Page 2 of 6 FirstFirst 12345 ... LastLast
Results 26 to 50 of 150
Thread: ATI video cards and BOINC
  1. #26
    Devil kept pokin'
    Jan 2010
    South Kakalaky
    Quote Originally Posted by retro77 View Post
    I'm at 104* C on air....
    Create a custom fan profile in MSI AfterBurner
  2. #27
    Xtreme crazy bastid
    Apr 2007
    On mah murder-sickle!
    For my personal comfort levels that's WAY too hot. If I ever get into GPU crunching I'll also be getting into water cooling.
    [SIGPIC][/SIGPIC]
  3. #28
    Xtreme Mentor
    Dec 2007
    State of Confusion, USA
    Hey Folks,
    I just tried to set up MW@home on my Boinc profile...
    I'm no expert yet, but I'm pretty sure I did everything right.
    I set the perfs as noted (no CPU etc) but whenever I turn MW@H on it steals 3 cores from my CPU that should be used for WCG tasks
    and my GPU temps don't increase...
    I'm getting the feeling that MW@H doesn't recognize the 6870 series cards yet.
    Can anyone confirm/deny this?
    Or am I just doing something wrong...
    AMD FX-8350 (1237 PGN) | Asus Crosshair V Formula (bios 1703) | G.Skill 2133 CL9 @ 2230 9-11-10 | Sapphire HD 6870 | Samsung 830 128Gb SSD / 2 WD 1Tb Black SATA3 storage | Corsair TX750 PSU
    Watercooled ST 120.3 & TC 120.1 / MCP35X XSPC Top / Apogee HD Block | WIN7 64 Bit HP | Corsair 800D Obsidian Case
    First Computer: Commodore Vic 20 (circa 1981).
  4. #29
    Devil kept pokin'
    Jan 2010
    South Kakalaky
    Hey Dave havent heard anything about the 6series cards yet. If its eating up your WCG cut that sucker off.
    M@H is just an added bonus to me personally.
  5. #30
    Xtreme Mentor
    Dec 2007
    Thanks Slave,
    Yeah... I turned it off for now, but I'm a true geek, SETI and this project really interest me.
    I'll try and figure it out on my own...
    My VC has nice aftermarket cooling so I don't think temps would be a problem.
    I'm bored anyway, I'll check for new driver patches etc.
  6. #31
    Xtreme Cruncher
    Oct 2007
    MW@H needs a double precision card and the 6800's are only single precision. Collatz Conjecture may be the only 6800 friendly project?
    XTREMESupercomputer: Phase 2
    Live up to your name - November 1 - 8
  7. #32
    Xtreme Mentor
    Dec 2007
    Quote Originally Posted by trn View Post
    WOW... Really?
    That kind of shocks me, because thats the error message I keep getting from Boinc: "An ATI GPU supporting double precision math is required"
    I found a new Hotfix for the 6870 drivers (E) and updated, but it still doesn't want to work....
    Actually, I'm really happy with the 6870 for gaming/benching it's a great bang for the buck card!
    I'd refuse to pull it from the main rig because of this...
    Guess I'll have to put a crunching rig together using my old 4850.
    Do you know if it supports double?
    Thanks..... Dave
  8. #33
    Xtreme Cruncher
    Apr 2006
    Quote Originally Posted by Daveburt714 View Post
    WOW... Really?
    Thanks..... Dave
    the 4850 sure does, im using one I added my 5870 for a bit tonight as well, about one WU every 1 min 10sec. the 4850 alone turned out like 60k in half a day. totally crazy.
    oh and Movieman, I would be more then happy to post else were but I can't seem to find the MW@H subforum and considering the thread is here...
    CPU: Intel Core i7 3930K @ 4.5GHz
    Mobo: Asus Rampage IV Extreme
    RAM: 32GB (8x4GB) Patriot Viper EX @ 1866mhz
    GPU: EVGA GTX Titan (1087Boost/6700Mem)
    Physx: Evga GTX 560 2GB
    Sound: Creative XFI Titanium
    Case: Modded 700D
    PSU: Corsair 1200AX (Fully Sleeved)
    Storage: 2x120GB OCZ Vertex 3's in RAID 0 + WD 600GB V-Raptor + Seagate 1TB
    Cooling: XSPC Raystorm, 2x MCP 655's, FrozenQ Warp Drive, EX360+MCR240+EX120 Rad's
  9. #34
    Dec 2008
    Quote Originally Posted by D_A View Post
    And some serious money, those WB aren't cheap
    I could probably add my 5850 to my loop without seeing any real impact on cpu temps but I can't justify the cost of the wb.
