Bench/Crunch Rig
i7-2600k
MSI P67A-GD65
ATI 6950x2
8 GB G.Skill Pi DDR3-1600
Xigmatech CPU cooler
Sparkle Gold 1250w PSU
Crunching Rig #2
Q-6600
Asus P5K-Deluxe WiFi
4 GB G.Skill DDR-2
ATI 4850
Tuniq Tower
24/7 rig
i-7 930
ASUS REII
ATI HD5850
Noctua CPU cooler
8 GB G. Skill Ripjaws DDR3-1600
Media Server Under Construction
E6750
Asus Maximus Formula
NVIDIA GT9500
4GB G.Skill Pi DDR2
Stock cooler
2xHitachi Deskstar 2TB HDD
only so much i can do with 2 GPU's haha. I would add my 3870 as well but I'm pushing the limit as it is with my power bill. My OCed 5870 finishes a WU about every 1min 30sec. It's a real champ
I know slaveondope has at least 2 5850's which would be more then enough to overrun my 5870 and 4850
CPU: Intel Core i7 3930K @ 4.5GHz
Mobo: Asus Rampage IV Extreme
RAM: 32GB (8x4GB) Patriot Viper EX @ 1866mhz
GPU: EVGA GTX Titan (1087Boost/6700Mem)
Physx: Evga GTX 560 2GB
Sound: Creative XFI Titanium
Case: Modded 700D
PSU: Corsair 1200AX (Fully Sleeved)
Storage: 2x120GB OCZ Vertex 3's in RAID 0 + WD 600GB V-Raptor + Seagate 1TB
Cooling: XSPC Raystorm, 2x MCP 655's, FrozenQ Warp Drive, EX360+MCR240+EX120 Rad's
My toys:
Asus Sabertooth X58 | Core i7-950 (D0) | CM Hyper 212+ | G.Skill Sniper LV 12GB DDR3-1600 CL9 | GeForce GTX 670-2048MB | OCZ Agility 4 512GB, WD Raptor 150GB x 3 (RAID0), WD Black 1TB x 2 (RAID0) | XFX 650W CAH9 | Lian-Li PC-9F | Win 7 Pro x86-64
Gigabyte EX58-UD3R | Core i7-920 (D0) | Stock HSF | G.Skill Sniper LV 4GB DDR3-1600 CL9 | Radeon HD 2600 Pro 512MB | WD Caviar 80GB IDE, 4TB x 2 (RAID5) | Corsair TX750 | XClio 188AF | Win 7 Pro x86-64
Dell Dimension 8400 | Pentium 4 530 HT (E0) | Stock HSF | 1.5GB DDR2-400 CL3 | GeForce 8800 GT 256MB | WD Caviar 160GB SATA | Stock PSU | (Broken) Stock Case | Win Vista HP x86
Little Dot DAC_I | Little Dot MK IV | Beyerdynamic DT-880 Premium (600 Ω) | TEAC AG-H300 MkIII | Polk Audio Monitor 5 Series 2's
just ordered a xfx5830....didnt want to but it was that or buy a 4850 for 110$ =\
so im gonna return that gtx275 and fall out of pie for the weekend til that card comes in
Intel C2Q Q9550 2.83ghz :: Intel DQ45CB :: 4 x 2gb OCZ DDR2 PC2-8500 Reaper HPC :: ASUS EAH5850 :: Thermaltake TR2 RX 750w :: Western Digital Caviar Black 4 x 750gb in RAID 10
Intel e3-1235 3.3ghz :: Intel s1200kp :: 4gb kingston hyperX 1600mhz :: WD 500gb Cavier Green
Intel i7-3770k 4.4ghz :: msi z77ma-g45 :: 8 gb patriot Signature 1600mhz :: 160gb WD Cavier :: 5830 + 5870 CF :: Antec Earthwatts 650w
"...all men die, and no brave man lets death frighten him from his desire..."
Wow guys, good job!
I see that you guys are beating on the green camp, keep it going.
Crunch on XS
Hey guys. I have a few questions. I was wondering if it is possible to use a nvidia and ati card in the same machine for crunching. I hope there won't be any driver conflicts. I plan on using my old cards, a 3870x2 and a GTX 280... trying to get some good use out of them since they have been lying around for the past year collecting dust. I will put the 3870x2 on M@H and the GTX 280 on gpu grid or F@H. Also in case you are wondering I am going to be using a 890fx board.
