2005
    Australia
    Very nice man
    How are the headsinks connected to pwm, thermal tape or also some sort of adhesive?
    Team.AU
    Got tube?
    GIGABYTE Australia
  24. #24
    Jun 2009
    Philly
    I first thought they were on good with ceramique, but after I booted to make sure everything was working, they started to slide down, lol! So I did what oliver suggested and used a rubber band (Thanks oliver!). It's not perfect because the force of the rubber band pulls the heatsinks together, leaving a few mm of the bottom vrm exposed. But I guess that will be ok.
    CPU: i7-990x
    GPU: 2xGTX 580
  25. #25
    -_-
    Sep 2006
    ATLanta, Ga.
    you just made me realize how freaking lazy I have become with GPU prepping.......:p
    have fun with that setup. Looks good
    Quote Originally Posted by Gautam View Post
    I'll add my name to this elpida graveyard as soon I even think about running 32M. (yes, the thought is enough)