    Thanks Slave,
    edit: I decided to try this anyway to see if my temps would be reasonable, but none of the WU's run
  10. #35
    Devil kept pokin'
    Jan 2010
    South Kakalaky
    @ Red Maw
    Make sure you have gpu on while in use in BOINC manager other wise it will only run when its been idle for X minutes as seen below it.
  11. #36
    Oct 2006
    A place the sun don't shine (Seattle)
    How can i control the GPU usage? i want milkway to use no more then 75% of my GPU, i set that in preferences but it doesnt take affect anywhere. i also said that i dont want Milkyway using my CPU yet its still using 25% of it
    Intel C2Q Q9550 2.83ghz :: Intel DQ45CB :: 4 x 2gb OCZ DDR2 PC2-8500 Reaper HPC :: ASUS EAH5850 :: Thermaltake TR2 RX 750w :: Western Digital Caviar Black 4 x 750gb in RAID 10
    Intel e3-1235 3.3ghz :: Intel s1200kp :: 4gb kingston hyperX 1600mhz :: WD 500gb Cavier Green
    Intel i7-3770k 4.4ghz :: msi z77ma-g45 :: 8 gb patriot Signature 1600mhz :: 160gb WD Cavier :: 5830 + 5870 CF :: Antec Earthwatts 650w
    "...all men die, and no brave man lets death frighten him from his desire..."
  12. #37
    Mar 2009
    you cant set % for GPU.. it either uses it or it doesnt. If its a multicore GPU, you could make it only use 1 core perhaps..
    As far as it using your cpu.. it does use like 5% of cpu no matter what.. if you made a change on the milkyway website ( and no tlocal ), make sure you force an update to pull the new config.
  13. #38
    Devil kept pokin'
    Jan 2010
    South Kakalaky
    @ masterg
    I looked back over my settings and Im afraid to say its all or nothing when it comes to gpu % usage.
    As for your 25% cpu usage by M@H check the first page I posted the preferences you should use to minimize CPU usage for M@H
    I suspect you may have changed your CPU usage to 75%, not GPU and have a setting for M@H somewhere that is allowing for it to use your CPU.
    You should only get ~2%-5% max CPU usage from M@H when setup as Ive shown.
  14. #39
    Oct 2006
    Is there a way to automatically control the GPU runnings then? cause i have a 4850x2 2GB. its a friggin beast MW@H will use both GPU cores on it, but it reach ~91C on each core doing so and this has caused BSODs in the past
  15. #40
    Devil kept pokin'
    Jan 2010
    South Kakalaky
    Quote Originally Posted by masterg View Post
    Under clock and under volt my friend or add fans/water
  16. #41
    Oct 2006
    Thanks, i just might try that
  17. #42
    Oct 2006
    The GPU clock cant go any slower...
  18. #43
    Oct 2006
  19. #44
    Devil kept pokin'
    Jan 2010
    South Kakalaky
    You have any voltage control What are you using to change clocks also?
    Back to what you asked earlier too, I dont believe you can control how many gpu cores to use. Ive tried suspending just on of mine but t will just jump that task and start another.
    EDIT I see pics now MSI AfterBurner it lets me go more than 100mhz under stock if I like.
  20. #45
    Oct 2006
    I have Rivatuner and ATI Catalyst Control 10.10 both of them list my GPU as being at the lowest clock settings of 625MHZ and im not able to select lower and i dont like touching voltages
  21. #46
    Oct 2006
    i got MSI Afterburner and when i try to set the Clocks to 550mhz, i click apply and they reset to 625. i dont think i can lower them
  22. #47
    Oct 2006
    and i must say 165 credits in ~10minutes... @_@
  23. #48
    Devil kept pokin'
    Jan 2010
    South Kakalaky
    You may need to change UnofficalOverClocking value 0 to 1 I believe in the .cfg file.
    Also be sure to check sync similar cards in settings as seen in pic.
  24. #49
    Oct 2006
    it wont let me change the .cfg file. it keeps saying "Access Denied" when i try to save the changes. i love the fact that these jobs only last 8 seconds on my beast
  25. #50
    Devil kept pokin'
    Jan 2010
    South Kakalaky
    Be sure your closed out of AfterBurner completely and if it still deny's access run as admin.
