If you're in Windows you may need to do that either as the Administrator, in Safe Mode (without any drivers loaded) or by booting from a live cd.
[SIGPIC][/SIGPIC]
sweet, i saved the file to my desktop, renamed the old one and copied in the changed file as admin and that worked and im running at 550mhz now
drop in 75mhz resulted in drop of 4C
Intel C2Q Q9550 2.83ghz :: Intel DQ45CB :: 4 x 2gb OCZ DDR2 PC2-8500 Reaper HPC :: ASUS EAH5850 :: Thermaltake TR2 RX 750w :: Western Digital Caviar Black 4 x 750gb in RAID 10
Intel e3-1235 3.3ghz :: Intel s1200kp :: 4gb kingston hyperX 1600mhz :: WD 500gb Cavier Green
Intel i7-3770k 4.4ghz :: msi z77ma-g45 :: 8 gb patriot Signature 1600mhz :: 160gb WD Cavier :: 5830 + 5870 CF :: Antec Earthwatts 650w
"...all men die, and no brave man lets death frighten him from his desire..."
New members stang, THE1320GOD, retro77, Black~Mystic
Im missing a few others from yesterday so welcome all I take it everyone is staying warm
Team stats for M@H and be checked here
Errr, maybe we should really start a M@W/Collatz subforum
idk why im listed as Black~Mystic, i joined as masterg
after 11 hours i've got pie ^(^_^)^
CPU: Intel Core i7 3930K @ 4.5GHz
Mobo: Asus Rampage IV Extreme
RAM: 32GB (8x4GB) Patriot Viper EX @ 1866mhz
GPU: EVGA GTX Titan (1087Boost/6700Mem)
Physx: Evga GTX 560 2GB
Sound: Creative XFI Titanium
Case: Modded 700D
PSU: Corsair 1200AX (Fully Sleeved)
Storage: 2x120GB OCZ Vertex 3's in RAID 0 + WD 600GB V-Raptor + Seagate 1TB
Cooling: XSPC Raystorm, 2x MCP 655's, FrozenQ Warp Drive, EX360+MCR240+EX120 Rad's
My toys:
Asus Sabertooth X58 | Core i7-950 (D0) | CM Hyper 212+ | G.Skill Sniper LV 12GB DDR3-1600 CL9 | GeForce GTX 670-2048MB | OCZ Agility 4 512GB, WD Raptor 150GB x 3 (RAID0), WD Black 1TB x 2 (RAID0) | XFX 650W CAH9 | Lian-Li PC-9F | Win 7 Pro x86-64
Gigabyte EX58-UD3R | Core i7-920 (D0) | Stock HSF | G.Skill Sniper LV 4GB DDR3-1600 CL9 | Radeon HD 2600 Pro 512MB | WD Caviar 80GB IDE, 4TB x 2 (RAID5) | Corsair TX750 | XClio 188AF | Win 7 Pro x86-64
Dell Dimension 8400 | Pentium 4 530 HT (E0) | Stock HSF | 1.5GB DDR2-400 CL3 | GeForce 8800 GT 256MB | WD Caviar 160GB SATA | Stock PSU | (Broken) Stock Case | Win Vista HP x86
Little Dot DAC_I | Little Dot MK IV | Beyerdynamic DT-880 Premium (600 Ω) | TEAC AG-H300 MkIII | Polk Audio Monitor 5 Series 2's
ive got a 4850x2 chugging alone. im gonna go out looking for a MW@H-able graphics card for my 2nd pc cause my 8800gt aint
and you got more points because i had to UNDERCLOCK my 4850x2 to keep it from burning out. it is capable of running at 725mhz per core and its at 500mhz to keep it stable
edit: well maybe not for HIpno >_>
Look into running that 8800gt on our GPUGRID team Nvidia's do best there.
Everything you need to know
Joining the easy way just make sure you run the Dev.Drivers at the bottom of the guide
GPUGRID has them as too slow or not working but WFO just ran 4x8800gt's and 2x9600's on GRID without issue all last week running the Dev. drivers.
You have ~4days from receiving a WU to return on GRID and they take ~12-24hours to complete a WU.
If you where dedicated to it and let it run Im sure you can score ~10k ppd. Thats what Im aiming for with a 9800gt (8800) just got messed up with the wrong drivers for awhile.
Looking good so far with the Devs, knocks on would.
Case: Modded 700D
Hello everyone,
I was wondering what kind of temps I should be watching out for. If I run at 500MHz I top out at about 69*c and at 550MHz I'm at about 74*c. I'm not sure how much an extra 50MHz does and if an extra 5*c is that bad.
Thanks for the help.
Cruncher #1: i7 860 @ 3.6GHz
Cruncher #2: "WatSon" i7 4670k @ 4.0GHz / GTX 760 for GPUGRID
you guys really have no idea how hot this 4850x2 gets..... its 40 degrees outside and im sleeping with my windows open...
sweating my arse off watching dvds on my pc
My toys:
masterg may I ask you where on the globe you are based. 40 Degrees external temps that's a lot. I think you should study a cooling system for your room based on the heat emitted by your system. These are called adsorption systems.
[SIGPIC][/SIGPIC]
Good for you m8
