Does the EVGA SR-2 works fine with HX1000 corsair PSU?
i want to built a
dual E5520 (80watt each) overclock them to 3Ghz or little bit more
one GPU 6870
12GB ram
and 8 SSD's
is it possible to work??
i want to built a
one GPU 6870
12GB ram
and 8 SSD's
I dont think that the hx1000 has enough cpu power connectors to power two cpu's
soo its ok to use it ???
I've been using a HX1000 before switching to AX1200 for a good while, and it was doing good.
HX1000 will work for sure if you don't have too many GPU, but those cost almost the same now, If you haven't bought yet, you may want to look at AX1200 too.
► ASUS P8P67 Deluxe (BIOS 1305)
► 2600K @4.5GHz 1.27v , 1 hour Prime
► Silver Arrow , push/pull
► 2x2GB Crucial 1066MHz CL7 ECC @1600MHz CL9 1.51v
► GTX560 GB OC @910/2400 0.987v
► Crucial C300 v006 64GB OS-disk + F3 1TB + 400MB RAMDisk
► CM Storm Scout + Corsair HX 1000W
► EVGA SR-2 , A50
► 2 x Xeon X5650 @3.86GHz(203x19) 1.20v
► Megahalem + Silver Arrow , push/pull
► 3x2GB Corsair XMS3 1600 CL7 + 3x4GB G.SKILL Trident 1600 CL7 = 18GB @1624 7-8-7-20 1.65v
► XFX GTX 295 @650/1200/1402
► Crucial C300 v006 64GB OS-disk + F3 1TB + 2GB RAMDisk
► SilverStone Fortress FT01 + Corsair AX 1200W
i want to use only one GPU and that will be 6870
but i want to oc my CPU (low watt cpus 160watt total @ stock settings)
You will be fine then.
I've been running 2 x X5650 @3.8GHz + GTX295, and HX1000 didn't cause any instability, or made any noise or other complains.
► EVGA SR-2 , A50