ASUS P5E3 PREMIUM X48 - Intel Q9550 - Corsair Dominator 8GB 1600MHz - Corsair H50 - Corsair P128 SSD - WD VelociRaptor 300GB - WD Caviar Black 2TB 64mb cache - Sapphire 5870 - Lian Li PC-7FN - PC and Power Cooling 860 - Creative X-FI Titanium - LG Blu-ray Drive - Samsung DVD-RW - Logitech MX1000 - Logitech 920 - Gateway FHD2400
ASH
It is possible to use different cards in a same system, but it will be pretty hard configure the system to run the 3870x2 on M@H and the GTX280 on GPUGRID.
However, the configuration will be far easier if you intend to run the GTX280 on F@H, if you don't mind the heat output and the power draw.
Well I noticed that under M@H settings I can choose whether I want to run it on a nvidia or ati gpu or both if present. Just having one manager makes everything easier imo. The cards actually have wc blocks on them. I might need to get a new rad for this :/. It would be quite a bit of heat output at 100 percent load. Especially if I put my 1055T on the loop for WCG. I actually have another 3870x2, but it used to give me some weird problems... not sure if it is defective. But I will test that out. Once I get the funds I will give this a try. I am positive that my TX750 would explode and my 3 x 120 rad would be overloaded. I am going to keep an eye on ebay if I can pick up a 1000-1200 watt psu for cheap.
ASH
HD3870's weren't all that high-power. You could probably get away with it if you don't have a high-clocked quad.
It should actually be easier to setup if you run GPUGRID & MW@H, since GPUGRID is nVidia-only and MW@H lets you select which coprocessors to use (it supports both CPU, ATI, & nVidia; disable CPU & nVidia so it only runs on ATI)
My toys:
Celestial, i had a 4850x2 and a GTX275. on paper the gtx275 is the biggest and baddest by comparison. on the MW@H however the 4850x2 was able to complete 2 work units on 2 cores in 4minutes each. 1 WU on 1 core in 4min. the gtx275 did 1 work unit every 13minutes. i changed that nvidia number from 128 to 40000 and it went from 13min to 11. i even overclocked that gtx275 to 800mhz core and no where close to that 4850x2 =\
MSI Afterburner. i have rivatuner and ati CCC and had the nvidia panel but rivatuner and CCC and such had locked numbers and afterburner was the only unlocked interface
Here you go masterg, give this a read through;
http://www.xtremesystems.org/forums/...d.php?t=246434
Shadders are all you should be interested in - upping the core clock has no relevance in GPUGRID. Some down clock it for a 1-2c temp drop - doing this on my 275 just errored out wu's, luck of the draw.
Go grab EVGA Precision. You should be able to run 1458 shadder right off the bat. Let us know how you get on.
Nymph - Xeon 5675 @ 4.1 w/ x2 680
Ikaros - i7 920 w/ 275 - Build In Progress
Long live LGA1366
ive already returned the GTX275. i bought it to try to match my 4850x2 in MW@H and it couldnt get anywhere near it. afterburner dragged up the shader with the core. i cant remember the shader numbers when i did but it started at 633/1400 based on ASUS specs page. i ramped it up to 800/~1580. afterburner took shader up with core clock so it was pretty dang high and barely dropped my time by 20 seconds...
ive dropped my gtx275 and only lost ~10,000points compared to my 4850x2's ~140,000
Anyone knows how many points 2x 5870 and one 5970 will average at stock clocks?
I can not run them OC'ed cause I'm already at my PSU's max limit, the whole rig is now pulling 960w from the socket. Tried to run it at max OC but then it wass pulling 1500w from the socket and I'm running with a 1000w PSU.
just got my 5830 today and its DOA doesnt detect when installed and creates artifacts all over my screens
My toys:
I'm curious if there are any budget ATI cards that can be good crunchers? I know with Nvidia the GT 240 does decently in GPUGrid.
i3-8100 | GTX 970
Ryzen 5 1600 | RX 580
Assume nothing; Question everything
HD3800s or better, HD4800 or better, HD5800 or better, or HD6900 or better. anything under a HD5800 or below HD6900 cant run MW@H i dont know about anything under a HD4800 or HD3800
Yah it probably wouldn't be worth it, but i remember back in the day a 3600 did decently in F@H GPU.
i3-8100 | GTX 970
