I was supposed to be wiring and testing the controller today, but I just couldn't resist getting started on one of 2 cascades I'm putting together.
The other one will have a TEV/CPEV setup, but this one is going to be 'old school' with captube and home brew oilsep with a handvalve. Mainly because of the space issues. You'll see what I mean...
Got ahold of a cool little condensing unit, though I had to get rid of the barrel fan, it was too loud and got in the way of the small size. The curved condensor is awesome though, and I already have a couple of ideas for fan setups. We'll see how that happens. Only the first stage is set up, and it's R290 for testing until I'm back at work and have access to 404a or 402a. I'm thinking colder though, since the condensor is ideal for that kind of thing.
Specs
1 x Toshiba 12cc Rotary 1st stage
1 x LG 12cc Rotary 2nd stage
12000 btu curved condensor
18 plate HX
6' .040 captube 1st stage
6' braided flex is sitting there for the 2nd stage, planning 6.5' or so of .031 captube, though I may adjust that.
Likely 402a 1st and either R23, Ethane or Ethylene for 2nd, depending what I get first. I don't have any gasses here, not even Co2, so I'll have to be patient. Hoping to have one of them before the end of the week, but we'll see. Only gas my suppliers use for HVAC here is 508 and that's 4k+ for 5 kg so it's not going to happen.
Found a good supplier but need to set up an account and all that. Hope it goes quick.
That's about it for now, running a little overcharged and terrible condensor cooling now, but it's about -43c on the HX, around 0psig. 402a will be far better and once the shroud is made up for the fans it should bring my head pressure down, and temps along with it.
With R290 and terrible fan power it's running 160psig/0psig sitting there, no load other than being uninsulated.
So I'm happy and leak free so far
Hope to get it mostly done by the weekend if gas allows, and make the case into something pretty afterwards.
The chassis frame is about 1' Square. Everything fits though, just barely, with room for insulation and wiring, and I'm hoping to get the oilsep into that little empty space next to the HX. Should be a perfect fit. Already have the pipes ready for it, but I need to braze it tomorrow if I can. All being well, I'll have the second stage finished and ready for gas tomorrow.
I have a few evaps here, but I'm not sure what to use. Probably either the Kayl or the other stepper that's here. Not sure, but probably the Kayl will be used. I like 'em.
Once the workings are done and the fan shroud ready, I've got exterior panels in mind, perspex will do nicely, since the fan/exhaust will be strong enough to prevent the heat fading and staining. I may go with a white panel setup, but I'm not sure. White/blue LED kind of motif sounds nice.
Gray
